Latest post Wed, Oct 21 2009 12:26 PM by jveekeres. 3 replies.
  • Thu, Oct 15 2009 9:01 PM
    • afaurote
    • Joined on Fri, Aug 17 2007
    • Posts 3
    • Points 45
    How to use both ethernet ports on a MacPro
    I'm trying to get my MacPro to connect to both our network and our Unity at the same time.
    Currently, I have port 1 wired to a router giving me access to our network and the internet. Port 2 has a crossover cable wired directly to the unity (we have four Avids using all four fibre channel slots and this system has no fibre card in it).
    In System Preferences, I can arrange the Service Order for the devices, but it will only allow access to the ethernet port on top. In other words, if I make the Ethernet Port 1 the top priority, I have access to the internet and our network, but not the Unity. If I make Port 2 the top, then I can see the partitions on the Unity, but cannot access our network or internet.
    For some reason, I cannot use both ports at the same time.
    Thanks.
  • Sat, Oct 17 2009 4:21 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,832
    • Points 201,135
    Re: How to use both ethernet ports on a MacPro
    I'm fairly certain that we don't support Dual NICs on a Mac.
  • Sun, Oct 18 2009 1:32 PM In reply to
    • mkj
    • Sweden
    • Posts 69
    • Points 830
    I have that setup.
    A Mac Pro connected with NIC1 to the unity, and NIC2 to internet without problem.
    Actually it also works to set 2 diffrent ip's on a single nic on my pc's...and no problems.
    But of course, this is not qualified by Avid....
  • Wed, Oct 21 2009 12:26 PM In reply to
    • jveekeres
    • Athens Greece
    • Posts 671
    • Points 8,470
    Hi, Yes this can work but is not supported and has its security risks and can slow down your network performance.
    You need to make sure that both networks are in different subnets. The network that connects to the unity should also not have a default gateway filled in.
    For example. If your internet network is a 10.1.1.x network. And your Unity network is a 192.168.1.x network. You will see that it works. I have done this for years on pc.
    But be careful with viruses etc....
    Good luck
    7x HP XW8400 9x HP XW8200 4x HP XW8000 5x Media Composer 3.1 2x Media Composer 3.1 Adrenaline 2x Media Composer 2.7 Adrenaline HD 1x Media Composer... [view my complete system specs]
    Jeroen van Eekeres
    Ena productions
    Software activation AND dongle is better then only software activation.
