Latest post Fri, Oct 16 2009 5:46 PM by metropolis. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Oct 12 2009 3:03 PM
    • metropolis
    • Joined on Mon, Aug 4 2008
    • Posts 7
    • Points 75
    DS 10.1.2 doesn't keep custom video output settings
    Hi every body,
    when we change the output video settings (lets say I lower the R-Y chroma setting) and press the "SAVE PARAMETER" button for component video, when we restart the PC and the breakout box, the system does not keep the change and the factory settings are back.
    We use the component output, but we need to lower the chroma in order to be in "legal colors" when outputting to Beta SP.
    How can I keep my custom settings?
    Any suggestions?
    Tommy R.
  • Mon, Oct 12 2009 4:18 PM In reply to
    • GusC
    • Burbank, CA
    • Posts 363
    • Points 4,380
    • Moderator: Avid DS
    Re: DS 10.1.2 doesn't keep custom video output settings
    Can you use the realtime legalizer/clipper in the Color Corrector?
  • Mon, Oct 12 2009 4:57 PM In reply to
    • metropolis
    • Posts 7
    • Points 75
    Yes, I suppose we can.
    But I prefer to calibrate the component output with a vectoscope and a waveform, (and using a calibrated monitor), and live the legalizer/clipper in the Color Corrector for small adjustments.
  • Mon, Oct 12 2009 4:58 PM In reply to
    • metropolis
    • Posts 7
    • Points 75
    The question here is why the settings are not being kept by the breakout box or the sofware?
    Thanks for the help.
    Tommy
  • Thu, Oct 15 2009 4:04 PM In reply to
    • metropolis
    • Posts 7
    • Points 75
    Any suggestion? Sylvain?
    thanks
    T
  • Fri, Oct 16 2009 5:28 PM In reply to
    • slabross
    • Montreal
    • Posts 381
    • Points 3,810
      Moderator: Avid DS
    Unfortunately, these specific settings are not saved in the deck template and they are driven by the Nitris hardware, so when the gear is power cycled or the DS application reinitializes the Nitris drivers, these settings are indeed going back to their defaults. It is a design limitation.
    Sylvain Labrosse
    Avid DS Product Champion | Video Customer Success
    Avid
    3510 St-Laurent Boulevard
    Montréal, QC H2X 2V2
    Canada
    sylvain.labrosse@avid.com
    We're Avid.  Learn more at www.avid.com
  • Fri, Oct 16 2009 5:46 PM In reply to
    • metropolis
    • Posts 7
    • Points 75
    Thanks for the answer Sylvain, I thought I was doing something wrong.
    But that drives me to the problem on how to calibrate the analog component output, and rkeep it fixed for new projects.
    What would you suggest appart from using "clamp to video levels, color correction"?
    Tommy
