Latest post Mon, Oct 12 2009 4:14 PM by GusC. 5 replies.
Page 1 of 1 (6 items)
  • Sun, Oct 11 2009 5:57 PM
    • AYMAN26
    • Joined on Sun, Dec 28 2008
    • Posts 14
    • Points 260
    resetting X or Y value..
    how can i reset one value for example X value of the size in the DVE instead of pressing reset button which reset all the values (size,rotaion,.... in the DVE effect ).
  • Sun, Oct 11 2009 6:28 PM In reply to
    • Brickwad
    • Simsbury, CT
    • Posts 482
    • Points 5,700
    Re: resetting X or Y value..
    Over to the right of the X or Y slider is a numeric value. Click on it, and hit zero "0" then "enter" on your numeric keypad.  That will reset the value to default.
    Good Luck.
    I have 10 Avid systems, DX, Meridian and DNA. 1 MCA 1.8 on 2.5 quad G5 w/ 5 Gigs of Ram, 1 Symphony Nitris DX on eight core mac pro with 4 gig ram, 1 MC... [view my complete system specs]
    Andy
  • Sun, Oct 11 2009 6:42 PM In reply to
    • AYMAN26
    • Posts 14
    • Points 260
    i'll give try tomorrow..
    BUt u know i mean resetting..since i don't know what is the defaut value..
    in the case of scale the X and Y dafukt value is 100 not 0...
  • Sun, Oct 11 2009 6:46 PM In reply to
    • Brickwad
    • Simsbury, CT
    • Posts 482
    • Points 5,700
    That's right - so you enter "100" instead of zero.  Also, if it's a scaling value you're resetting, make sure to uncheck the box that links the values - unless you want to reset both X and Y.
    Andy
  • Sun, Oct 11 2009 6:51 PM In reply to
    • AYMAN26
    • Posts 14
    • Points 260
    THEN i didn't get the answer i mean man!
    i wanna hit button to reset the certain value only..
    it is found in sooo many S/W..
    and it is good for animation when i reset key fram value..
    for example..
    it is faster to hit this reset instead of typying 1920 value in translation value of X,,
    u heit reset..u get this value written by itself..cuz not all dafault values 0 and 1000
  • Mon, Oct 12 2009 4:14 PM In reply to
    • GusC
    • Burbank, CA
    • Posts 362
    • Points 4,375
    • Moderator: Avid DS
    Some parameter in DS, like the color corrector, offer the ability to reset individual parameters.  The DVE is, unfortunately, not one of them.
    As a workaround to find the original default parameter, you could hit 'reset', then either copy or memorize the default value and hit CTRL+Z for undo, and that will put you back to where you were.
