Latest post Mon, Oct 12 2009 1:32 PM by mattman. 7 replies.
  • Sat, Oct 10 2009 3:35 AM
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,030
    • Points 25,920
    • Moderator: MCA PC
    Can an MC Dongle co-exist.....?
    As I am still on MC 3.1.2, I have a dongle attached.
    I will soon be installing a completely different piece of software (from Sonic) that also has its own USB dongle.
    Do any of you know from experience whether or not there are complications having 2 different USB dongles installed on the same computer system?
    I realise that after I upgrade MC, in the future, I could run it under software activation, but for the present I am staying with the dongle.
    Of course, I am also asking the same question of Sonic.
    Regards,
    Douglas
    (AMC MojoDX 3.1.2 - XP Pro SP2) + (AMC MojoDX 4.0.2 Vista64 Business SP1),ASUS PK5 DEluxe/WiFi-AP CH1-14 Mobo,Intel Core 2 Duo E6850 (3GHz)8GB Corsair... [view my complete system specs]
  • Sat, Oct 10 2009 3:40 AM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,822
    • Points 201,035
    Re: Can an MC Dongle co-exist.....?
    Douglas, for a long time I ran with three different dongles attached for MC, Sapphire and Lightwave. Don't know about Sonic but I assume it should be fine.
  • Sat, Oct 10 2009 3:47 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,030
    • Points 25,920
    • Moderator: MCA PC
    BLKDOG:
    Thank you BLKDOG,
    That sounds extremely positive and reassuring Big Smile Geeked
    Regards,
    Douglas
  • Sat, Oct 10 2009 4:36 AM In reply to
    PC's here run happily here with a pair of iLoks, ProCoder and MC dongles attacched
    Thanks for the continued dongle support
  • Mon, Oct 12 2009 10:57 AM In reply to
    • maxvideo
    • Posts 47
    • Points 580
    MC and Inscriber TitleMotionPro with USB dongles. No problems.
    MC MojoDX 3.5.1, WinXP SP3,QT 7,6, HP XW8600 workstation / 2xXeon Quad Core 3,0 GHz, NVidia Quadro 3700, 4Gb RAM / Atto UL-5D SCSI controller with external... [view my complete system specs]
  • Mon, Oct 12 2009 11:08 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,030
    • Points 25,920
    • Moderator: MCA PC
    Thank you all for your replies.
    One further question would be - How about a USB hub?
    Normally it is not recommended to use a dongle on a hub.
    Usually it should be a direct USB connection.
    Or have you been lucky enough to have plenty free USB ports?
    Or even added a USB card with a few extra ports?
    At the moment my MC usb dongle is a direct contact, but I have run out of free USB ports.
    Regards,
    Douglas
  • Mon, Oct 12 2009 1:16 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,822
    • Points 201,035
    I have never had good luck with USB hubs.
  • Mon, Oct 12 2009 1:32 PM In reply to
    • mattman
    • Fort Myers, Florida
    • Posts 119
    • Points 1,570
    Douglas,
    I did run into a problem with another piece of software using a dongle.  All was fine until I updated the software and the driver for the dongle for it.  As I remember, I had to reinstall XP and I went back to the previous version of the software.  After several months a few updated versions of the offending software came out.  One said that they had changed how the dongle worked, so I upgraded and have been fine ever since.  It's dongle was very similar to Avid's and I think I did something when I had to update the driver for it.  (yeah, I wouldn't think would have a driver for a dongle, but that is what my memory is telling me happened.)
    As far as the hub, I used to use a hub all of the time since I couldn't easily get to the back of my computer.  It generally worked.  Sometimes Avid would say that there wasn't a dongle attatched and then I would either unplug the dongle and plug it back in or unplug the hub (either electic or usb) and plug it back in and then it would work.  So, not a big deal if that is what you need to do.  However, your mileage may very as Avid doesn't want you to use a usb hub.  But it did work for me okay.
    Media Composer 3.1.2 - Mojo, Tyan S2676 Motherboard, XP SP3 dual Xeon 3.2, 4 gig ddr2 ram, 4 300 gig Sata drives, raid 5, 3ware 9550SX Sata II controller... [view my complete system specs]
    Mattman Life is good, eternal life is better.
