Latest post Sat, Oct 10 2009 5:30 PM by Larry Rubin. 10 replies.
Page 1 of 1 (11 items)
  • Fri, Oct 9 2009 9:52 PM
    • JMattenley
    • Joined on Fri, Oct 27 2006
    • Ontario Canada
    • Posts 36
    • Points 490
    Dip to color with multiple PIP
    I have three levels of PIP and when I put a dip to color effect on one of the layers the entire screen dips to color.  I just want to edit a talking head together taking out the ums and ahs.
    Xpress Pro HD Studio Complete, Digi002, Mojo, HP xw8200 4GB ram, NVidia 1400 and Avid Media array 2.5 TB [view my complete system specs]
  • Fri, Oct 9 2009 10:09 PM In reply to
    Re: Dip to color with multiple PIP
    You may have to Collapse and Dip to Color.
  • Fri, Oct 9 2009 10:12 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,005
    • Points 107,170
      Moderator: Meridien
    Try "stepping into" the PIP effect on that particular layer (nesting) and add your dip to color transition effect there.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Fri, Oct 9 2009 10:18 PM In reply to
    I was thinking that at first Larry, but then couldn't remember if you can do transitions on nested effects.
  • Fri, Oct 9 2009 10:25 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,005
    • Points 107,170
      Moderator: Meridien
    Yes you can, Kenton, and I've been tripped up by that when I first started nesting and wondered why I wasn't getting the results I wanted in the transition after collapsing layers with transitions nested underneath. I'm not sure this will fade only the PIP like the OP wants, but it's worth a try.
  • Fri, Oct 9 2009 10:58 PM In reply to
    • Sycophant
    • Auckland, New Zealand
    • Posts 1,143
    • Points 13,870
    • Moderator: MCA Mac
    I'd be inclined just to use the 'Fade Effect' tool on that PiP layer - keyframe the Foreground from 100 to 0 over 6 frames or whatever.
    HP XW8600s - Media Composer 3.5.4 - HP XW8400s - DS Nitris 10.1 [view my complete system specs]
    Dylan Reeve - Editor and Stuff
    My opinions are my own.
    Dylan's Templater - Basic Avid project templating tool.
    BatchFuze - MetaFuze batch transcoding tools.
  • Sat, Oct 10 2009 12:28 AM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,005
    • Points 107,170
      Moderator: Meridien
    The OP mentions applying a dip to color transition. I believe fade effect is only capable of fading in from black and fading out to black.
  • Sat, Oct 10 2009 12:43 AM In reply to
    • JMattenley
    • Ontario Canada
    • Posts 36
    • Points 490
    Im sorry I guess I am not explaining it right.  I have a looping background on V1  My PIP interview is on V2.  I need to shorten the PIP interview and was hoping to use the effect of fading to white and then back.  When I do the effect (fade to white or black)  my looping background fades out as well.  I want the looping background to stay visible.
    Thanks for any help.
  • Sat, Oct 10 2009 12:53 AM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,005
    • Points 107,170
      Moderator: Meridien
    OK, then do this. Place the PIP on the entire interview clip. In other words, for the total duration of "tighten ups" that you want to do. Then, step into the PIP effect and place an add edit at the first tighten up point, edit the second clip in and add your dip to color effect there. Continue the process until all tighten ups are complete. Step out of the effect. This should give you the result you want - transitions that won't affect the background layer on V1.
  • Sat, Oct 10 2009 3:43 PM In reply to
    • JMattenley
    • Ontario Canada
    • Posts 36
    • Points 490
    Thanks Larry
    Thats It
    Joe Mattenley, LightSplash Media Inc.  www.lightsplashmedia.com   www.premierevideoproductions.com
  • Sat, Oct 10 2009 5:30 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,005
    • Points 107,170
      Moderator: Meridien
    You're quite welcome, Joe. Glad to help out.
