Latest post Wed, Nov 18 2009 1:49 AM by Aneuploid. 11 replies.
Page 1 of 1 (12 items)
  • Fri, Oct 9 2009 8:56 PM
    Media Creation Settings
    Since upgrading to MC 4.0.2, my media creation settings default to DV25 MXF.  I can manually switch it to whatever I want in the media creation settings, and all is good.  However, as soon as i close the project and open another, it's back to DV25 MXF.
    I uninstalled everything and wiped every remaining Avid related setting off the machine manually.  Re-installed... brought back NO settings or users... opened Avid, started a new project and wham DV25 MXF.
    I've stumped the higher ups at Avid with this one... any ideas out there?  This is not a global issue I'm told, so somehting is up here on my end.
    MC 4.0.2, Nitris DX, 8-Core/2.8ghz Harpertown MacPro, 8 GB RAM, Avid VideoRAID 2.5 TB, 1.5 TB internal SATA Raid [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc FCP2Avid
  • Fri, Oct 9 2009 9:12 PM In reply to
    • Bill Nelson
    • West Coast
    • Posts 714
    • Points 8,130
    Re: Media Creation Settings
    ...and while you're in there Todd, I'll give you twenty bucks to figure out how to REALLY exclude system drives, etc. from the media creation drive list.
    MC v3.5.4 thru SDI Mojo, OS 10.5.8, QT 7.6, on Quad-Core Intel Xeon 2.8 w/8 gig RAM, 2Tb internal RAID volume, 4TB CalDigit HDOne RAID, 30"Display... [view my complete system specs]
    "I scare nothing! Even you become napkins!"
    (english subtitles in Hong Kong kung-fu movie)
  • Fri, Oct 9 2009 10:13 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,834
    • Points 201,175
    I've duplicated this on two different Macs here Todd. I thought the resolution was sticking, but no. Neither the resolution nor the filtering options will stick. Go ahead and escalate this.
  • Fri, Oct 9 2009 10:18 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,001
    • Points 107,120
      Moderator: Meridien
    What happens when you set your resolution and "apply to all", then drag it into site settings? If you quit and re-launch, are the site settings for media creation consistently honored? If not, this is an age old problem that I've been seeing ever since 2.2.3. I haven't had a chance to see whether or not NC 8.0.2 continues to suffer from this, but I'll check it out after we solve some rather peculiar problems we're having with our ISIS/Interplay transition, now in progress.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Sat, Oct 10 2009 12:53 AM In reply to
    Larry,
    My settings are not honored after doing what you said.  Both existing and new projects do not hold the settings across all the tabs in the media creation settings.  As soon as I close a project and re-open it or open another, it reverts back to DV25 MXF no matter what.  This was not an issue for me in MC 3.5 or even in MC 4 beta 1.  In fact if I roll back to MC 4 beta 1, it works as it should.
  • Sat, Oct 10 2009 1:16 AM In reply to
    • janusz
    • Paris
    • Posts 273
    • Points 3,090
    I had a similar issue (MC 4.0.2).  The project settings were not saving (modified date never changes) - be it for the media creation settings or Audio project.  A workaround that worked for me and got them to stick: I deleted the avs file in the project folder.
    Janusz
    MC 3.1.3 / OS 10.5.5 / QT 7.5.5 Mac Pro Octo 2.8GHz 6M RAM/ Mojo SDI [view my complete system specs]
  • Sat, Oct 10 2009 2:05 PM In reply to
    That is typically one of my first troubleshooting attempts janusz.  I'm getting hit with this on newly created projects native to 4.0.2 however, as well as older ones.  I've trashed the .avs file to no avail.
  • Sat, Oct 10 2009 2:12 PM In reply to
    • janusz
    • Paris
    • Posts 273
    • Points 3,090
    What I did was to throw away the avs file, with avid running, click on the settings tab, then save manually.  This worked for me.  Maybe these are two separate issues...
    Janusz
  • Mon, Oct 12 2009 1:53 PM In reply to
    Interesting... I've not tried the .avs thing in that exact manner.  I'll give it a go and let you know if that helps.
  • Mon, Oct 12 2009 3:58 PM In reply to
    Did not work for me unfortunately.
  • Sun, Oct 18 2009 5:03 PM In reply to
    • fiendish
    • Posts 343
    • Points 4,155
    Just found this post after having the same problem on 4.02 on the Mac.
    I found that Januscz's solution worked - I deleted the project's AVS settings file while the project was open and then re-saved. This kept Media Creation and Audio Project settings. This worked for Site Settings too, thank god!
    However, it still doesn't excuse Avid from getting things working properly. Settings not sticking has plagued many versions since 2.5. Sort it out!
    xw8600 Dual Quad 3ghz - MC 3.5.4 / QT 7.6 / Win XP / Vista 64 bit with Mojo SDI - 12gb RAM / Quadro 3500 / 3700 and 3ware 9650SE Raid 5 [view my complete system specs]
  • Wed, Nov 18 2009 1:49 AM In reply to
    • Aneuploid
    • Joined on Wed, Nov 18 2009
    • Posts 1
    • Points 5
    Has this been fixed in version 4.0.3? In the bug fixes of the 4.0.3 release notes it lists this: "Bug Number: UDevC00129784. If you made a change to a User setting and then closed the project, the User setting change would not stick. This has been fixed."
