Latest post Sun, Oct 18 2009 12:34 AM by MichaelP. 3 replies.
  • Thu, Oct 8 2009 6:29 PM
    • Fish
    • Joined on Sat, Oct 15 2005
    • Filet Post, Halifax NS
    • Posts 170
    • Points 2,085
    Feature request
    Love the program. In the next incarnation...
    • an option to creat a fast SD version (i.e. DV25 or 2:1) of a Red Clip...to help speed up the rushes part of the process
    • an option to save all the perferred settings, perhaps muliple/favourite versions of those settings, to be applied as a batch to the next project. If there's a way to do that now I don't see it.
    Thank you!
    MACINTEL, 4 gig ram, AVID Raid [view my complete system specs]
    ><({(º> AVID man, AVID fan (since 1993 with version 4.5 - before multiple tracks!)...like to solve my own problems and I try not to bother anyone unless I'm really stumped.
  • Tue, Oct 13 2009 1:51 AM In reply to
    Re: Feature request
    Frame rate is one problem with the SD approach.
    Whether you're working in 25fps or 29.97fps your RED footage is likely to be shot at 24fps or 23.98fps.
    In N. America for example that means that you have to use 3:2 pulldown in the MXF footage. This is all fine, Media Composer can deal with it superbly but it just adds another layer of complexity to an already complicated process.
    Add pulldown, remove pulldown, etc. It increases the margin of error.
    Igor Ridanovic
    www.HDhead.com
  • Tue, Oct 13 2009 2:43 AM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 353
    • Points 3,945
    • Moderator: Avid DS
      Moderator: MetaFuze
    Re: Feature request
    But you can already work with SD 23.98 footage in MC, so it should be available in MetaFuze as well.
    "There are no rules for the brave". Albert Einstein
  • Sun, Oct 18 2009 12:34 AM In reply to
    • MichaelP
    • Boston
    • Posts 1,751
    • Points 21,670
      Moderator: Film
      Moderator: MetaFuze
    Re: Feature request
    This is also on the list - it is not a matter of actually creating media with pulldown only to remove it - but a metadata change to make it think it "had" pulldown and PAL or NTSC timecode. MetaCheater has this feature via ALE, but doing it via MXF wrapped DNxHD takes a little more work.
    Michael
    HP 8600 Symphony Nitris DX v4 || MBP 15" Media Composer v4 [view my complete system specs]
    ____________ Anything 24fps
