Latest post Sun, Oct 18 2009 1:02 AM by AndrewAction. 10 replies.
Page 1 of 1 (11 items)
  • Thu, Oct 8 2009 6:24 PM
    • Fish
    • Joined on Sat, Oct 15 2005
    • Filet Post, Halifax NS
    • Posts 170
    • Points 2,085
    Metafuze colour settings
    Pretty sure I know the answer to this..but there isn't a way to accidentally effect the luminance value of a Red shot when its being transcoded by Metafuze, is there?
    The MXF results  are pretty dark and before I go accusing the DOP of being too careful in his exposure I want to make sure something isn't going "wrong" on my end.
    MACINTEL, 4 gig ram, AVID Raid [view my complete system specs]
    ><({(º> AVID man, AVID fan (since 1993 with version 4.5 - before multiple tracks!)...like to solve my own problems and I try not to bother anyone unless I'm really stumped.
  • Thu, Oct 8 2009 6:59 PM In reply to
    Re: Metafuze colour settings
    First of all, when transcoding RedSpace to Rec709, you get a pretty dull picture. It may appear underexposed, but that is because of the conversion.
    If you need to have something that more accurately resembles whatever was intended, you can either add a color correction in the Avid editor, or you can use an application like RedAlert to create an RLX file, which you may use in MetaFuze as a "grade" (with curves, color temp, etc). Alternatively, you might want to run the R3D files through BaseLight or Scratch in order to get an actual one-light-type transfer.
    Would be great if we could use custom LUTs in MetaFuze with R3D. Not yet, though.
    Symphony Classic Nitris 4.0.2 on 2x 2.33 quad core XW8400/8GB Vista Biz 64bit | MC 4.0.2 on 2x dual core 2.66 XW8400/7GB Vista Biz 64bit | Mojo SDI | Unity... [view my complete system specs]
  • Thu, Oct 8 2009 8:02 PM In reply to
    • Fish
    • Posts 170
    • Points 2,085
    Excellent reponse. Next time I will set up a grade first. Thank you.
    And as far as features...I'm not looking to save colour settings but rather the reams of settings from the "details" panel. Something I could set up and then smack onto a series of clips without a lot of fuss.
    For instance my latest batch is 246 clips. Every adjustment takes a bit of tiem for it to ripple through Yet it's always the same settings...(same destination folder, same codec, same size, same frame rate, same project name, etc.)
    Thanks again..
  • Tue, Oct 13 2009 3:13 AM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 353
    • Points 3,945
    • Moderator: Avid DS
      Moderator: MetaFuze
    With the latest version, you can select all transcodes"Cntr-shift-A" and change the settings in one go. No need to set the values over and over again. It usually takes me under 30 seconds to setup transcodes for 200+ clips. You can load in an RLX in the same manner for all 200 clips or selections of.
    "There are no rules for the brave". Albert Einstein
  • Tue, Oct 13 2009 7:19 AM In reply to
    I think Fish means that if you have a certain default setup for a project, and you get dailies in every day, one would like to be able to apply all settings for that project to the each new batch.
  • Tue, Oct 13 2009 3:32 PM In reply to
    • Fish
    • Posts 170
    • Points 2,085
    Yup..that's exactly what I mean. And that's exactly what has been happening. If I could set up templates (like Render settings in After effects or Import/export settings in the Avid) where I could choose a pre-selected set to apply to everything...it would save a whack of time and remove the possibility of forgetting something entirely. Such was the case when I forgot to apply the correct DNX setting on my last overnight batch and the results pretty much useless to me.
  • Wed, Oct 14 2009 3:55 AM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 353
    • Points 3,945
      Moderator: MetaFuze
    That would be a good option. I'll mention it to the devs.
  • Fri, Oct 16 2009 9:22 PM In reply to
    • ManChicken
    • Joined on Mon, Feb 4 2008
    • Denver, CO
    • Posts 78
    • Points 970
    • Moderator: MetaFuze
    It's like the workflow should be reversed;  Rather than putting clips in Metafuze and adding a transcode for each one, we should instead create be creating a transcode job and adding the clips to it.
  • Fri, Oct 16 2009 9:57 PM In reply to
    ManChicken:
    I would second that.  Add the ability to save those transcode settings as templates and we would be smokin
    Thanks for the continued dongle support
  • Sun, Oct 18 2009 12:28 AM In reply to
    • MichaelP
    • Boston
    • Posts 1,751
    • Points 21,670
      Moderator: Film
      Moderator: MetaFuze
    We certainly have discussed that - one of the main reasons it is the way it is now it to allow different encode jobs to be sent to different CPU's in a render farm.
    Michael
    HP 8600 Symphony Nitris DX v4 || MBP 15" Media Composer v4 [view my complete system specs]
    ____________ Anything 24fps
  • Sun, Oct 18 2009 1:02 AM In reply to
    MichaelP:
    Maybe make it possible by having a render farm option of MetaFuze and a second UI that uses template transcode options for the one job at a time town folk.
    I appreciate that it is currently free software. The time savings for ME with a template option would be worth paying for.  Smile
