Latest post Tue, Oct 13 2009 11:28 PM by drbgaijin. 10 replies.
Page 1 of 1 (11 items)
  • Thu, Oct 8 2009 6:06 PM
    Trim Multiple Clips at the Same Time?
    I have a sequence w/ ten clips that I'd like to single roller trim to about one half of their original lengths.
    I don't care if they are trimmed on the incoming or outgoing side, b/c they are actually still images. So the image is static and does not change during each clip.
    I know I can go into Trim Mode and do this for each clip individually, but I'm wondering if there is a way to do it en masse, as I'm probably going to be running into this a fair amount.
    Thanks much. :)
    P4 3.0. 4 Gig RAM, CAS 2.0. 3Gig patch. Intel 865PERL mobo. Two WD 7,200 IDE drives. SIIG SATA II-150 PCI RAID card w/ 2 WD Raptor 10,000 SATA drives as... [view my complete system specs]
  • Thu, Oct 8 2009 6:49 PM In reply to
    Re: Trim Multiple Clips at the Same Time?
    BobbyMurcerFan:
    Not a trimming answer but you can set the duration of all your selected stills in a bin (in script view) before you add them to the timeline.  You can also set your mark in any distance into the clip you want so you will have media for transitions if needed
    I think I would use go to next edit. Keyboard to advance the duration I wanted. Mark in. Go to next edit and mark out. Cut. Repeat rather than trim mode if the timeline was already set up.
    Thanks for the continued dongle support
  • Thu, Oct 8 2009 7:13 PM In reply to
    • sasfog
    • Bristol United Kingdom
    • Posts 185
    • Points 2,220
    Not at my system right now but can't you just lasso all the clips while in trim mode and then select trim left or right and go from there.
    Would only take a few seconds if it works and obviously will only achieve the effect you want if all the clips are of similar lengths to begin with.
    Graham
    Pentium 4 3.4 GHZ ASUS P4P800 2GB DDR SDRAM PC 3200 80GB 7200RPM Hard Drive NVIDIA GEFORCE FX5200 128MB AGP Graphics MC 3.1.3 with Mojo (not SDI)... [view my complete system specs]
  • Sat, Oct 10 2009 9:25 PM In reply to
    Unfortunately (for what I'm tyring to do) it seems that selecting multiple clips and then entering Trim mode just place the trim rollers at the beginning of the first clip and at the end of the last clip, and only those two clips can be trimmed.
    But thanks for the suggestion.
  • Sat, Oct 10 2009 9:29 PM In reply to
    You could use the Top or Tail buttons to do quick trims.
    Park wherever you'd like to trim to, hit Top and it'll trim off the "top" of the clip to the point you're parked at.  Hitting Tail, will trim the tail... brilliant.
    you'd still have to move through the sequence and do each clip one by one, but at least it's only 1 button click and  a mouse move.
  • Sat, Oct 10 2009 11:30 PM In reply to
    Kenton, Thanks for the suggestion ;).
  • Mon, Oct 12 2009 6:46 PM In reply to
    • Joachim Claus
    • Seeheim-Jugenheim, Germany
    • Posts 187
    • Points 2,265
    there is a method to change all marked clips in a bin at the same time. See here
    http://community.avid.com/forums/post/406138.aspx
    Joachim
    SuperMicro Workstation 7046A-3 Dual Xeon (Quadcore) X5550 2.67GHz 12 GB RAM PNY FX1700 Soundblaster Audigy 2 ZS Pro 4 SAS HDD's 300GB 15k (1 for OS... [view my complete system specs]
    Joachim Claus
  • Mon, Oct 12 2009 7:46 PM In reply to
    • redsnapper
    • London, UK
    • Posts 38
    • Points 460
    Type +10:00 in the composer monitor and hit enter to advance 10 seconds. Then use trim to tail to cut the rest of the clip off. The great thing is the Avid remembers the +10 and all you have to do to repeat the jump forward is to hit enter again. If all your clips are next to each other you then just have to hit enter followed by the trim to tail button over and over. Easy.
  • Mon, Oct 12 2009 11:03 PM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,035
    • Points 26,005
    • Moderator: MCA PC
    redsnapper:
    Don't forget this:
    Regards,
    Douglas
    (AMC MojoDX 3.1.2 - XP Pro SP2) + (AMC MojoDX 4.0.2 Vista64 Business SP1),ASUS PK5 DEluxe/WiFi-AP CH1-14 Mobo,Intel Core 2 Duo E6850 (3GHz)8GB Corsair... [view my complete system specs]
  • Tue, Oct 13 2009 11:22 PM In reply to
    • redsnapper
    • London, UK
    • Posts 38
    • Points 460
    Yes if you are marking in and outs from the source monitor that can be a problem but if you follow the method I posted using the trim to tail command the extra frame is not a problem.
  • Tue, Oct 13 2009 11:28 PM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,035
    • Points 26,005
    • Moderator: MCA PC
    redsnapper:
    Thank you Tones.
    I didn't know that  Yes
    Regards,
    Douglas
