Latest post Thu, Nov 5 2009 2:08 AM by David MO. 8 replies.
Page 1 of 1 (9 items)
  • Thu, Oct 8 2009 3:42 PM
    • aimie_rcp
    • Joined on Fri, Nov 21 2008
    • Posts 14
    • Points 210
    MC 4.0.2 - cannot export Quicktime Reference?
    I'm getting the following error message.
    Exception: QuickTime reference exports cannot be performed on clips linked via AMA or on sequences containing media linked via AMA
    How do I fix this?
    Thanks.
  • Thu, Oct 8 2009 4:22 PM In reply to
    • outpostbc
    • Joined on Tue, Feb 21 2006
    • Lenexa,KS
    • Posts 279
    • Points 3,425
    Re: MC 4.0.2 - cannot export Quicktime Reference?
    I think you can do a mixdown or consolidate of media to get around this. I would try the mixdown first.
    Media Composer Nitris DX 4.0.2 Dual 3GHz Mac Pro 4GB Ram 10.5.7, Symphony Nitris DX 4.0.2 Dual 3GHz Mac Pro 4GB Ram 10.5.7, Unity MediaNet 5.1.3 [view my complete system specs]
  • Thu, Oct 8 2009 5:20 PM In reply to
    • aimie_rcp
    • Posts 14
    • Points 210
    Hm, I'll give it a shot. Though this worked fine in the previous version of MC.
  • Thu, Oct 8 2009 5:39 PM In reply to
    • outpostbc
    • Lenexa,KS
    • Posts 279
    • Points 3,425
    Not sure if it worked in the past or not, I always do a consolidate prior to exporting or going out to tape.
  • Thu, Oct 8 2009 5:44 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,822
    • Points 201,035
    What type of media is this? If it's Long GOP, you can't export a QT ref. It's not supported in QT.
  • Thu, Oct 8 2009 6:17 PM In reply to
    • aimie_rcp
    • Posts 14
    • Points 210
    It is P2 media. I've been working with P2 media for a while, and I have always been able to export a QT Ref from Avid, but I just upgraded to MC 4 and I suddenly get this error message.
  • Thu, Oct 8 2009 6:43 PM In reply to
    • Bill Nelson
    • West Coast
    • Posts 713
    • Points 8,115
    ...if so, this is an undesirable development.
    MC v3.5.4 thru SDI Mojo, OS 10.5.8, QT 7.6, on Quad-Core Intel Xeon 2.8 w/8 gig RAM, 2Tb internal RAID volume, 4TB CalDigit HDOne RAID, 30"Display... [view my complete system specs]
    "I scare nothing! Even you become napkins!"
    (english subtitles in Hong Kong kung-fu movie)
  • Thu, Oct 15 2009 4:32 PM In reply to
    • wil
    • Quebec
    • Posts 43
    • Points 500
    I got into the same situation. It seems that if you don't consolidate all your source clips, you won't be able to export QT references... evev if they are on the same drive... so the new P2 workflow would be as follows (it seems to be the same as before, only the names have changed!):
    -Copy your P2 cards in folders on your drive
    -Link to your P2 card or folder with AMA
    -consolidate all the clips, making sure you deselect "skip media files already on the target drive", and select "Relink master clips to media on the target drive".
    You can then delete all those "yellow" clips, and you'll then be able to work normally with your clips.
    If anyone found an easier way of doing this please share!
    HP xw4400 4 GB of RAM NVidia Quadro fx1500 80 GB 7200 RPM internal drive 250GB 1394 External drive [view my complete system specs]
  • Thu, Nov 5 2009 2:08 AM In reply to
    • David MO
    • Joined on Mon, Apr 27 2009
    • Posts 21
    • Points 220
    The smoothest work around we use for EX XDCAM (and I assume its the same as other long GOP stuff) is as follows
    Edit away till yor heart is content from AMA folders
    When you are ready to export:
    Do an Audio and Video mix down and use a NEW  sequence to export these newly created streams to QT ref. It all works well assuming you are not using long GOP in the mix down codec options.
    Thats it! Works a treat.
    What should be able to be done in my opinion is use the original sequence and just turn off the tracks that contain the media that MC and QTime have the problems with and only leave the mix down Video and Audio turned on. this would allow a tidy consolidate later on when definately complete. This worked early in 3.5, but option desappeared in 3.5 patches somewhere and has not returned with V4 either.  Hopefully it will come back sometime soon.
