Latest post Mon, Oct 12 2009 7:39 AM by mjolnarn. 36 replies.
Page 3 of 3 (37 items) < Previous 1 2 3
  • Sun, Oct 11 2009 12:07 PM In reply to
    • NubusAvid
    • Joined on Fri, Mar 3 2006
    • Kent U.K.
    • Posts 128
    • Points 1,465
    Re: No Filler created in 4,02
    A feature?
    Definitely no T-shirt for Tomas.
    MCA 4.02 DNxHD card Macpro Quad 3Ghz 3Gb Ram Apple Fibrecard Infotrend 15Tb Sata raid 5 Fibre chassis. Panasonic TH-50PF9UK Monitor Yamaha 03D Mixer... [view my complete system specs]
  • Sun, Oct 11 2009 1:04 PM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,035
    • Points 26,005
    • Moderator: MCA PC
    Yes, David,
    That's what I said in the 2nd post in this thread - no T-shirt Sad
    In all fairness to Tomas he has seen something that could bother any of us if we happened to use the same setting as he did.
    I am just now uploading a short Video summary of the phenomenon.
    It will be posted in this reply shortly!
    Now it is "shortly"
     My guess is that when anyone chooses to "show effect contents", then the V2 track turns black and the "Filler" text, which is also black, disappears (camoflage!")
    Regards,
    Douglas
    PS Big Smile Did I hear someone shout , "Give that Video producer a T-Shirt!!! "
    (AMC MojoDX 3.1.2 - XP Pro SP2) + (AMC MojoDX 4.0.2 Vista64 Business SP1),ASUS PK5 DEluxe/WiFi-AP CH1-14 Mobo,Intel Core 2 Duo E6850 (3GHz)8GB Corsair... [view my complete system specs]
  • Mon, Oct 12 2009 5:28 AM In reply to
    • smyers63
    • Joined on Thu, Feb 16 2006
    • Dallas, Texas area
    • Posts 2,854
    • Points 33,650
    • Moderator: MCA PC
     Douglas,
    I'd go as far as sending you 2 shirts in trade for your DX.  I'll put a couple of shirts in the mail to you and watch for the DX in a few days.  Big Smile
    So, this is apparently usual behavior and operator error instead of really being isolated to 4.02.  I think it's important to put the answer in text in the thread in case the video isn't accessible to folks who read the thread later.
    Sys. 1: ECS C51GM-M motherboard, Athlon 64 X2 3800+ (2GHz), 4GB RAM, XP Pro SP3 or Windows 7 beta (64-bit) on separate boot drives, XFX 8800GT 512MB PCIe... [view my complete system specs]
  • Mon, Oct 12 2009 5:53 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,035
    • Points 26,005
    • Moderator: MCA PC
    smyers63:
    I am sure you would, Scott Geeked
    smyers63:
    Hopefully, as long as Avid is around the video will be accessible, BUT....... you never know.
    My text version.
    As seen on 3.1.2:
    With DEFAULT SETTINGS!
    Create a blank track (The track will either be gray, or whatever colour you have chosen for it)
    Place the 3D effect on a blank track (e.g. V2) on the time line.
    A filler is created.
    It can be on any track height and always visible as a filler.
    It can be trimmed and moved.
    Change the DEFAULT SETTINGS:
    Go into "Settings", "Time line" and check the "Show Effect Content" box
    Create a blank track (The track will be black with a horizontal central line) (I don't remember if it is black before you add the effect or not. Don't have MC running just now)
    Place the 3D effect on the blank track (e.g. V2) on the time line
    A filler is created BUT IT IS NOT VISIBLE because, as I understand, the track is black and the word, "FILLER" is black. So you cannot see the text.
    If you use the CTRL+K keys to decrease the height of the V2 track.. the word "FILLER" will become visible eventually, as it will change colour!
    If you go into trim mode, you can use the rollers to trim the black area.
    If you then move the trimmed clip along the time line, the "FILLER" text changes colour and is visible as you drag.
    This is in MC 3.1.2
    Anyone notice the same in MC 4.0.2?
    If this is the case in both versions...... then the lesson is beware of changing the defaults if you are not sure what will happen.
    My goodness Scott, it took me as long to write all of that as it did to make the video!
    1 picture is worth 1000 words......
    Big Smile
    Now I will sit back and see if MC 4.0.2 is working the same as I described........ or if I am completely off target.
    If it is correct, I would like to thank AndrewAction and BLKDOG for bringing the line in the middle of Tomas Track to my attention.
    Regards,
    Douglas
  • Mon, Oct 12 2009 7:09 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 3,108
    • Points 35,510
    Yes, this seems to be the fact with all versions of Media Composer, turning effect viewing on and the filler will not be visible with a track height above a certain size.
    I qoute myself from an earlier post
    " Matt, all works as it is supposed to, but no filler is created, just the effect icon into the middle of an empty track.
    Some other effects are creating fillers, this is strange.
    Hopefully someone is able to reproduce this, I see no logical difference between effects that creates fillers and those that doesn´t"
    One question explained, another one still to be answered, why does, for example, the Avid Fx editor or any of the reformat editors always create visible fillers, if this is a feature, it should affetct all filters in the same way, as it doesn´t , it seems to be closer to a bug than a feature ...
    MC 4,03 ( Liquid 7,2 ) V 64 Ultimate Mbo gigabyte 965-DQ6,cpu quad core QX 6700, mem Corsair Dominator 8500 8 GB, PNY Quadro 1800, Soundblaster X-Fi... [view my complete system specs]
    Tomas
  • Mon, Oct 12 2009 7:27 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,035
    • Points 26,005
    • Moderator: MCA PC
    Tomas,
    2 straight simple questions:
    1. If you have the "Show Effect Content" box unchecked, do you see examples of filters that DO NOT(as you say) create fillers.
    2. If you have the "Show Effect Content" box checked, do you see any examples of filters that DO create fillers?
    I still believe that FILLERS are being created in all cases.  BUT because of the text colour being the same as the background you cannot see the words!
    If you can see the word "FILLER" then either the track is not black, or the text is not black.
    Let's wrap up this thread with final words from all who have something to say and then, Tomas, start a new thread with your new line of query.  GeekedYes
    Regards,
    Douglas
  • Mon, Oct 12 2009 7:39 AM In reply to
    • mjolnarn
    • Sweden
    • Posts 3,108
    • Points 35,510
    "I still believe that FILLERS are being created in all cases.  BUT because of the text colour being the same as the background you cannot see the words!"
    Yes, this seems to be a correct summarize
    "If you have the "Show Effect Content" box checked, do you see any examples of filters that DO create fillers?"
    Yes, as described doing a very fast test without analyzing to much, both the Avid FX editor and the effects inside the reformat folder are always creating visible fillers, no matter what size or setting for the sequense
    Tomas
