Latest post Sat, Oct 3 2009 5:01 PM by drbgaijin. 2 replies.
  • Sat, Oct 3 2009 1:29 PM
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,042
    • Points 26,080
    • Moderator: MCA PC
    That Puzzling Extra Frame!
    After I migrated to Avid Media Composer, I spent about 4 weeks happily and unknowingly adding an extra frame to my clips!
    It was really by accident that I discovered my error.
    Here is an explanation of my error and why it was happening.
    After you understand the error, the solution is simple.
    Regards,
    Douglas
    This tutorial can be viewed at "Full-screen" by clicking on the icon on the toolbar
    (AMC MojoDX 3.1.2 - XP Pro SP2) + (AMC MojoDX 4.0.2 Vista64 Business SP1),ASUS PK5 DEluxe/WiFi-AP CH1-14 Mobo,Intel Core 2 Duo E6850 (3GHz)8GB Corsair... [view my complete system specs]
  • Sat, Oct 3 2009 4:31 PM In reply to
    Re: That Puzzling Extra Frame!
    Douglas, that's a pretty good explanation - however, I think one thing you may have omitted is that when you're zoomed in and see the solid line and dotted line.  If you press I and O at the same point you will see the marks surrounding that one frame.  So the In and Out can never be less than 1 frame.  The dotted line is always the Out point.
    Similarly in film, each strip of film is made up of frames.  In your example, you want a a strip of 5 frames, but in order to include that 5th frame you must move to the head of the 6th.
    So, the counting of frames is that the In point assumes the head of the frame.  Your Composer window will always display the incoming head frame wherever you are parked.  Marking Out will always assume the tail of the frame.
    Graphically,   |A|B|C|D|E|  (6  In point possibilities, 5 total frames) Notice that if you were to park at the head of B, you're also parked at the tail of A.  But, if you mark In/Out while parked at B, it'll mark surrounding B.  Cutting |B|, would result in |A|C|D|E|  (5 In point possibilities, but only 4 total frames)
    If you don't have a filmstrip that you can look at, you can use a roll of paper towels to understand the logic.
  • Sat, Oct 3 2009 5:01 PM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,042
    • Points 26,080
    • Moderator: MCA PC
    Kenton,
    First of all thanks for the extra information.
    It gives viewers/readers more things to think about.
    Kenton.VanNatten:
    Actually I did notice that when I was running through what I wanted to include. I almost included it, but I thought it wasn't necessary.
    Too bad you are not a mind reader and could have sent me this before I did the Tutorial Big Smile
    Maybe next time?
    Regards,
    Douglas
