Latest post Tue, Oct 6 2009 11:28 PM by drbgaijin. 4 replies.
  • Sat, Oct 3 2009 3:51 AM
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,035
    • Points 26,005
    • Moderator: MCA PC
    Deleting a Clip - Revisited
    When we are learning something new and we succeed, we tend to remember the success.
    Next time we are back in the same situation we usually use the same method that we first succeeded with.
    Even with Media Composer - when you first delete a clip successfully, you tend to continue using the same method in the future.
    Sometimes, however, there are other ways of achieving the same success.
    Sometimes the other ways may be more suitable for deleting a clip under different circumstamces.
    Here is another way of deleting a clip that I came upon recently.
    Regards,
    Douglas
    This tutorial can be viewed at "Full-screen" by clicking on the icon on the toolbar
    (AMC MojoDX 3.1.2 - XP Pro SP2) + (AMC MojoDX 4.0.2 Vista64 Business SP1),ASUS PK5 DEluxe/WiFi-AP CH1-14 Mobo,Intel Core 2 Duo E6850 (3GHz)8GB Corsair... [view my complete system specs]
  • Mon, Oct 5 2009 3:47 AM In reply to
    • iedjie
    • Posts 139
    • Points 1,625
    Re: Deleting a Clip - Revisited
    Hi Douglas,
    why actually hold down CTRL when you press X to delete a clip? Just X gives the same result.
    iedjie
  • Mon, Oct 5 2009 6:54 AM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,035
    • Points 26,005
    • Moderator: MCA PC
    iedjie:
    Hi Douglas,
    iedjie
    A good question, Iedjie
    My answer is below,
    Regards,
    Douglas
  • Tue, Oct 6 2009 2:58 AM In reply to
    • iedjie
    • Posts 139
    • Points 1,625
    I never use that method, great! Or I put marks, or I press backspace/delete to delete a segment(s) when I'm in lift/overwrite mode. Thanks a lot. You support to the forum is outstanding!
    When you mark clips, you can also press alt-x or z. In that case it loads it into the sourse monitor at the same time. Does that happen too in the lift/overwrite mode? I'm not behind an avid machine right now.
    Once, Scott Carnegie posted a very nice list of tips here. As there are many different approaches in avid that end up having  the same result, I intend to develop a certain way of working and getting used to it. It would be good for me to read these tips again once in a while!
    I'll include a PDF of them,
    iedjie
    [EDIT]
    I'm reading the tips right now. The answer is Ctrl-Alt-c.
    12. In the timeline, when you select a clip and press ctrl and alt and c, it will copy the clip to the clipboard and automatically load it into the source monitor
  • Tue, Oct 6 2009 11:28 PM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,035
    • Points 26,005
    • Moderator: MCA PC
    Iedjie,
    I didn't see your PDF at first.
    Now I have downloaded it and will take a look.
    HERE is another Tutorial with some information about loading clips into a new pop-up window.
    Regards,
    Douglas
