Latest post Thu, Oct 15 2009 3:06 PM by GusC. 7 replies.
  • Thu, Oct 1 2009 10:26 AM
    • lateral
    • UK
    • Posts 126
    • Points 1,525
    Stabilize
    I'm using the stabilize effect on a shot, simple 1point track and seems to work well.
    But when I switch back to Output the result is half off of the screen and I then have to move the shot back to the middle, is this normal? Am I missing something obvious?
    I support, use and own various systems. [view my complete system specs]
    Eddtheditor
  • Thu, Oct 1 2009 11:46 AM In reply to
    • M-Edit
    • Joined on Thu, Jan 29 2009
    • Posts 60
    • Points 730
    Re: Stabilize
    Are you holding down Ctrl when you're positioning
    the tracker, ie. trackers?
    Because when you hold down Ctrl both the reference
    and layer trackers are positioned at the same point.
    My guess is that you're only moving the reference
    tracker to the point you want to be stable.
    I don't know which DS version you're on but check
    out "Using the Stabilizer in the Effects Tree" either
    in the Help or in "da thick book".
    Page 238 in the DS10 manual.
    Good luck!
    //mike
  • Thu, Oct 1 2009 12:07 PM In reply to
    • lateral
    • UK
    • Posts 126
    • Points 1,525
    Re: Stabilize
    Ah, makes sense, i'm not holding Ctrl, sounds like the problem.
    Thanks mike, forums are great Big Smile
    Eddtheditor
  • Sun, Oct 11 2009 7:11 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 472
    • Points 5,820
    Re: Stabilize
    The CTRL comment is probably where you need to start.
    But also realize that any stabizied shot wil start showing the edges of raster at the points where the stabilizing was most severe.  So the resultant image may need to be resized / repoed to work in your situation.
    And the highest quality way to do that is to add a translate node to the Global input of the stabilize effect.  This way you are just adding math to the process and only "passing through the DVE" once.  This will give a better looking image rather than adding a second DVE after the stabilizer to repo the result.
    Hope that makes sense.
    Jef
    MC 3.1.3 Mac Dual 2.8 8core ATI2600 OS 10.5.7 QT 7.6 10 GB ram 2xSATA software raid local storage [view my complete system specs]
  • Wed, Oct 14 2009 5:09 PM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 353
    • Points 3,945
    • Moderator: Avid DS
      Moderator: MetaFuze
    Re: Stabilize
    The Stabilizer has a built in DVE tab, no need to add a second one after.
    "There are no rules for the brave". Albert Einstein
  • Wed, Oct 14 2009 10:58 PM In reply to
    • jef
    • Maryland
    • Posts 472
    • Points 5,820
    Re: Stabilize
    True.  I tend to use the Transform nodes.  Same quality. Personal preference.
    Jef
  • Thu, Oct 15 2009 7:13 AM In reply to
    • M-Edit
    • Posts 60
    • Points 730
    Re: Stabilize
    Jef or mrmikster, could you please shed some
    light onto when to use a tranform node in
    preference of the actual DVE's own transformation
    controls? Except for the obvious use of it as
    a multi-DVE transform controller.
    I feel I've missed out on something when it comes
    to dealing with this. In certain circumstances I've
    noticed a quality improvement using a transfrom
    node but I don't think I've grasped the general
    idea.
    //mike
  • Thu, Oct 15 2009 3:06 PM In reply to
    • GusC
    • Burbank, CA
    • Posts 363
    • Points 4,380
    Re: Stabilize
    I tend to use transform node instead of the DVE in the stabilizer/tracker.  Again, that is merely a personal preference.  I just like to know that my stabilize is my stabilize, and that my additional repos are separate.
