Latest post Wed, Sep 30 2009 7:46 PM by luces umbrarum. 9 replies.
Page 1 of 1 (10 items)
  • Tue, Sep 29 2009 5:39 PM
    How to batch an entire project's offline media?
    Hello.
    Once again my employer had the wonderful idea of having full access to an older project, whose media files have been deleted on some time ago.
    I still have the project of course, but during the batch capture of the DV tapes, I get the message, that capturing has to be aborted due to lack of timecode, which is understandable, as the tape has reached its end, but I don't get the option to keep the media. (I also get the error message with "not enough samples", and I still can't save any digitized media).
    I have 40 tapes to digitize, 30 DV and 10 Digi Beta, and as the project is a multicam project, it would be easier to just batch digitize the tapes.
    But how can I avoid the dreadful message at the end of a tape, which gives me no option to keep the media already captured?
    I don't want to regroup everything.
    Thanks in advance for any input.
    Avid 1: PowerMac G5, Avid MC 2.8.3, EditShare, Mac OS 10.4.11 Avid 2: MacPro, Avid MC 3.1.1, EditShare, Mac OS 10.5.5 Avid 3: MacBook Pro, MC 3.1.1, Mac... [view my complete system specs]
  • Tue, Sep 29 2009 5:52 PM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 474
    • Points 5,830
    Re: How to batch an entire project's offline media?
    I have been through recently with  a client.
    First backup your project in a safe place!
    You need to modify your master clips.  You want to modify the out timecode by using the decrement tool in modify.  This will make the master clip shorter, therefore letting the Avid stop before you run out of code on the source tapes.
    Jef
    MC 3.1.3 Mac Dual 2.8 8core ATI2600 OS 10.5.7 QT 7.6 10 GB ram 2xSATA software raid local storage [view my complete system specs]
  • Tue, Sep 29 2009 6:11 PM In reply to
    Thanks.
    I almost thought of this, but the last time it didn't work.
    I also get an error message at the same TC on one tape (I'm only in three tapes).
    I doesn't occur at the end, it occurs at 34:20:xx with the out point/mark at 44:03:21.
    The message is the following:
    Halted on clip 'Tape 500 D.02'.
    Exception: ADVAudioDev: Calculation error - not enough samples
    Number of clips remaining to re-capture: 1 (The one I want to capture three times now.)
    Do you want to continue?
    TRY AGAIN   ---   SKIP CLIP   ---   SKIP TAPE   ---   ABORT.
    No other options there.
    If I try again, I get the same error again and again.
    I'll try another tape for now.
  • Tue, Sep 29 2009 8:24 PM In reply to
    • jef
    • Maryland
    • Posts 474
    • Points 5,830
    Is this the same system that captured the tapes before?
    By same I mean -
    Same VTR?
    Same Avid system?
    Same settings?  ( here I mean in the capture settings are the set the same - capture accross TC breaks, etc.)
    What I say next is NOT yelling at you, but something to think about.
    When capturing material, never take the easy way out and just capture the whole tape without logging.  You can create a situation like this.  Logging and then capturing with a documented workflow guarantees that the material can be recaptured later.
    So you task is to try and get as close to the original setup.
    Good luck,
    Jef
  • Tue, Sep 29 2009 9:35 PM In reply to
    I'd suggest you decompose the sequence, with very long handles if needed, and then batch in the .new clips in a shorter manner.  This should help you avoid the long clip/end of tape issue for the most part.
    MC 4.0.2, Nitris DX, 8-Core/2.8ghz Harpertown MacPro, 8 GB RAM, Avid VideoRAID 2.5 TB, 1.5 TB internal SATA Raid [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc FCP2Avid
  • Wed, Sep 30 2009 12:26 PM In reply to
    I thought about this too already for my future habits, about logging.
    It is not the same Avid system (MC 12 then, MC 3.1.1 now) and not the same resolution.
    The material was captured in 20:1 OMF then, now I want to capture it in DV 25 4:2:0 and the Beta material in 10:1.
    The VTR was a big DV Cam tape deck, now I use smaller DV cameras via Firewire instead of SDI.
    I don't have access to the older system anymore, as it was replaced with the newer system.
    I also tried to decrement the timecode, as suggested earlier, but Avid won't let me do it in the end.
    "The clip(s) you have selected could not be modified.
    1 is a master clip and could not be modified by this operation unless unlinked."
    I also tried the unlink method described in the help section, but I couldn't unlink the material, as the unlink option didn't become active in spite of every resolution I picked or equal option I choose.
    No I just thought about just batch capturing the groups, but I would have to change tapes a lot, as there are around 100 groups.
    Is there any way to use a tool like media tool to find sub-clips used for the groups, so I can select them tape-wise, and just put in one tape after another?
    Thanks for any help given already.
    EDIT:
    It works selecting the groups and then Batch Capture its material.
    I sometimes get the message of conflicting sample rates, but I just have to switch then, back and forth, as the cassettes have different sample rates.
    But the more prominent error is the one I mentioned earlier, this time with another tape.
    Halted on clip 'Tape 510'.
    Number of clips remaining to re-capture: 1 Do you want to continue?
    TRY AGAIN   ---   SKIP CLIP   ---   SKIP TAPE   ---   ABORT. Is there any way to get by this message?
  • Wed, Sep 30 2009 5:03 PM In reply to
    • jef
    • Maryland
    • Posts 474
    • Points 5,830
    Unlinking:
    There is a very wierd combination of keys used to unlink a clip.  You have to search help for it.  This is becuase it is dangerous.  Not sure from your comments if you tried / found that combo.
    Capture error:
    I have never seen that one before.  Just curious.  In your capture settings, do you have "capture with clip settings" enabled or disabled?  (rough paraphrase on menu names here - not in front of MC)  I am wondering if the system sees one sample rate on input but your master clip info says it should be another one.  I would say make sure that your current settings override all clip settings.  Then make sure your current settings REALLY match what is on tape and coming from VTR.
    System:
    Not haveing the same system will make this much harder.  I have to say I do not trust cameras as VTRs and I NEVER trust firewire for machine control.
    Good luck,
    Jef
  • Wed, Sep 30 2009 6:23 PM In reply to
    Thanks for the answer.
    jef:
    Unlinking:
    I searched help for this, but it only got me to the Relink menu, where an Unlink options is listed, but right now not available.
    The help says the following:
    You can relink to clips of a specific resolution.
    To relink a clip by resolution:
    1.   Select the unlinked object or objects in the bin.
    2.   Select Clip > Relink.
    3.   Select Relink Method > Specific Resolution.
    4.   Select an option from the "Relink if quality" menu, as described in the following table.
    When you select an option from the "Relink if quality" menu, the text of the Unlink button changes, as shown in the following table. The button is selected by default.
    "Relink if quality" Menu option Dependent option
    Is greater than or equal to resolution Unlink lower quality media
    Is equal to resolution Unlink media that is not resolution
    Is less than or equal to resolution Unlink higher quality media
    5.   Select the Unlink option.
    If you are working in an offline resolution and want to capture in a higher resolution, select Unlink to ensure that you recapture all the media at the higher resolution. You can check for offline media in the Timeline by selecting Timeline Fast menu > Clip Color > Offline, which displays offline clips in red.
    6.   Select a resolution from the Resolution menu.
    The default resolution is determined by the current Media Creation setting for Capture. See Media Creation Settings. If you select a different resolution in the Relink dialog box, the Media Creation setting does not change.
    7.   Select other Relink options as described in Relinking Media Files.
    8.   Click OK.
    I'm a little baffled by this, as I quite don't get it to work for unlinking Master clips, as it is listed under "Unlinking". Also the topic "Unlinking Master Clips" tells me to right click the Master clip and select Unlink, but I only get the following doing the right clicking part: Quite unnerving.
    jef:
    I'll check when the current tape stops, and report back on this setting.
    But I remember doing that already with another project, and it didn't work.
    I will try it nonetheless.
    Edit: The option with "capture the logged tracks" was selected, I deselected it and try how it works for now.
    jef:
    System:
    I know about the harder part, but I can't circumvent it now.
    We also don't have proper DV decks at hand, so I have to use those cameras, and the advantage is having the option to create subclips, which doesn't work with SDI, for which we have the Sony DSR 60 P, a machine almost 100 times bigger and 600 times heavier than a DV tape. I really can use subclips, as we work with several cameras at the same time, so having to look for every stop is quite a pain in the bottocks.
    And why don't you trust Firewire control?
    And good luck to you back.
  • Wed, Sep 30 2009 7:06 PM In reply to
    • jef
    • Maryland
    • Posts 474
    • Points 5,830
    Just chatted with the editor who went through the hell you are in.
    The unlink command is:
    control shift apple
    She said:
    "What ended up working best was to digitize the clip [not batch capture] with the exact same in timecode and relink the subclips to the new clip.
    I never got decrement to work"
    So there you go.  Does that help?
    EDIT
    Oh yea firewire - As a machine control protocol it is very inaccurate.  There is no guarantee that your recapture will be frame accurate to the original capture.  So be prepared for things to have "slipped" a bit.  Especially since it is a different machine.
    Jef
  • Wed, Sep 30 2009 7:46 PM In reply to
    jef:
    Jef
    Ah yeah, smegging frell.
    I will try the tip you gave me with my next tape.
    It works right now, but I still get that annoying message with some clips on some tapes (1 clip every five tapes) even though I deselected all the Settings > Capture > Batch > Clip options.
    I will do them by hand later.
    I'll report back, if that tip you got given worked.
    Thanks, and a nice evening or morning or day.
