Latest post Sun, Sep 27 2009 6:43 PM by TCurren. 2 replies.
  • Sun, Sep 27 2009 5:17 PM
    • JayEmm
    • Joined on Sun, Dec 16 2007
    • London, UK
    • Posts 20
    • Points 300
    How to re-import files with different levels?
    Hi Guys,
    Friend of mine working on a graduation project borrowed my AVID laptop, but for some reason did not realise the import levels had been set to RGB. Now, he has imported the 7 QT Movie files (DNxHD transfers of our rushes) with nastily compressed dynamic range.
    Unfortunately, he did not twig this at the start (he's not a professional editor) and has now edited the film and graded it, using the wrong levels to start.
    I appreciate that the grade will have to be re-done, but I was wondering if there was a way to delete the badly imported clips and to get it to re-import the files at the correct levels? I am sure this must be do-able. Somebody help us!
    Time is short, I thank you for your help.
    James Martin.
    Main System: 3.00 GHz C2D E6850, evga 680i SLI, 4GB RAM, GeForce 8800 GTX soft-modded to Quadro 4700, Windows XP [view my complete system specs]
    ------ James Martin Film Student, Met Film School, Ealing Studios, London
    Home Build System running MC 3.0
  • Sun, Sep 27 2009 5:39 PM In reply to
    • Brickwad
    • Simsbury, CT
    • Posts 480
    • Points 5,670
    Re: How to re-import files with different levels?
    You can hghlght the clips in the bin and hit "Delete" on your computer. When the dialog box pops up and offers check boxes on whether to delete master clips, or media files, or both, make sure only media files are selected and hit OK.
    Then, select the"empty" clips in your bin, and go to the clips menu and select batch import. It will ask if you want offline only, so say yes.  Then - if the QT files are in the same location that will appear and just click import.  If the QT's have moved, the file names will be in red, and you'll have to find them to do the batch import. Once the batch import is complete, your newly imported clips will already be in your timeline, and all your ins and outs will be preserved.  Be sure to change your import settings to the desired specifications before you do the batch import.
    Good Luck,
    I have 10 Avid systems, DX, Meridian and DNA. 1 MCA 1.8 on 2.5 quad G5 w/ 5 Gigs of Ram, 1 Symphony Nitris DX on eight core mac pro with 4 gig ram, 1 MC... [view my complete system specs]
    Andy
  • Sun, Sep 27 2009 6:43 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 1,668
    • Points 21,295
    In the batch import dialog window there is a check box in the lower left (don't recall the exact wording at the moment) but whne it is checked on the imports will follow whatever you have selected as import settings currently. When checked off (the default) the original settings will be used regardless of what you have set up.
    Burbank, Ca
    www.alphadogs.tv
    www.digitalservicestation.com
    www.editorslounge.com
