Latest post Mon, Sep 28 2009 4:11 AM by Clement Canino. 15 replies.
  • Sat, Sep 26 2009 10:19 PM
    • Colby
    • Joined on Sun, Nov 23 2008
    • Posts 23
    • Points 325
    Nitris DX vs Mojo DX
    Can someone tell me - in real simple layman's terms - the exact difference between a Nitris DX and a Mojo DX.  I get it that there running the same software (Media Composer). And I know that the Mojo I/O box is smaller, but what are the differences between the 2?
    Colbers
  • Sat, Sep 26 2009 10:38 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 1,400
    • Points 16,025
    Re: Nitris DX vs Mojo DX
    Mojo DX: SDI only, Nitris DX: SDI and analog I/O and hardware DNxHD. hth
    MC 3.5/Mojo, Vista 64 biz, Gigabyte GA-EP45T-EXTREME, Intel Q9450, 8 GB ram, Pyro 64, Quadro FX 1700, 2 x 1TB drives (raid 0) for mediafiles + G4 MacBook... [view my complete system specs]
    peace luca
  • Sat, Sep 26 2009 10:46 PM In reply to
    • Colby
    • Posts 23
    • Points 325
    Luca, Yes that definitely helps.  Help me out a little more:
    1.  Does the Nitrix DX I/O box add processing power to the HP workstation?
    2.  By "hardware DNXHD" do you mean that the Nitris acts as a transcoding box during ingest and that the Mojo doesn't?
    Bear with me.  I'm trying to get a grip on this so that I understand it for myself.
    Colbers
  • Sat, Sep 26 2009 11:20 PM In reply to
    • berga
    • Stockholm, Sweden, Europe
    • Posts 1,627
    • Points 19,490
    1. Depends what You mean with processing power. Both Nitris DX and Mojo DX do some video centric trix for MC, such as scaling video.
    2. With Mojo DX, the CPU will trnascoding the incoming HD-SDI to DNxHD. With Nitris DX, the incoming HD-SDI is transcoding in the box without any use of the CPU.
    HP xw4600, 3.2Mhz, 4Gb RAM, Mojo. 500GB SATA Bootdrive, 3x500GB internal raid-0 for video, Windows xp sp3, MC3.05, Genelec 1030A, JVC TM-H170. [view my complete system specs]
  • Sat, Sep 26 2009 11:30 PM In reply to
    • Colby
    • Posts 23
    • Points 325
    Sorry I was a little unclear.  But you answered me anyway - the Nitris transcodes independent of the PC and the Mojo doesn't.
    What was the Mojo originally designed for?  Editing in the field/on-location?  Any idea?
    Colbers
  • Sun, Sep 27 2009 3:03 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 4,242
    • Points 48,755
    I believe that it was originally designed as a cheap monitoring and I/O solution for Xpress DV and Xpress Pro.
    MC 4.0.3 - Asus P6T Deluxe V2 mobo - Intel i7 920 2.66GHz - nVidia Quadro 1700 - 12 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro firewire... [view my complete system specs]
  • Sun, Sep 27 2009 3:39 AM In reply to
    jwrl:
    MojoDX was introduced after XpressDV and XpressPro were EOL'd.  It was never intended to be used with those products.  The original Mojos (analog or SDI) were also not ever compatible with XDV.  XpressPro was the first product to be usable with the Mojo (non-DX)
  • Sun, Sep 27 2009 6:39 AM In reply to
    • jwrl
    • Posts 4,242
    • Points 48,755
    Kenton.VanNatten:
    Yes, that's true.  But the question was
    Colby:
    To that question I replied
    jwrl:
    I stand by that reply.  I believe that was the original Mojo's purpose.
  • Sun, Sep 27 2009 7:14 AM In reply to
    • Colby
    • Posts 23
    • Points 325
    Tracking.  Thanks for all your input.  Aside from the limited I/O of the Mojo compared to the Nitris DX, is there any other function that the Nitris I/O box does other than transcoding to DNXHD that the Mojo doesn't do?  For example, when an effect is rendered (BCC or Sapphire), does the I/O box of the Nitris lend any of its computing power to that or is it strictly on the CPU of the PC at that point?
    Colbers
  • Sun, Sep 27 2009 8:42 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 1,400
    • Points 16,025
    Go to the products-Mojo DX page and the system requirements page and carefully read the published info: Mojo DX does not support DNxHD capture on some systems, a minimum 8 cores machine is needed for that if I recall... and I doubt that Nitris DX would interact with third party plugins.
    peace luca
  • Sun, Sep 27 2009 3:58 PM In reply to
    Even though they say an 8 core is minimum, I currently use a Mojo DX wiith an HP XW 6400, 2 dual core 3.0 Intel Xeon processors and regularly use DNxHD 220, in 1080, and DNxHD 175 in 720 for a LOT of capture and  playback without any problems whatsoever. Running 3.12 on Win XP 32, Quadro 3500. You might not be able to do same, but it works fine for me.
    HP XW6400, 2x 3.0 dual Xeon 4g ram, Quadro FX 3500, XP Pro SP2 Pyro 64, MOJO, MOJO DX, latest nvidia drivers from Avid install disk, recommended QT version... [view my complete system specs]
  • Sun, Sep 27 2009 4:27 PM In reply to
    jwrl:
    Kenton.VanNatten:
    Colby:
    jwrl:
    From that context, yes I agree - you are 100% correct.  But, to me in the context of the whole thread (subject line included) it seems that Colby is referring to the MojoDX and is dropping the DX part of the name, which leads to confusion.
  • Sun, Sep 27 2009 5:13 PM In reply to
    • GeorgeDe
    • Joined on Tue, Jun 30 2009
    • Posts 5
    • Points 75
    I don't understand it either - just why should I pay more for the Nitris?  SDI to analog converter is $300 and for HD there is HDMI.
  • Sun, Sep 27 2009 6:06 PM In reply to
    • NICKB
    • Posts 732
    • Points 9,870
    GeorgeDe:
    Avid want to make more money, they believe the Nitris will be bought by facilities and broadcasters rather than editors.
    Editors will buy the Mojo DX and a cheap external analogue convertor.
    The Nitris does have DNx chips inside for encoding which relieves you computer of some work during capture from tape however no one seems able to say if those chips do anything in normal editing!
    If your spending someone elses money you buy a Nitris if it's your own money you buy a Mojo with an external convertor.
    Or cheaper still you go out and buy Final Cut Pro and a $500 i/o card and join the new kid on the blockBig Smile
    Those DX box's will be the death of Avid if they dont sort out the prices soon.
  • Sun, Sep 27 2009 7:36 PM In reply to
    • Colby
    • Posts 23
    • Points 325
    Thanks for the suggestion. Didn't mean to hit a nerve with my post... I guess I could convert SDI to analog if I wanted to with a converter. Got a particular one in mind? The Mojo DX also doesn't have AES in or out nor any XLR connectors. So there's a few more things that make it different. Seems to me
    Colbers
