Latest post Thu, Sep 24 2009 4:43 PM by luca.mg. 13 replies.
Page 1 of 1 (14 items)
  • Thu, Sep 24 2009 3:26 AM
    • GeorgeDe
    • Joined on Tue, Jun 30 2009
    • Posts 5
    • Points 75
    MC 4.02 cannot apply Timewarp
    Getting message "Effect does not apply" when I try to drop Timewarp or Trim to Fill onto a clip in a sequence.
    Vista 64
    Project: PAL 25i
    Clip: imported from an AVI file as 25i PAL, the AVI file is originally NTSC, ignoreqtframerate true
    I tried some other PAL mixdown clip and it worked on that one. Then I made a mixdown of the imported clip and it worked on the mixdown. So that would be the workaround for now...
    - George
  • Thu, Sep 24 2009 7:26 AM In reply to
    • mvegas
    • Posts 1,436
    • Points 16,450
    Re: MC 4.02 cannot apply Timewarp
    Does your original file contain an alpha channel?  If so then hold the alt key down before dropping the timewarp fx onto
    your clip.  Doing a mixdown creates a masterclip of the original import and your workaround makes perfect sense.
  • Thu, Sep 24 2009 8:43 AM In reply to
    If you are on v4, the "better" thing to do would be to import the NTSC clip into an NTSC project, then, from your PAL 25i project, open the bin with that imported clip. It will automatically be timewarped to the right speed. Just saying...
    Symphony Classic Nitris 4.0.2 on 2x 2.33 quad core XW8400/8GB Vista Biz 64bit | MC 4.0.2 on 2x dual core 2.66 XW8400/7GB Vista Biz 64bit | Mojo SDI | Unity... [view my complete system specs]
  • Thu, Sep 24 2009 8:50 AM In reply to
    • sverkalo
    • Thessaloniki Greece
    • Posts 4,787
    • Points 57,000
    Job,
    it sounds that MC4 is the easiest way to go from PAL to NTSC and vice versa.
    Desktop
    Armor 8000/Zalman 600W/Abit IP35Pro/Quad 6600@3G/8G Corsair DDR2 800/Geforce 8800GTS 640@Quadro FX 5600(169.47)/X-Fi Xtreme Music/160WD S2/2x1TB Samsung F1(RAID 0)/Many e-SATA drives/Samsung 203B/Vista Business SP1 64bit/Avid Media Composer 3.1.3 Suite/2xHP 22'' Monitors/M-Audio AV30 Speakers.
    Laptop
    Fujitsu Siemens(Amilo Xi 2528-07)/T8100/3G DDR2/8600M GS 256/Realtek HD/Many e-SATA drives/Optiarc 7540/Optiarc 7240S(USB)/Vista Business SP1 32bit/Avid Media Composer 3.1.3 Suite.
    My Films
  • Thu, Sep 24 2009 9:02 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 1,388
    • Points 15,885
    There's also an obscure product called Symphony... Big Smile
    MC 3.5/Mojo, Vista 64 biz, Gigabyte GA-EP45T-EXTREME, Intel Q9450, 8 GB ram, Pyro 64, Quadro FX 1700, 2 x 1TB drives (raid 0) for mediafiles + G4 MacBook... [view my complete system specs]
    peace luca
  • Thu, Sep 24 2009 11:58 AM In reply to
    • TerryO
    • Joined on Mon, Oct 24 2005
    • Oslo, Norway
    • Posts 111
    • Points 1,310
    Job ter Burg:
    There is a difference in this method and the console command mentioned. The console command will import all frames as is. Meaning the duration will differ from the original but there will be no frame/motion/convertion.
    Work machines: 5 Avid Media Composer Adrenaline version 3.5 Avid Sympony Nitris v. 3.5 Interplay and Unity Medianet TV 2 Oslo, Norway [view my complete system specs]
  • Thu, Sep 24 2009 12:22 PM In reply to
    TerryO:
    There is less difference than you would think.
    With the new feature you actually bring in the frames as they are, but the clips will have an automatic source-based timewarp applied to them. So if you bring in NTSC clips into a PAL project, click on the Timewarp effect and modify it so it plays back at 25.00fps you have the exact same result as an ignoreqtrate true-import.
    The idea is that you import in NTSC, then use the clip in PAL. No framerates are actually changed, they just get a realtime motion effect applied for instant playback.
    Since you mentioned importing with the console command, then applying a timewarp (probably to get to the right speed), you might jsut as well (but faster) achieve this with the new mix&match features.
  • Thu, Sep 24 2009 12:57 PM In reply to
    • andro
    • Warsaw
    • Posts 87
    • Points 1,125
    Only one problem is with new mix&match features, fast movment is not smooth you can change setting to fluid motion but must do this manualy for every shot(except this new future is grate). You can't change this in render settings, fluid motion option is absent for timewarps.
    Avid MC 4.0.2 Vista 64 Adrenaline HD HP xw8400, FX 1500, 8GB ram. 2* Avid MC 3.1.2 Vista 64 Mojo SDI HP xw8400, FX 1500, 8GB ram Avid MC 3.0.5 XP... [view my complete system specs]
  • Thu, Sep 24 2009 2:20 PM In reply to
    • bwilhelm
    • Joined on Thu, Mar 19 2009
    • Avid (Tewksbury, MA)
    • Posts 57
    • Points 680
    GeorgeDe:
    It may be that there is already a motion adapter on your clip.
    Currently we do not allow transplanting a timewarp onto a motion adapter,
    though we do hope to enable this in a future release.
    You can, however, promote a motion adapter to a timewarp,
    which allows you to modify speed values, add keyframes, get access to Fluid Motion, etc.
    Open the Motion Effect Editor while parked on the clip in the timeline and hit Promote.
  • Thu, Sep 24 2009 2:47 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 1,388
    • Points 15,885
    GeorgeDe:
    Welcome to the forum George, that's the error message that You get when adding an effect to a clip which has already an effect such as a resize, PiP, key, or whatever: do You happen to already have an effect on the offending clip? If yes step into the effect and drop the Timewarp under the other effect. You can have multiple effects on a clip but timewarp has to be the first one.
    peace luca
  • Thu, Sep 24 2009 4:12 PM In reply to
    • TerryO
    • Oslo, Norway
    • Posts 111
    • Points 1,310
    Job ter Burg:
    TerryO:
    I guess you might be correct. But if one does not change the speed afterwards, there will be no motion artifacts.
    Much NTSC or film that is converted to PAL do have an increase of speed, thus giving shorter durations when watched in PAL.
  • Thu, Sep 24 2009 4:37 PM In reply to
    • GeorgeDe
    • Posts 5
    • Points 75
    I looked but there is no  motion adapter effect on this clip. It seems MC thinks there is. It is imported as PAL media and so there should be no need for a motion adapter.
    The problem occured with either ignoreqtrate true or false.
    It would help if there was an option to apply a motion adapter or not on the import module. Some option to deal with mismatching frame rates.
    And while I'm at it.... an option to remove a motion adapter and use the clip frame by frame would help too. Sometimes I have to bring in footage frame by frame to avoid motion artifacts.
    - George
  • Thu, Sep 24 2009 4:38 PM In reply to
    • bwilhelm
    • Posts 57
    • Points 680
    TerryO:
    Users of 4.0.X can actually also simulate this behavior - preserving frames at the expense of time -
    though it will require a few extra manual steps on their part.
    For each motion adapter on a video clip in the timeline,
    promote it in the Motion Effect Editor to a full timewarp and set its speed to %100.
    To compensate for the matching audio clips,
    add an AudioSuite Time Shift plugin and adjust the Time/Shift parameter accordingly.
    Note that you'll need to calculate the percentage value yourself, based on the edit rate ratio.
    (ie: going from 24 to 25 would be about %104, from 25 to 24 is %96).
    The audio effects will also need to be rendered in order to play them back in real-time.
    It's not a seemless workflow - though we hope to improve that in future releases -
    but it should accomplish the goal of avoid motion artifacts.
    Feel free to experiment with this and let us know whether it works for you - thanks.
  • Thu, Sep 24 2009 4:43 PM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 1,388
    • Points 15,885
    Job ter Burg:
    Job had the right recipe for You at the beginning of the thread IMHO.
    peace luca
