Latest post Tue, Sep 29 2009 11:24 PM by TrevorA. 8 replies.
Page 1 of 1 (9 items)
  • Tue, Sep 22 2009 9:39 PM
    Uniy over VPN
    Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4 <!-- /* Font Definitions */ @font-face {font-family:"Cambria Math"; panose-1:2 4 5 3 5 4 6 3 2 4; mso-font-charset:0; mso-generic-font-family:roman; mso-font-pitch:variable; mso-font-signature:-1610611985 1107304683 0 0 159 0;} @font-face {font-family:Calibri; panose-1:2 15 5 2 2 2 4 3 2 4; mso-font-charset:0; mso-generic-font-family:swiss; mso-font-pitch:variable; mso-font-signature:-1610611985 1073750139 0 0 159 0;} /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-unhide:no; mso-style-qformat:yes; mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman","serif"; mso-fareast-font-family:Calibri; mso-fareast-theme-font:minor-latin;} .MsoChpDefault {mso-style-type:export-only; mso-default-props:yes; font-size:10.0pt; mso-ansi-font-size:10.0pt; mso-bidi-font-size:10.0pt;} @page Section1 {size:612.0pt 792.0pt; margin:72.0pt 72.0pt 72.0pt 72.0pt; mso-header-margin:36.0pt; mso-footer-margin:36.0pt; mso-paper-source:0;} div.Section1 {page:Section1;} --> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} Hi there
    We are running a UNITY locally and an avid in a remote location and have a
    10M dedicated VPN between the two locations. At present we are copying media
    and projects from one location to the other. It would be much better if we
    could have the projects on UNITY. I'm thinking 10M connection would be fine
    for just projects, they aren't massive projects. So the question is does
    this seem like a reasonable plan and if so how do I co connection manager
    across a VPN ie ports etc.
    Also along similar lines if I wanted the attic to be on the remote machine
    rather than unity to save bandwidth is that practical and if so how do I
    change the attic location?
    Or is all this a bad idea?
    Nige
    MN 5.1 media endine 5 fiber clients 7 ethernet. Mix of xw8200/8400 and 1 mac! [view my complete system specs]
  • Thu, Sep 24 2009 1:25 AM In reply to
    • Posts 1,595
    • Points 19,895
      Avid Employee
      Moderator: Broadcast Newsroom
    Re: Uniy over VPN
    Nigel,
    Let me check with the engineers on this one....  no one has ever asked me about VPNing... with Unity.  Seems skechy but let me ask the experts.
    marianna
    Customer Advocate/Customer Success [view my complete system specs]
    813-493-6800 mobile
    AOL IM avidmarianna
  • Fri, Sep 25 2009 2:54 PM In reply to
    • Doc Avid
    • Joined on Mon, Jul 17 2006
    • Los Angeles / Hollywood
    • Posts 2,238
    • Points 24,745
    Re: Uniy over VPN
    This is a really bad idea.
    Just about all of them, And a '06 Scion xB [view my complete system specs]
  • Sat, Sep 26 2009 9:28 AM In reply to
    Re: Uniy over VPN
    can I ask why you think this? This is an uncontended guareteed bandwidth connection, it would be a very neat why of us keeping 2 locations in sync, far syperior and safer to any of the alternatives.
    N
  • Sat, Sep 26 2009 4:22 PM In reply to
    • jveekeres
    • Athens Greece
    • Posts 671
    • Points 8,470
    Re: Uniy over VPN
    Bad idea, but it would be great experiment. Have you ever tested the actual data throughput on that line? It's one thing to have an average throughput for data, another for streaming high quality video and Avid software in general is highly allergic to any data timeouts...
    7x HP XW8400 9x HP XW8200 4x HP XW8000 5x Media Composer 3.1 2x Media Composer 3.1 Adrenaline 2x Media Composer 2.7 Adrenaline HD 1x Media Composer... [view my complete system specs]
    Jeroen van Eekeres
    Ena productions
    Software activation AND dongle is better then only software activation.
  • Sat, Sep 26 2009 4:33 PM In reply to
    Re: Uniy over VPN
    My plan isn't to stream the media but just to have the shared projects. The media is mirrored in both locations by slowly synchronising overnight which works fine, About 6 Gigs an hour. So all I want is to be able to access the Unity Projects so no media from unity directly. Plus I was going to have the attic on the local PC so the only time the remote user sends data to the unity is when something is expressly saved.
    NIge
  • Sat, Sep 26 2009 4:44 PM In reply to
    Re: Uniy over VPN
    Excellent thanks
    So all I want is to have access over VPN to the Unity projects, I'm not wanting the media to work. And possibly have the attic on the remote workstation rather than unity to reduce the slow saves.
    We are currently getting 6G/hr transfer speed which is 100M/min At typlical project for us is about 25M so it seems like a reasonable thing to do?
    N
  • Tue, Sep 29 2009 3:36 PM In reply to
    • Doc Avid
    • Posts 2,238
    • Points 24,745
    Re: Uniy over VPN
    You're going to have issues with Bin Locks due to your connection type,  and bin  Version issues because of time discrepancies.
  • Tue, Sep 29 2009 11:24 PM In reply to
    • TrevorA
    • Posts 159
    • Points 1,835
    Re: Uniy over VPN
    We've been getting around crashing/lockup issues by having local projects and avoiding shared bins / projects. Seems to have cured a number of issues. Of course we are on Interplay - which does actually work better than shared projects in many ways - once you get your head around it.
    T
    Avid, FCP, EVS, Tape, whatever.
    Online diary and showreel at webdiary.tv
