Latest post Wed, Sep 23 2009 12:06 AM by BarkinMadd. 13 replies.
Page 1 of 1 (14 items)
  • Tue, Sep 22 2009 11:53 AM
    • BarkinMadd
    • Ontario, Canada
    • Posts 2,172
    • Points 28,860
    Importing mixed rate material - MC 4.0.2
    Hi folks,
    Just upgraded to MC 4 and was reading about mixing framerates in a sequence. For those of you who have tried this, how do you import material at a different framerate from the project rate? When I try to import, for example, a 1080i59.94 clip into a 1080p23.976 project, Avid converts my clip to match the project rate (and the import takes a long time as it creates the new QT media).
    I'm obviously overlooking something obvious. Any help is appreciated.
    ***edit - BTW - the imported video clip in my test does not have an audio track - does that matter?
    Camera(s) Sony HDR-FX1, Canon HV20 | MC 4.0.5 | QT 7.6.2 | Vista 64 Ultimate SP2 | System: P5W-DH QUAD QX6700 (2.66GHz clocked to 3.2GHz), 8GB RAM (800MHz... [view my complete system specs]
    Steve
  • Tue, Sep 22 2009 12:38 PM In reply to
    • camoscato
    • Posts 6,574
    • Points 78,630
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    Re: Importing mixed rate material - MC 4.0.2
    Hi Steve,
    As I understand it, if you've got a 59.94 file, you should import it into a bin in a 59.94 project, then open that bin in your 23.976 project, at which point the new Mix & Match feature will apply a source side timewarp effect to adjust the frame rate of the 59.94 clip to match the 23.976 project.  The lack of an audio track should make no difference.
    Hope that makes sense.
    good luck,
    Carl
    MC 4.0.5, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
    There is no such thing as a video emergency.
    I've got a new website for 2010!
  • Tue, Sep 22 2009 12:46 PM In reply to
    • sverkalo
    • Thessaloniki Greece
    • Posts 5,410
    • Points 63,425
    Can't be like that Carl.
    Because this is too much trouble to do it every time.
    Armor 8000/Zalman 600W/Abit IP35Pro/Quad 6600@3G/8G Corsair DDR2 800/Geforce 8800GTS 640@Quadro FX 5600/X-Fi Xtreme Music/160WD S2/2x1TB Samsung F1(RAID 0)/Many e-SATA drives/Optiarc 7240S/W7 Ultimate 64bit/Avid Media Composer 4.0.5 Suite/Pro Tools Vocal Studio 8.0.3/2xHP 22'' Monitors/M-Audio AV30 Speakers.
    My Films
  • Tue, Sep 22 2009 1:07 PM In reply to
    That's how it's done, though. You capture/import into a project with a matching framerate, then open that captured/imported footage within any other project (with a different frame rate). It ensures proper metadata handling, sound sync at the correct sample rate, and it also enables you to change the format on any sequence later on.
    Symphony Classic Nitris 4.0.4 on 2xQC 2.33 XW8400/8GB Vista Biz 64bit | MC 4.0.5 on 2xQC 3.0 XW8600/8GB Vista Biz 64bit | Mojo SDI | MC 4.0.5 on 2xDC 2... [view my complete system specs]
  • Tue, Sep 22 2009 1:25 PM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,377
    • Points 30,445
    • Moderator: MCA PC
    sverkalo:
    George, I'll just add my support to both Carl and Job - That is how it is done!
    Regards,
    Douglas
    (AMC MojoDX 4.0.5.2 XP Pro Business SP3), (AMC MojoDX 4.0.4 Vista64 Business SP1),ASUS PK5 DEluxe/WiFi-AP CH1-14 Mobo,Intel Core 2 Duo E6850 (3GHz)8GB... [view my complete system specs]
    Douglas, Kumamoto, Japan - ( AMC 3.1.2 / Mojo DX) + ( AMC 4.0.4 / Mojo DX), http://www.gaijin-eyes.com
  • Tue, Sep 22 2009 1:42 PM In reply to
    • jjytan
    • Joined on Wed, Oct 31 2007
    • Posts 12
    • Points 165
    updated to mc/symphony 4.0.2,   when importing AMA P2 1080/24PA material the motion adapter sees it as "interpolated field", it does not detect correct cadence.
    Project Setting: 1080/23.98
    Material: P2 1080/24PA Material imported using AMA.
    i have to manually promote the effect and choose 2:3 pulldown and click detect for every single clip on the timeline for proper cadence detection. also, is there a 2:3:3:2 pulldown removal in timewarp instead of the usual 2:3
    John
  • Tue, Sep 22 2009 1:52 PM In reply to
    • sverkalo
    • Posts 5,410
    • Points 63,425
    This doesn't sound so good.
    You capture at the frame rate or import then you close that project and open a new one and import from where?
    From the bins?
    My Films
  • Tue, Sep 22 2009 1:59 PM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 3,692
    • Points 42,335
    sverkalo:
    import from where?
    From the bins?
    The command from the new project is " open bin"
    MC 4,05 Soft V 64 Ultimate Mbo gigabyte 965-DQ6,cpu quad core QX 6700, mem Corsair Dominator 8500 8 GB, PNY Quadro 1800, Soundblaster X-Fi Elite Pro... [view my complete system specs]
    Tomas
  • Tue, Sep 22 2009 2:20 PM In reply to
    • camoscato
    • Posts 6,574
    • Points 78,630
      Moderator: Meridien
    Hi George,
    sverkalo:
    To use the OP as an example, if you want to use a 59.94 clip in a 23.976 project:
    Step 1: Create 59.94 project.
    Step 2: Import 59.94 file into 59.94 project bin.
    Step 3: Create 23.976 project.
    Step 4: In 23.976 project, select File > Open Bin.
    Step 5: Navigate to bin from Step 2.
    Now you can use the 59.94 clip created in Step 2 in your 23.976 project without any transcoding, rendering, mixing down, blah, blah, blah.
    good luck,
    Carl
  • Tue, Sep 22 2009 2:28 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 16,579
    • Points 210,465
    If your clip is imported with the incorrect progressive/interlaced filed motion, you can show the column for field motion and/or cadence, right click on either, and change those to be whatever you like.
  • Tue, Sep 22 2009 3:20 PM In reply to
    • jjytan
    • Posts 12
    • Points 165
    the bins show 2:3:3:2 pulldown, but when viewed in our monitors, the motion is stuttery unless i upgraded using the procedure i listed in my previous post.
  • Tue, Sep 22 2009 3:39 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 16,579
    • Points 210,465
    But, in the bin, where you see the cadence, you can right click on the column and change the cadence without promoting the effect. You can do the same to the Field Motion type.
  • Tue, Sep 22 2009 4:35 PM In reply to
    • jjytan
    • Posts 12
    • Points 165
    i can only select 2:3:3:2, no other options.  i'd also like to verify if it is indeed the C frame is being dropped, or avid is performing 2:3:2:3 pulldown on a 2:3:3:2 clip.
  • Wed, Sep 23 2009 12:06 AM In reply to
    • BarkinMadd
    • Ontario, Canada
    • Posts 2,172
    • Points 28,860
    camoscato:
    Hi Steve,
    good luck,
    Carl
    Fantastic, Carl - Thanks!!!
    Steve
