Latest post Mon, Sep 28 2009 7:46 AM by Igor Ridanovic. 5 replies.
Page 1 of 1 (6 items)
  • Mon, Sep 21 2009 10:16 PM
    • autolux
    • Joined on Tue, Jan 15 2008
    • Redwood City Ca
    • Posts 52
    • Points 750
    Footage Replace in DS?
    I'm sure the answer is probably no, but I thought I'd ask.....anyone got anything on this?
    Thanks as usual guys and gals!
    AB
    later.
  • Tue, Sep 22 2009 12:34 AM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 353
    • Points 3,945
    • Moderator: Avid DS
      Moderator: MetaFuze
    Re: Footage Replace in DS?
    Sorry, but I'm not sure what the question is. Do you mean replace footage on your timeline, swap out footage linked in, or footage captured from tape?
    "There are no rules for the brave". Albert Einstein
  • Tue, Sep 22 2009 1:02 AM In reply to
    • autolux
    • Redwood City Ca
    • Posts 52
    • Points 750
    to swap footage thats linked.  Like I did a wow edit of some animation and the client may want a different background in the whole show.  I was curious if I could have our artist re-render the clips with the same name and parameters and just select the updated clips and have them automatically be replaced in the timeline.  Hopefully that explains it a bit better...thanks
    later.
  • Tue, Sep 22 2009 3:44 PM In reply to
    • slabross
    • Montreal
    • Posts 381
    • Points 3,800
      Moderator: Avid DS
    If the linked files indeed use the very same name and length, yes, just moved the original files out of its current location (better keep them as a backup, in case you need them again, right?) and replace these files.  DS will link to the new material and display the images.
    Even for captured files, if you use the same format, size and length, you can purge the media and recapture the new content.
    Sylvain Labrosse
    Avid DS Product Champion | Video Customer Success
    Avid
    3510 St-Laurent Boulevard
    Montréal, QC H2X 2V2
    Canada
    sylvain.labrosse@avid.com
    We're Avid.  Learn more at www.avid.com
  • Wed, Sep 23 2009 7:16 PM In reply to
    • autolux
    • Redwood City Ca
    • Posts 52
    • Points 750
    thanks so much Sylvain.  Great help
    later.
  • Mon, Sep 28 2009 7:46 AM In reply to
    If you are using linked clips as opposed to captured clips your timeline material is constantly udpated. DS will be loading whatever rendered frames are available at the time. Even in a middle of a render.
    If you process any parts of the timeline that contain linked clips you will need to purge the caches in order to force DS to look at the original files instead of the caches.
    Igor Ridanovic
    www.HDhead.com
