Latest post Thu, Sep 17 2009 10:09 AM by sverkalo. 14 replies.
Page 1 of 1 (15 items)
  • Tue, Sep 15 2009 3:19 PM
    Correct aspect ratio in widescreen projects
    Can we have the Film masks labeling revised for 16x9 and HD projects? Applying a 16x9 effect does not create a 16x9 mask in these projects, and also 1.66 and 1.85 are incorrect. Looks like SD 4x3 legacy...
    Perhaps revise the way the Grid settings work, while we're at it. Now, you have to set "4x3 outside 16x9" in order to have correct aspect ratio markers in the grid. Also SD 4x3 legacy, I think.
    Symphony Classic Nitris 4.0.2 on 2x 2.33 quad core XW8400/8GB Vista Biz 64bit | MC 4.0.2 on 2x dual core 2.66 XW8400/7GB Vista Biz 64bit | Mojo SDI | Unity... [view my complete system specs]
  • Tue, Sep 15 2009 11:16 PM In reply to
    • vvp
    • Edmonton, Canada
    • Posts 654
    • Points 7,960
    Re: Correct aspect ratio in widescreen projects
    + 1
    MC Nitris DX v.4.0.2 HP Z800 * Nitris DX v.4.0.2 HP wx8400 [view my complete system specs]
    So my new wife asks me about my "Avid Forever" tattoo... I told her she's an old girlfriend who was always coming up with new things for me to try...
  • Wed, Sep 16 2009 12:12 PM In reply to
    • sverkalo
    • Thessaloniki Greece
    • Posts 4,787
    • Points 57,000
    This should be as Job says!!!!!!!!!!
    Desktop
    Armor 8000/Zalman 600W/Abit IP35Pro/Quad 6600@3G/8G Corsair DDR2 800/Geforce 8800GTS 640@Quadro FX 5600(169.47)/X-Fi Xtreme Music/160WD S2/2x1TB Samsung F1(RAID 0)/Many e-SATA drives/Samsung 203B/Vista Business SP1 64bit/Avid Media Composer 3.1.3 Suite/2xHP 22'' Monitors/M-Audio AV30 Speakers.
    Laptop
    Fujitsu Siemens(Amilo Xi 2528-07)/T8100/3G DDR2/8600M GS 256/Realtek HD/Many e-SATA drives/Optiarc 7540/Optiarc 7240S(USB)/Vista Business SP1 32bit/Avid Media Composer 3.1.3 Suite.
    My Films
  • Wed, Sep 16 2009 12:20 PM In reply to
    • sverkalo
    • Posts 4,787
    • Points 57,000
    Job ter Burg:
    Can you expand on this Job?
    You mean that the grid is false at HD?
    Desktop
    Laptop
    My Films
  • Wed, Sep 16 2009 1:13 PM In reply to
    • jakeheat
    • Joined on Sun, Sep 3 2006
    • Posts 151
    • Points 1,815
    sverkalo:
    Job ter Burg:
    I think Job means "4:3 inside 16:9 Monitor".  But in any case the Avid's default grids bare no resemblance to the real world.
    As for the Film Mask, yeah, it seems to be one of Avid's many 4:3 legacy annoyances. Surely at some point a major new release of Avid apps should default everything to 16:9 and make 4:3 the secondary option.
    Even in HD mode a 1.85:1 mask comes in at 2.46:1 - pretty pathetic from Avid really.
    SYMPHONY NITRIS 3.5.4 HP xw8400 QT 7.6 Vista 64 ADRENALINE 3.5.1 PC HP xw8400 XP MC SOFT 4.0.2 PC HP xw8400 - & MacPro 3Ghz Quad OS 10.5.8 QT 7.6.2... [view my complete system specs]
  • Wed, Sep 16 2009 1:19 PM In reply to
    • sverkalo
    • Posts 4,787
    • Points 57,000
    jakeheat:
    Why you say that? All of my tests for the shows we are making are ok at tv sets and at broadcasting.
    I am refering to titles only.
    Desktop
    Laptop
    My Films
  • Wed, Sep 16 2009 1:26 PM In reply to
    • jakeheat
    • Posts 151
    • Points 1,815
    We get a PS grid guide from the BBC to calibrate our grid settings. When you put this against the default Avid grid, it's off.
    And things like 4:3 safe title within 16:9 are completely out.
    If you like I'll send you a copy.
  • Wed, Sep 16 2009 1:38 PM In reply to
    • sverkalo
    • Posts 4,787
    • Points 57,000
    Please do so!
    Is this for every ratio?
    And is it easy to set it up for MC?
    angeludis@gmail.com
    George Angeludis at Facebook.
    Desktop
    Laptop
    My Films
  • Wed, Sep 16 2009 1:51 PM In reply to
    • jakeheat
    • Posts 151
    • Points 1,815
    Here's a link. There's a guide to setting up.
    http://www.bbc.co.uk/commissioning/tvbranding/picturesize.shtml
    but it's only for 16:9 SD - not sure if it relates internationally though - also things change all the time.
    Most of our stuff just has to be 14:9 safe for pics and graphics / 4:3 safe for text.
  • Wed, Sep 16 2009 1:59 PM In reply to
    • sverkalo
    • Posts 4,787
    • Points 57,000
    Thanks a lot Jake.
    Desktop
    Laptop
    My Films
  • Wed, Sep 16 2009 3:49 PM In reply to
    jakeheat:
    No, I don't.
    If you're in a 16x9 or HD project, and need to have 1.85:1 gridlines, you need to tell your Avid that 4x3 resides outside 16x9. In "normal" mode, the aspect ratio of the grid is distorted. If you are in 4x3-inside-16x9-mode, it places the grid as a picture-in-picture. All other settings assume 4x3.
    Unless you tell your grid that 4x3 resides outside 16x9. Then it appears to be correct.
  • Wed, Sep 16 2009 6:20 PM In reply to
    • jakeheat
    • Posts 151
    • Points 1,815
    Gotcha! Thought you were still talking about the Mask effect.
    Job ter Burg:
    I'm still right about the Mask presets.
  • Wed, Sep 16 2009 6:33 PM In reply to
    Then we are in common confusion AND agreement. ;-)
  • Thu, Sep 17 2009 9:01 AM In reply to
    • Sycophant
    • Auckland, New Zealand
    • Posts 1,143
    • Points 13,860
    • Moderator: MCA Mac
    jakeheat:
    The BBC/EBU 4:3 protect in 16:9 is a comprimise. What Avid's guide shows is a true 4:3 safe within a 16:9 raster, but the BBC spec for 4:3 in widescreen splits the difference a bit, reducing the action and title safe margins to 3.5% if I recall correctly.
    While that's acceptable to the BBC (as it's their spec) it's not really 4:3 safety within 16:9 and might fail with other broadcasters.
    The grids in Media Composer are correct by a strict interpretaion.
    Also, for what it's worth, the frame-edge line in Avid's 4:3 in 16:9 is close enough to 14:9 title safe that it's usually pretty good for that.
    HP XW8600s - Media Composer 3.5.4 - HP XW8400s - DS Nitris 10.1 [view my complete system specs]
    Dylan Reeve - Editor and Stuff
    My opinions are my own.
    Dylan's Templater - Basic Avid project templating tool.
    BatchFuze - MetaFuze batch transcoding tools.
  • Thu, Sep 17 2009 10:09 AM In reply to
    • sverkalo
    • Posts 4,787
    • Points 57,000
    At least I don't see any problem to titles when placed on a 16:9 or 4:3 project following MC's grid.
    Now graphics might be a different story.
    Desktop
    Laptop
    My Films
