Latest post Fri, Sep 18 2009 6:53 AM by Chris Hocking. 4 replies.
  • Tue, Sep 15 2009 2:07 AM
    EDL Manager Crash - Bus Error
    I'm running Avid Media Composer 3.0.5 and EDL Manager 24.0.5 on a Mac. Normally EDL Manager works great, however, on a current project, I'm running into issues.
    The project was created in 3.0.5, but most of the editing has taken place on another Avid Media Composer 2.8.0 Mac. The footage is RED material that was imported into Avid as DNxHD36 Quicktime's that came via REDrushes. We do this workflow all the time, and we've never had any issues.
    If I click Output > EDL, then click - - - > I get the following fatal error:
    "Bus error" in thread "MainThread", at address 0x0
    If I do exactly the same thing on Avid 2.8.0 and 3.5, it works fine.
    Is this just a 3.0.5 bug? Is there any workaround?
    Thanks for your time!
    Best Regards, Chris!
  • Tue, Sep 15 2009 2:09 AM In reply to
    Re: EDL Manager Crash - Bus Error
    After a bit of further testing... it seems as if the EDL Manager doesn't like some of the speed effects in the sequence... Ummm....
  • Tue, Sep 15 2009 8:30 AM In reply to
    • St.John
    • UK
    • Posts 159
    • Points 1,920
    I too had this some time ago- I think recreating speed changes sorted it,
    or if you have access to another avid configuration, it may work.
    St.John
    Mac pro 2.66 GHz 2gb ram OSX 10.4.11 qt 7.4.5, MC 3.05,mojo gtech drives firewire 800 connection Mac pro 2.8 6gb ram, OSx 10.5.5 QT 7.5.5, MC 3.05 Nitris... [view my complete system specs]
  • Thu, Sep 17 2009 7:00 PM In reply to
    Are you using the RED16 template for your EDL?  That allows for 16-character reel names, which is necessary for RED clips.
    It should be on the Avid RED page.
    MacPro MCA (v4.0.3/3.5.9/v3.1.4) on 2x3 GHz Quad Core Xeon; Mac Meridien (v12.1.2); Unity LanShare EX (v4.1.6) [view my complete system specs]
  • Fri, Sep 18 2009 6:53 AM In reply to
    Thanks for your replies!
    Yes - I was using the RED16 template - however that wasn't the issue. EDL Manger can comfortably export standard CMX3600's EDLs out of a RED Avid project (it just chops off the end of the tape name).
    The issue was in fact the speed effects. The only way around it was to export the EDLs on the Avid that was being used to cut the piece. It seems some effects just arn't backwards compatible - although the newer versions of Avid seem to fix these issues.
    So in the end, it's just a 3.0.5 qwerk!
