Latest post Wed, Sep 16 2009 2:21 AM by Larry Rubin. 9 replies.
Page 1 of 1 (10 items)
  • Mon, Sep 14 2009 7:47 PM
    Exception: Not enough space on this media drive
    Hello All,
    I'm just attempting to import a clip from my desktop into a bin when I get the message, Exception, not enough space on this media drive. This has never happened before, and there is plenty of space on the drive that I am using. 300 GBs in fact. Not sure what to do, thinking maybe the drive got changed somehow? How can I check if it did, and if so change it back?
    Brendan Maghran
  • Mon, Sep 14 2009 7:58 PM In reply to
    Re: Exception: Not enough space on this media drive
    Double check you are importing to the drive you think you are.  How long is the file you are trying to import?
    MC 4.0.2, Nitris DX, 8-Core/2.8ghz Harpertown MacPro, 8 GB RAM, Avid VideoRAID 2.5 TB, 1.5 TB internal SATA Raid [view my complete system specs]
    Conformity is the jailer of freedom and the enemy of growth. Motion Inc FCP2Avid
  • Tue, Sep 15 2009 8:28 AM In reply to
    • St.John
    • UK
    • Posts 159
    • Points 1,920
    In media creation (cmd5) you can check which drive imports go to
    St.John
    Mac pro 2.66 GHz 2gb ram OSX 10.4.11 qt 7.4.5, MC 3.05,mojo gtech drives firewire 800 connection Mac pro 2.8 6gb ram, OSx 10.5.5 QT 7.5.5, MC 3.05 Nitris... [view my complete system specs]
  • Tue, Sep 15 2009 9:35 AM In reply to
    • mvegas
    • Posts 1,436
    • Points 16,450
    Also, check to make sure your internal harddrive has enough free space.
  • Tue, Sep 15 2009 4:59 PM In reply to
    hey guys,
    Thanks for your feedback. The file I was importing was no longer than a couple minutes, and my internal hard drive has about 400 gbs free on it, so the actual space is not an issue. I've never had this problem before. And the file I was importing was just on my desktop, so I thought it would just import normally from my internal harddrive. When I checked in media creation it was only reading one media drive. Is there a chance that the media drive my files are going into somehow changed? And if so how can I change it back?
    brendan
  • Tue, Sep 15 2009 6:03 PM In reply to
    Settings... Media Creation... Import Tab.
    Further, if you select import from the dropdown menu, rather than drag and drop the file into a bin, you can also select your destination drive there as well.
  • Wed, Sep 16 2009 12:26 AM In reply to
    Well I turned my external hd on and there was no problem importing into a bin with the external turned on. My problem is now when I don't have it on. The avid is saying, "There are no media drives available, you will only be able to import shot logs." I recently switched to Snow Leopard, I wonder if it reset my media drives somehow?
  • Wed, Sep 16 2009 1:00 AM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,995
    • Points 107,070
      Moderator: Meridien
    Check to see if it's a permissions issue.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Wed, Sep 16 2009 2:16 AM In reply to
    Yeah, that seemed to work, thank you so much this was so frustrating.
  • Wed, Sep 16 2009 2:21 AM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,995
    • Points 107,070
      Moderator: Meridien
    You're quite welcome. Glad that worked for you.
