Latest post Mon, Sep 14 2009 12:16 PM by mjolnarn. 9 replies.
Page 1 of 1 (10 items)
  • Sun, Sep 13 2009 11:25 AM
    • ThomasDubiel
    • Joined on Wed, Jan 28 2009
    • Chicago, IL
    • Posts 75
    • Points 950
    SD/HD mixed timeline issue:adjusting field order
    Hello all,
    I am cutting a project which mixes HD footage from a 5d mark II and SD footage from a canon agdvx100. I set the project up as HD 1080p, 23.976. I am attempting to export an SD clip from the timeline and i get some bad interlacing artifacts. When i go to custom settings to change the field order, that option does not exist. The SD footage is actually shot at 24p so i dont know why this would even be an issue, and i guess that might be the reason why the field order option does not show up. Or is this one of those cases where the interlacing will show up on a computer but not on actual video display? Any ideas? Thanks.
    Tom
    Avid MC v3.0, windows vists sp1, gigabyte ga-ex58-ud4p mobo,6GB 1800 Mhz ram, nvidia quadro fx 1800, 500 GB 7200 rpm boot drive, 1TB 7200 rpm media drive... [view my complete system specs]
  • Sun, Sep 13 2009 7:17 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 1,668
    • Points 21,295
    Re: SD/HD mixed timeline issue:adjusting field order
    Are you exporting it in the native frame size? (Same as source)
    Burbank, Ca
    www.alphadogs.tv
    www.digitalservicestation.com
    www.editorslounge.com
  • Sun, Sep 13 2009 7:33 PM In reply to
    • bobcat
    • Joined on Thu, Jul 20 2006
    • New Mexico, USA
    • Posts 319
    • Points 3,730
    ThomasDubiel:
    Hello all,
    Tom
    The AG DVX100 is a Panasonic camera that records in 29.97 (30i) interlace format. It uses a pulldown effect to accomplish the 24p look. The actual recording is 30i (interlace).
    (System #1)HP 8200,dual 3.4,quadro 1400, 2gb ram, 160gb boot drive, 250gb Sata internal, Avid MC 3.0, Caldigit HD Element 4TB Raid Array w/ Raid Card ... [view my complete system specs]
  • Mon, Sep 14 2009 1:17 AM In reply to
    • ThomasDubiel
    • Chicago, IL
    • Posts 75
    • Points 950
    Terence,
    Well, it exports native to the project but not native to the clip. The clip itself was captured 720X480. but i insert it into the timeline and export same as source, which means it exports at 1920X1280. Is it becuase the project is 1080p/23.976 that i do not have a field order option?
    Tom
  • Mon, Sep 14 2009 3:23 AM In reply to
    • jwrl
    • Melbourne, Australia
    • Posts 4,233
    • Points 48,650
    ThomasDubiel:
    Progressive projects do not have field interlacing.  Therefore they do not require field dominance to be specified.
    MC 4.0.3 - Asus P6T Deluxe V2 mobo - Intel i7 920 2.66GHz - nVidia Quadro 1700 - 12 Gbyte mem - Internal 4 Tb SATA II 4-way RAID 5 array - Pyro firewire... [view my complete system specs]
  • Mon, Sep 14 2009 3:28 AM In reply to
    • TCurren
    • Burbank, CA
    • Posts 1,668
    • Points 21,295
    Use the format tab to change the project back to SD, then export. I'm guessing Avid is goofing up the resizing on you. It's not really elegant in handling that during import and export.
    Burbank, Ca
    www.alphadogs.tv
  • Mon, Sep 14 2009 10:25 AM In reply to
    • ThomasDubiel
    • Chicago, IL
    • Posts 75
    • Points 950
    jwrl,
    But what if you have interlaced material inside a progressive project?
    Terence,
    I changed the format tab to SD 23.976 and still no go. I assuming the field order option does not show up, even if you have interlaced material in a project. The SD material was shot 24p, but i captured using advanced pulldown and now its 30fps.
  • Mon, Sep 14 2009 10:45 AM In reply to
    • mjolnarn
    • Joined on Wed, Feb 8 2006
    • Sweden
    • Posts 3,094
    • Points 35,350
    ThomasDubiel:
    You might want to do a search in the knowledge base for mixing interlaced and progressive or wait for version 4.
    To deinterlace interlaced media with Media Composer, you use the timewarp filter, settings source interlaced - target progresive
    MC 4,03 ( Liquid 7,2 ) V 64 Ultimate Mbo gigabyte 965-DQ6,cpu quad core QX 6700, mem Corsair Dominator 8500 8 GB, PNY Quadro 1800, Soundblaster X-Fi... [view my complete system specs]
    Tomas
  • Mon, Sep 14 2009 11:45 AM In reply to
    • ThomasDubiel
    • Chicago, IL
    • Posts 75
    • Points 950
    ahh didnt realize that i could do that. thanks!
  • Mon, Sep 14 2009 12:16 PM In reply to
    • mjolnarn
    • Sweden
    • Posts 3,094
    • Points 35,350
    You´re welcome, happy to have been able to assist.
    Tomas
