Latest post Fri, Sep 25 2009 2:41 PM by Scott Carnegie. 5 replies.
Page 1 of 1 (6 items)
  • Fri, Sep 11 2009 7:27 PM
    • et.ghi
    • Joined on Fri, Sep 11 2009
    • Posts 1
    • Points 25
    HD Monitor; Do I need a MOJO???
    Do I need a mojo to view HD projects on an HD computer monitor? If my computer monitor is HD wouldn't that be enough to see captured P2 clips and projects in HD form? Wouldn't the full screen playback be in HD? Thanks!
    -E
  • Fri, Sep 11 2009 7:42 PM In reply to
    Re: HD Monitor; Do I need a MOJO???
    Your computer monitor isn't a broadcast monitor, and in Avid your computer monitor is only showing you one field at a time, while it's output is full-rez. If you can afford a mojo, do it. There are other ways to do it (firewire out to camera, looped to monitor for example) but you will end up with sync issues. Perhaps someone else has other ideas.
    :: Work - Symphony Nitris DX 3.5.1, HP xw8600 :: Home - Media Composer 4.0, Asus P5GD2-Deluxe Mobo, Pentium 4 2.8GHz, 2 x 1GB RAM, NVidia GeForce 6600... [view my complete system specs]
    "Don't go by my script, they're always wrong." - producer to me while editing
  • Fri, Sep 11 2009 9:08 PM In reply to
    • berga
    • Stockholm, Sweden, Europe
    • Posts 1,627
    • Points 19,490
    One important addition to Scotts answer, for HD you need Mojo DX. Mojo Analog and Mojo SDI does not work with HD.
    HP xw4600, 3.2Mhz, 4Gb RAM, Mojo. 500GB SATA Bootdrive, 3x500GB internal raid-0 for video, Windows xp sp3, MC3.05, Genelec 1030A, JVC TM-H170. [view my complete system specs]
  • Fri, Sep 11 2009 9:14 PM In reply to
    • BLKDOG
    • Lansing, MI
    • Posts 15,822
    • Points 201,035
    And another important addition, the Avid only shows one field when paused. Both fields are dislplayed during playback.
  • Fri, Sep 11 2009 9:25 PM In reply to
    • bobcat
    • Joined on Thu, Jul 20 2006
    • New Mexico, USA
    • Posts 319
    • Points 3,730
    et.ghi:
    Do I need a mojo to view HD projects on an HD computer monitor? No.
    If my computer monitor is HD wouldn't that be enough to see captured P2 clips and projects in HD form? Yes, if it is full size 1080X1920 and your video card will drive the monitor.
    Wouldn't the full screen playback be in HD? Thanks! Yes, Full screen playback will playback in HD
    -E
    However, I would not trust Color correction with this method. But it works for viewing.
    (System #1)HP 8200,dual 3.4,quadro 1400, 2gb ram, 160gb boot drive, 250gb Sata internal, Avid MC 3.0, Caldigit HD Element 4TB Raid Array w/ Raid Card ... [view my complete system specs]
  • Fri, Sep 25 2009 2:41 PM In reply to
    BLKDOG:
    I don't think that's true when it plays back on your computer monitors, only on the output.
