Latest post Wed, Oct 7 2009 12:13 AM by sasha1. 19 replies.
Page 1 of 2 (20 items) 1 2 Next >
  • Fri, Sep 11 2009 6:38 PM
    • Frederick0245
    • Joined on Tue, Nov 28 2006
    • UK England
    • Posts 76
    • Points 1,025
    Is there an effect which will filter out Audio Hum MC 3.5
    Hi, I have a recording for a wedding but unfortunately during part of the recording there is a low frequency hum on the sound track, Is there an effect in MC 3.5 which might help filter this out.
    Regards
    Fred
    HP XW8400 Intel Xeon CPU 5150 @ 2.66 Ghz 2.93 Ghz, Memory = 3.0 GB Ram Media Composer 3.5 Graphics Card GeForce 1500 Hard Drives 1 x Seagate... [view my complete system specs]
  • Fri, Sep 11 2009 7:18 PM In reply to
    • cuervo
    • Joined on Fri, May 2 2008
    • Santa Fe, NM
    • Posts 331
    • Points 4,300
    Re: Is there an effect which will filter out Audio Hum MC 3.5
    your best bet would be to look at the plugins available here:
    www.izotope.com
    check out 'RX'...prolly the best noise reduction algorithmns on the planet
    Media Composer 4.03 on Win 7 64-bit and XP Pro SP3 - Intel x48, dual core quad 6600 - 8Gb RAM - PNY Quadro FX1700 - Echo Mona [view my complete system specs]
    Chalchihuitl Productions Music video, Digital Imaging JVC HD110--Sony EX1
  • Fri, Sep 11 2009 8:31 PM In reply to
    • adamsonn
    • South Africa
    • Posts 337
    • Points 4,945
    Hello
    I use Adobe Audition (I think it is called SoundBooth now) quite effectively.
    It does require you to export the audio track out of MC - import it into Audition - clean up the sound - export it from Audition and re-import it into MC, but it works
    Regards
    Neil
    MC3 machine: Intel Pentium 3Ghz Duo Dual Core (E8400) Asus P5QL-EM Motherboard 1*160 Gb SATA drive - partitioned to C (OS and programs) and D (data... [view my complete system specs]
    Neil
  • Fri, Sep 11 2009 9:58 PM In reply to
    • JohnnyReboot
    • Southern CA
    • Posts 709
    • Points 8,595
    Frederick0245:
    Regards
    Fred
    In MC with your timeline active you could try the Audio EQ Tool>Fast Menu dropdown>NTSC or PAL Hum Buster.  If that doesn't work try one of the 3 or 4 band EQ's in there and find the offending frequency.  Good luck.
    Regards, JR
    Media Composer v3.1.1-IE7-HP xw8000-TYAN Mobo S2663-Dual 2.8 Xeons-Hyperthreading On-3G RAM-Executed Install3GB.bat-Page File Initial/Max set to 2048/4092MB... [view my complete system specs]
    That's right...an xw8000.
  • Fri, Sep 11 2009 10:25 PM In reply to
    • Editmvp
    • Joined on Wed, Sep 3 2008
    • Billings, Montana
    • Posts 19
    • Points 225
    Download the free trial version of Adobe Sound Booth (formally Audition) - it has a very good noise reduction function.
    SYSTEM #1: MC Nitris DX 4.0.2/HPxw8600/Vista Biz 64 SP1/16GB RAM/Quadro 3700/2x VideoRAID RTX..... SYSTEM #2: Media Composer 3.5.4.3 w/Mojo SDI/HPxw8400... [view my complete system specs]
  • Sat, Sep 12 2009 12:46 AM In reply to
    • clockhart
    • Columbus, OH
    • Posts 258
    • Points 3,110
    Audacity also has a nice noise removal feature.
    http://audacity.sourceforge.net/
    Chris
    Avid Xpress Pro HD 5.7 Dell Precision 390 Core2Duo 2 Gigs Ram Quadro FX 3450 120 Gig Boot 300 Gig Media Drive 200 Gig Media Drive - External ; Media Composer... [view my complete system specs]
  • Sat, Sep 12 2009 3:58 AM In reply to
    • TVJohn
    • Bayonne NJ
    • Posts 1,612
    • Points 20,140
    Audacity works well, there is also an app within the nero suite 'wavelab" I think its called, works well too.
    PhenomII 940, AMD770 mobo, 4gigXMS DDR, ATIx4850, Audigy2zs, 500g SATA system drive, SATA 750g render, 640g SATA media storage, LG GGW-20HL BD/DVD XH... [view my complete system specs]
    Trial MC3.5, Using AL7.2 pro, Boris FX, DVDit6proHD, CCE Basic, TmpGe Express4, TmpGe Authoring Works 4, DVDLab-Studio. Canon XH-A1, GL2, GL1
  • Mon, Sep 14 2009 5:30 AM In reply to
    • butterfly
    • Hungary
    • Posts 108
    • Points 1,650
    I was trying Audicity but it crashes when importing a DV clip. It does not seperate the audio from the video automatically. How do I seperate the audio from the video?
    MC 3.5.1 software only, Windows XP Pro (SP3), P5Q Mbo, 4 Gb RAM, Quad Core CPU, nVidia Quadro FX580 [view my complete system specs]
  • Mon, Sep 14 2009 5:38 AM In reply to
    • JVR
    • Joined on Thu, Jul 13 2006
    • Bulli , Australia
    • Posts 1,359
    • Points 15,335
    select audio tracks only in MC and in the export box check the selected tracks only or export audio only option!
    MC 3.5.4 QTime 7.6 2x Vista Ultimate 64bit sp1 2x XW 8400 2 x 3.0gig Xeons 5160 146.8GB 15K Ultra320 o/s drive 8 gig ram FX 1500 4 1tb 32 mb... [view my complete system specs]
  • Mon, Sep 14 2009 7:01 AM In reply to
    • butterfly
    • Hungary
    • Posts 108
    • Points 1,650
    Audio EQ Tool won't open. All other audio tools open no problem, but not EQ. Any idea why not?
  • Mon, Sep 14 2009 7:15 AM In reply to
    • JVR
    • Bulli , Australia
    • Posts 1,359
    • Points 15,335
  • Mon, Sep 14 2009 8:37 AM In reply to
    • luca.mg
    • Roma - Italy
    • Posts 1,389
    • Points 15,920
    There's a few eq tools in the DAE engine too.
    MC 3.5/Mojo, Vista 64 biz, Gigabyte GA-EP45T-EXTREME, Intel Q9450, 8 GB ram, Pyro 64, Quadro FX 1700, 2 x 1TB drives (raid 0) for mediafiles + G4 MacBook... [view my complete system specs]
    peace luca
  • Tue, Sep 15 2009 2:47 PM In reply to
    • butterfly
    • Hungary
    • Posts 108
    • Points 1,650
    I have played wit the EQ Tool and was able to identify the frequency of the hum. I could deemphasize most of it but I would be more happy if I could get 10 dB less. Is there a possible tool within MC to do this.
    What is DAE engine, which luca was suggesting?
  • Tue, Sep 15 2009 2:52 PM In reply to
    • tompearson
    • Joined on Thu, Mar 1 2007
    • Wayzata MN
    • Posts 576
    • Points 6,210
    the dae engine is the audio fx that come with avid but dont waist your time with them they are poor at best
    out put your sound trks to a wav file and fix outboard on a sound pgm i use sound forge  it also has a good noise reduction  tool
    asus mb p5wd2 dualcore 3 gig intel cpu's 4 gig crucial ram nvidia quadro fx 3500 1 tb wd sata 7200 raid 0 seagate 160 gig sata 7200 os drive mojo command... [view my complete system specs]
    Tom Pearson Director Hollywood-sounds.com
  • Tue, Sep 15 2009 4:37 PM In reply to
    • butterfly
    • Hungary
    • Posts 108
    • Points 1,650
    OK, but within MC there is no possibility to reduce a certain frequency with more then 20 dB??
