Latest post Fri, Sep 11 2009 8:55 PM by berga. 2 replies.
  • Fri, Sep 11 2009 4:30 PM
    • Fimon
    • Joined on Wed, Aug 5 2009
    • Posts 19
    • Points 275
    Avid MC3 to After Effect CS4 and back
    i want to ask what is the best way to export from avid mc3 to After Effect CS4 and back? Important that quality won't lose.
    MC3.0.5, Vista Ultimate 64-bit, Intel Core 2 Quad Q9450 2.66GHz, 4GB RAM, Gigabyte EP45T-UD3P, Quadro FX 570 256 MB. [view my complete system specs]
  • Fri, Sep 11 2009 8:05 PM In reply to
    • Niko L
    • Joined on Fri, Jan 9 2009
    • Finland
    • Posts 16
    • Points 170
    Re: Avid MC3 to After Effect CS4 and back
    It depends on what is the format of your original material and how you're going to output the final project. Usually it is safest and fastest to use QuickTime reference and the original codec to export from Avid. This will save time and the quality doesn't degrade. If the material is compressed (eg. HDV or DV25), AE will need to decompress it anyway before rendering anything. When you export from AE to Media Composer, it's best to think about the final mastering format of the project. If you're mastering on DVCAM, for example, you can use the DV25 codec. If your final output is digibeta, you will gain a little bit in quality if you export it as uncompressed instead. This will minimize unecessary decompression/compression cycles.
  • Fri, Sep 11 2009 8:55 PM In reply to
    • berga
    • Stockholm, Sweden, Europe
    • Posts 1,627
    • Points 19,490
    HP xw4600, 3.2Mhz, 4Gb RAM, Mojo. 500GB SATA Bootdrive, 3x500GB internal raid-0 for video, Windows xp sp3, MC3.05, Genelec 1030A, JVC TM-H170. [view my complete system specs]
