Latest post Mon, Sep 21 2009 2:23 PM by PeterSchmitz. 111 replies.
Page 7 of 8 (112 items) « First ... < Previous 4 5 6 7 8 Next >
  • Fri, Sep 11 2009 8:05 PM In reply to
    • EditGuy18
    • Minneapolis
    • Posts 159
    • Points 1,960
    Re: Media Composer 4.0 announced
    BLKDOG:
    EditGuy18:
    Does the new MC 4.0 automatically apply the timewarp effect to non-matching formats, or is this something you go back and add manually later???
    It's all automatic and seamless to the user. No need for you to do anything. the  system recognizes the odd format and adjusts for you.
    Yeah!!  That pretty much ROCKS!!!!
    Thanks BD.
    Avid Media Composer Adrenaline HD 3.5.1.1 HP XW8400 Workstation Twin Dual Core Xeon 2.66 Processors 4 Gig Ram Windows XP Pro SP 2 NVIDIA QuadroFX... [view my complete system specs]
  • Fri, Sep 11 2009 10:08 PM In reply to
    Have just skim read all the posts and did not see this question specifically.
    Can I use the capture tool to capture NTSC AV from an NTSC deck using an appropriate NTSC machine template in a PAL project? And the  other way around.
    Reason. I get supplied multiple HD and SD formats (any of which are in 24, PAL and NTSC) masters of films for a film festival. The organisers require any combinations of these films on PAL DVDs so they can just insert 1 DVD per program.
    Edit add  Or do you open an NTSC project bin in PAL Projects as your way of introducing mixed frame rate media?
    Thanks for the continued dongle support
  • Fri, Sep 11 2009 11:11 PM In reply to
    • drbgaijin
    • Kumamoto, Japan
    • Posts 2,029
    • Points 25,915
    • Moderator: MCA PC
    BLKDOG:
    It doesn't Tomato/Tomahto.
    For those of us who speak English, I think BLKDOG means, " It doesn't Tomayto/Tomato."
    Geeked Sorry, Todd, I couldn't resist it!  Big Smile
    Regards,
    Douglas
    (AMC MojoDX 3.1.2 - XP Pro SP2) + (AMC MojoDX 4.0.2 Vista64 Business SP1),ASUS PK5 DEluxe/WiFi-AP CH1-14 Mobo,Intel Core 2 Duo E6850 (3GHz)8GB Corsair... [view my complete system specs]
  • Sat, Sep 12 2009 8:57 AM In reply to
    Re: MC 4
    taylormade:
    Hey, Bobby, you're probably right.  Guess I'm just a naturally grumpy guy.  At least I didn't threaten to go out and buy Final Cut!  I don't mind buying MC3.5 (or forcing my wife to since my location in Europe makes it difficult) or waiting until 4 comes out if the upgrade offer still stands.  I'm going with Avid either way and have always found the folks on this forum most helpful and friendly.  I promise never to be grumpy again.
    LOL! And I'm sorry if I snapped at you. Have a very nice trip ;).
    P4 3.0. 4 Gig RAM, CAS 2.0. 3Gig patch. Intel 865PERL mobo. Two WD 7,200 IDE drives. SIIG SATA II-150 PCI RAID card w/ 2 WD Raptor 10,000 SATA drives as... [view my complete system specs]
  • Sat, Sep 12 2009 9:15 AM In reply to
    • jveekeres
    • Athens Greece
    • Posts 671
    • Points 8,470
    Re: MC 4
    Hmmm, for the RT effects to work realtime, I guess there are some interesting system requirements. Was MC4 also tested on XW8200, XW8400 and XW8600 or only Z400, Z800? Any light on this Todd?
    And have any upgrades to AMA been made?
    7x HP XW8400 9x HP XW8200 4x HP XW8000 5x Media Composer 3.1 2x Media Composer 3.1 Adrenaline 2x Media Composer 2.7 Adrenaline HD 1x Media Composer... [view my complete system specs]
    Jeroen van Eekeres
    Ena productions
    Software activation AND dongle is better then only software activation.
  • Sat, Sep 12 2009 2:52 PM In reply to
    • tonifa
    • Joined on Fri, May 29 2009
    • Posts 6
    • Points 80
    I want to know if this version at least will work and be compatible -it could be great news for who don't want spend a lot of money in expensive hardware- whit video Nvidia Geforce 7025/Nvidia Nforce 630a and audio Realtek High Definition Audio onboard cards,in an Asus M2N68-AM motherboard whit AMD Phenom triple core 8650 Processor, 2 Gb RAM. Thanks.regards.
  • Sat, Sep 12 2009 3:01 PM In reply to
    tonifa:
    Except for the Realtek audio, Avid will unlikely test the it for that hardware configurtion. It might work, it might not. You will need to wait for an individual to test it themself to really find out.
    2GB of RAM is low these days by the way.
    MC 3.1.3, Intel i7 920, Vista 64 bit, Nvidia GTX 275, 6 GB of RAM, X-Fi Titanium Professional, MSI X58 SLI Platinum. [view my complete system specs]
  • Sat, Sep 12 2009 3:19 PM In reply to
    • tonifa
    • Posts 6
    • Points 80
    Thanks Dom for your quick and good explanation,regards.
  • Sat, Sep 12 2009 3:33 PM In reply to
    • camoscato
    • Posts 6,076
    • Points 72,920
    • Moderator: Avid Free DV
      Moderator: Avid Xpress Pro PC
      Moderator: Meridien
    tonifa:
     I want to know if this version at least will work and be compatible...
    Just in case you're not aware of it, there's a 14-day trial version.  You could download a trial of 4.0 when it comes out and see if it works on your system.
    good luck,
    Carl
    MC 3.5.4, HP dv9605ea, Vista Home Premium, AMD Athlon 1.8 GHz, 4 GB RAM, nVidia GeForce 7150M, Conexant HD Audio, G-tech 500GB G-drive [view my complete system specs]
  • Sat, Sep 12 2009 8:27 PM In reply to
    • vpcmike
    • Baltimore, MD
    • Posts 1,092
    • Points 12,880
    Quick questions - will the new version (and it looks like Avid did a great job from what I have read) better utilize multiple core machines?  Will 4 cores be that much better than 2?  8 better than 4?  And will ver 4 still work on XP Pro? (for those of us completely bypassing Vista and waiting for Windows 7).  And will Windows 7 be supported immediately?  Thanks in advance for the answers.
    - Mike
    System #1 -Tyan i7525 MB, dual 3.2 Xeon, 4 GB Ram, Mojo, Quadro 3500, Pyro 64 FireWire, 6 TB Unity System #2 - Intel 7505VB2 MB, Dual 2.8 Xeon, 2 MB... [view my complete system specs]
  • Sat, Sep 12 2009 8:45 PM In reply to
    vpcmike:
    Yes, according to my info, but only Vista64 was qualified for Z400 and Z800 workstations. Also: those holding out on Vista 64 are depriving themselves of some serious performance improvements. You all should have done that months ago. IMHO.
    Symphony Classic Nitris 4.0.2 on 2x 2.33 quad core XW8400/8GB Vista Biz 64bit | MC 4.0.2 on 2x dual core 2.66 XW8400/7GB Vista Biz 64bit | Mojo SDI | Unity... [view my complete system specs]
  • Sat, Sep 12 2009 8:52 PM In reply to
    • bobcat
    • Joined on Thu, Jul 20 2006
    • New Mexico, USA
    • Posts 319
    • Points 3,730
    I'm sure it will be a while before Windows 7 and Snow Leopard will be approved. Whether it will work or not on your individual machine only you can answer.
    It is never worth the trouble for me to set up Avid on an untested OS. If I had a machine just lying around or I could set up a seperate boot drive to run a new OS just to test it out that is another matter.
    Can't afford to have any extra hassles. Have to edit.
    (System #1)HP 8200,dual 3.4,quadro 1400, 2gb ram, 160gb boot drive, 250gb Sata internal, Avid MC 3.0, Caldigit HD Element 4TB Raid Array w/ Raid Card ... [view my complete system specs]
  • Mon, Sep 14 2009 7:31 AM In reply to
    • carlgmi
    • Western Australia
    • Posts 367
    • Points 4,510
    Can I confirm that when we say "yes to dongle in v4" we mean "yes to dongle in v4 without added support contract" as was discussed at some length during the dongle debate?
    MC4 with Dongle, 2xQC Xeon, Tyan 5400XT, Quadro FX3500, Adaptec RAID 0-4x1TB, 8G RAM, Creative Audigy, Vista 64 SP1, Matrox Triplehead Digital. Protools... [view my complete system specs]
    Vote 1 - Dongles.
  • Mon, Sep 14 2009 8:05 AM In reply to
    Job ter Burg:
    vpcmike:
    Well those wanting to run ProTools and MC on the same system can't use V 64, which is a shame.
  • Mon, Sep 14 2009 9:00 AM In reply to
    • camoscato
    • Posts 6,076
    • Points 72,920
      Moderator: Meridien
    HI,
    carlgmi:
    Yes, you are correct that you do not need a support contract to keep using a dongle with v4.  If you use a dongle with whatever version you're running now, you can keep using it with v4 in exactly the same way.
    good luck,
    Carl
