how can i impor a file .TOD in Avid Nitris???...
Thanks!!!........
TOD is a "type of" MPEG-2 file, and DS doesn't deal with any of them at all, so convert it/them to AVI, and import.I haven't got at TOD-file to try on, but you could try to change the extension of a file from TOD to MPG and see if your favourite MPEG-to-AVI-conversion program "swallows it". it might, but then again it might not.Otherwise you have to find software that can do a TOD-to-AVI conversion.Something on the TOD/MOD-format.http://en.wikipedia.org/wiki/TOD_(video_format)Looking at the specs I suspect that it would be possible to for example rename a file from testfile.MOD to testfile.MPG and try to import it into Adobe Premiere, and then export an AVI from there. Premiere often doesn't normally like MPEG-2's that don't have the extension MPG, but for example renaming a fileextension from VOB to MPG makes that Premiere gladly imports VOB-files.Or TMPGEnc Xpress would probably fix it.So good luck with you converting. //mike
Yes i Chance the file extension .TOD to .MPG, but avid nitris don´t acept files like this, and then need convert .MPG to MOV or AVI all clips like this way... maybe lost quality,or not?...and time ´it´s a slow process when you need transform a lot off clip... you drive avid nitris???
Mike Thank you so much!!!
jorgiatos:you drive avid nitris???
