Latest post Thu, Sep 10 2009 4:54 PM by M-Edit. 3 replies.
  • Thu, Sep 10 2009 12:58 PM
    • jorgiatos
    • Joined on Wed, Apr 1 2009
    • Posts 5
    • Points 65
    Import .TOD
    how can i impor a file .TOD in Avid Nitris???...
    Thanks!!!........
  • Thu, Sep 10 2009 3:46 PM In reply to
    • M-Edit
    • Joined on Thu, Jan 29 2009
    • Posts 60
    • Points 730
    Re: Import .TOD
    TOD is a "type of" MPEG-2 file, and DS doesn't deal with any
    of them at all, so convert it/them to AVI, and import.
    I haven't got at TOD-file to try on, but you could try to change
    the extension of a file from TOD to MPG and see if your favourite
    MPEG-to-AVI-conversion program "swallows it". it might, but then
    again it might not.
    Otherwise you have to find software that can do a TOD-to-AVI
    conversion.
    Something on the TOD/MOD-format.
    http://en.wikipedia.org/wiki/TOD_(video_format)
    Looking at the specs I suspect that it would be possible to
    for example rename a file from testfile.MOD to testfile.MPG
    and try to import it into Adobe Premiere, and then export an
    AVI from there.
    Premiere often doesn't normally like MPEG-2's that don't have
    the extension MPG, but for example renaming a fileextension
    from VOB to MPG makes that Premiere gladly imports VOB-files.
    Or TMPGEnc Xpress would probably fix it.
    So good luck with you converting.
    //mike
  • Thu, Sep 10 2009 4:05 PM In reply to
    • jorgiatos
    • Posts 5
    • Points 65
    Re: Import .TOD
    Yes i Chance the file extension .TOD to .MPG, but avid nitris don´t acept files like this, and then need convert .MPG to MOV or AVI all clips like this way... maybe lost quality,or not?...and time ´it´s a slow process when you need transform a lot off clip... you drive avid nitris???
    Mike Thank you so much!!!
  • Thu, Sep 10 2009 4:54 PM In reply to
    • M-Edit
    • Posts 60
    • Points 730
    Re: Import .TOD
    jorgiatos:
    No, not Nitris any more, but a xw8600 running DS v.10.1.2 and an AJA-BOB.
    Well, unfortunately it's always a slow and tedious process when you
    get files the DS can' t import directly.
    TMPGEnc Xpress can do batch encode, but you still have to code to
    a new fileformat and then import.
    And regarding quality. Uncompressed files won't cause any
    quality losses but the files will be huge. Of course there are
    also "lossy formats" that will do fine in many situations.
    Frameserving is another way (but only if you're on 32-bit system).
    http://www.debugmode.com/frameserver/
    This is the quickiest way to get single files inte the DS I think, but on
    the other hand it demands you attention almost all of the time.
    But I guess there are others here on the forum that has
    some kind of workflow that makes this cumbersome situation
    as painless as it can.
    I seldom have this problem cause I mostly deal with TV commercial
    length stuff. So it's just maybe 4-6 TV-spots á 30-10sec. each that
    have to be converted and imported. Not so much of a problem then,
    when you get the "wrong format" even though it's annoying.
    Anyway, would be nice to hear how you went ahead and "solved the problem".
    //mike
