Latest post Mon, Sep 14 2009 5:37 PM by Sam Z. 11 replies.
Page 1 of 1 (12 items)
  • Tue, Sep 8 2009 7:39 PM
    • Sam Z
    • Joined on Fri, Jan 25 2008
    • Posts 37
    • Points 545
    1080 29.97p
    I just started my first RED project and was looking forward to using Metafuze, however the project was shot at 1080/29.97p.  Metafuze can't transcode 1080/29.97 R3D to 1080/59.97i DNxHD 220 can it?  It didn't really look like REDCine or REDAlert can either.  So, right now I'm just importing the ProResHQ Quicktimes that were made on set so I can get started.  Does anyone have an idea for a good workflow when things are shot this way?
    Sam
  • Tue, Sep 8 2009 8:50 PM In reply to
    • TCurren
    • Burbank, CA
    • Posts 1,668
    • Points 21,295
    Re: 1080 29.97p
    Why wouldn't you just work in a 1080 29.97P project?
    Burbank, Ca
    www.alphadogs.tv
    www.digitalservicestation.com
    www.editorslounge.com
  • Tue, Sep 8 2009 8:55 PM In reply to
    Re: 1080 29.97p
    I think that  is - currently -  Symphony-only, Terry...
    Symphony Classic Nitris 4.0.2 on 2x 2.33 quad core XW8400/8GB Vista Biz 64bit | MC 4.0.2 on 2x dual core 2.66 XW8400/7GB Vista Biz 64bit | Mojo SDI | Unity... [view my complete system specs]
  • Wed, Sep 9 2009 12:57 AM In reply to
    • TCurren
    • Burbank, CA
    • Posts 1,668
    • Points 21,295
    Re: 1080 29.97p
    oops.
    Burbank, Ca
    www.alphadogs.tv
  • Wed, Sep 9 2009 7:27 AM In reply to
    Re: 1080 29.97p
    As far as the frame rate and project settings are concerned, 29.97p and 59.94i are the same thing.
    The numbers refer to frames in the case of "p" and fields in the case of "i" and there are twice as many fields. For example 29.97 x 2 = 59.94.
    Any 59.94i clip is really playing back at 29.97fps. There may be a visual difference in the material though, a progresivelly acquired material as in RED will not have visible interlacing whereas a typical video camera material will be visually interlaced. As far as the equipment and software are concerned it's all the same.
    So you could transcode to 29.97 MXF media. I am not in front of a Media Composer to see if it allows to setup a 1080 29.97 project. Theoretically, this should be the same thing as 1080 59.94i project in this particular case where field processing is not necessary due to progressive nature of original media.
    Igor Ridanovic
    www.HDhead.com
    Filed under: ,
  • Wed, Sep 9 2009 7:55 AM In reply to
    • TCurren
    • Burbank, CA
    • Posts 1,668
    • Points 21,295
    Re: 1080 29.97p
    Igor Ridanovic:
    This is exactly the only difference as far as Avid is concerned. Does it render field based or frame based. That is why i suggested doing it 29.97P. You can easily make a 59.94 out of that. Didn't know it was Symphony only. Why would Avid do that? How does one offline a 29.97P project?
    Burbank, Ca
    www.alphadogs.tv
  • Wed, Sep 9 2009 7:58 AM In reply to
    Re: 1080 29.97p
    I think this came up on the L2 some time ago, and IIRC the solution was simply to open the mediafiles in a 59.94 project and get on with it. For now.
  • Thu, Sep 10 2009 6:08 PM In reply to
    Re: 1080 29.97p
    And IIRC the newly announced MC4 makes 29.97p projects available to all.
  • Thu, Sep 10 2009 7:08 PM In reply to
    • Sam Z
    • Posts 37
    • Points 545
    Re: 1080 29.97p
    Thanks guys, I think the larger problem is that Metafuze 2 doesn't seem to support 1080p/29.97.  Metafuze is even reading my R3D files as 1080 24p even though they are 29.97p.
    When looking at page 11 of the Avid Metafuze 2.0 for RED ONE Workflows PDF http://www.avid.com/metafuze/MetaFuze_for_RED_guide.pdf under Compression it says, "Note that 1080p/29.97 (30) is not supported at this time."
    If this is true, and I'm on a PC, what are my remaining workflow options?  Also, even if I can get the footage on a Mac, I have yet to find a program that will change R3D files into 1080p/29.97 DNxHD or 1080i/59.94 DNxHD.  Please let me know if I am missing something.
    Thank you for your responses.
  • Fri, Sep 11 2009 8:00 AM In reply to
    Re: 1080 29.97p
    Redcine will output DNxHD encoded Quicktime files but there is something messed up with the codec bandwidth and those files will not fast import into Media Composer.
    Not much more on the Windows side that I can think of.
    Igor Ridanovic
    www.HDhead.com
  • Sat, Sep 12 2009 6:44 PM In reply to
    • johnnytex
    • Joined on Tue, Apr 18 2006
    • Dallas
    • Posts 44
    • Points 450
    Re: 1080 29.97p
    I am having the same problem! On a PC, footage shot at 1080/29.97. Metafuse 2.0 reads it @ 1080/24. Does Met FUSE SUPPORT 29.97????
    xw8600 XPPro 4g ram fx 3700 Media Composer 4.0.2 AvidFX ver5.1.5 [view my complete system specs]
  • Mon, Sep 14 2009 5:37 PM In reply to
    • Sam Z
    • Posts 37
    • Points 545
    Re: 1080 29.97p
    The best workflow I have for this right now is to find a Mac, install RedAlert, make sure you have updated RED and QT to handle the new RED camera firmware, convert everything to ProRes 1080p/29.97 and then import those files into the Avid (if you have up to date ProRes for Windows and Avid software you should get proper color representation and TC).
    It sucks because you basically have to transcode twice, but the only way to I've found to go from R3D 1080p/29.97 to anything useful is on a Mac and converting to ProRes.
