Latest post Sun, Sep 6 2009 3:41 PM by Alcy. 18 replies.
Page 1 of 2 (19 items) 1 2 Next >
  • Thu, Sep 3 2009 8:31 PM
    • Alcy
    • Joined on Tue, Mar 10 2009
    • Posts 198
    • Points 2,715
    How to create a 2.39:1 aspect ratio from 16:9 footage?
    My footage are from Sony EX1 with 1080/24p 16:9 aspect ratio. What is the best way to create a 2.39 aspect ratio from the 16:9 footage? I assumed I may have to do some cropping but, isn't that just basically including black bars to the top and bottom?
    Avid MC 3.5
    Dell Precision 670 Workstation
    146GB 15K RPM SCSI OS Drive
    10GB RAM
    Nvidia Quadro FX 4400
  • Thu, Sep 3 2009 9:56 PM In reply to
    • Vidiot Tech
    • Joined on Thu, Apr 6 2006
    • South Carolina
    • Posts 120
    • Points 1,335
    Re: How to create a 2.39:1 aspect ratio from 16:9 footage?
    Create a photoshop 2.39 aspect ratio inside a 16x9 project & export with alpha. Import into AVID with " invert alpha" checked. Apply to new video track above your final edit.
    System Specs: Dell M90, 4GB Ram (3GB Avid Enabled), nVidia FX 1500 w/ driver 8.4.2.9, MC 2.8, QT 7.2, External WD 750 GB eSata Drive [view my complete system specs]
    Steve Godsey, CLVS
    WARNING: Excessive consumption of alcohol leads to memory loss. Worse yet....it leads to memory loss.
  • Fri, Sep 4 2009 1:50 PM In reply to
    • Alcy
    • Posts 198
    • Points 2,715
    Thanks for the response. However, wasn't there an effect already available in MC that will automatically crop the 16:9 to 2.39 without manually creating my own one in Photoshop and bring it into MC? I know that there was one for 4:3 to 16:9 but I'm not sure about 16:9 to 2.39. I don't quite remember. However, essentially, what it does is just putting black bars on top and bottom blocking the areas of the 16:9, correct?
    Avid MC 3.5
    10GB RAM
  • Fri, Sep 4 2009 2:04 PM In reply to
    Yes, that is what it does. Adding a 16x9 mask to a 16x9 image will result in a 2.35:1 aspect ratio. You can set your grid preferences to display 2.39:1 if I recall correctly. You could then adjust any mask effect to create a letterbox effect for that aspect ratio.When I do this I find that a 75% vertical sized mask results in a 2.35:1 aspect ratio, and a 71% vertical sized mask results in 2.39:1.
    Symphony Classic Nitris 4.0.2 on 2x 2.33 quad core XW8400/8GB Vista Biz 64bit | MC 4.0.2 on 2x dual core 2.66 XW8400/7GB Vista Biz 64bit | Mojo SDI | Unity... [view my complete system specs]
  • Fri, Sep 4 2009 2:23 PM In reply to
    • Alcy
    • Posts 198
    • Points 2,715
    Okay, so let me try to understand this. By setting my MC compser window grid, I can get the composer window to show the 2.39:1 grid and then I can create a mask on another video track to cover the top and bottom based on those grid, correct? Does anyone have an instruction on how to show the grid for 2.39:1 grid? In addition, do I have to create this mask through Photoshop as the first poster suggested? There isn't an already made effect for this available in MC 3.5?
    Thanks for the help.
    Avid MC 3.5
    10GB RAM
  • Fri, Sep 4 2009 2:55 PM In reply to
    Assuming 16x9 footage in a project with 16x9 monitors:
    - Open the Grid Settings
    - In the "Coordinates" tab, choose "4:3 outside 16:9 Monitor"
    - In the "Display" tab, choose "Anamorphic"
    - Choose Apply
    - Choose OK.
    No need to create anything in Photoshop.
  • Fri, Sep 4 2009 3:05 PM In reply to
    • Alcy
    • Posts 198
    • Points 2,715
    Thanks, ter Burg! That sounds much easier than I initially thought. I'll give that a try tonight. By doing this way, MC will automatically crop my 16:9 footage to 2.39, correct?
    Thanks again.
    Avid MC 3.5
    10GB RAM
  • Fri, Sep 4 2009 3:50 PM In reply to
    Actually, you will be ordering MC to add a 2.39:1 matte to your footage that way.
  • Sat, Sep 5 2009 4:11 PM In reply to
    • Alcy
    • Posts 198
    • Points 2,715
    Okay, I'm not sure if I understand this correctly. I have done the steps you mentioned above and nothing on the composer window has changed. Any idea?
    Avid MC 3.5
    10GB RAM
  • Sat, Sep 5 2009 4:32 PM In reply to
    • Alcy
    • Posts 198
    • Points 2,715
    Job ter Burg:
    Okay, I figured how to turn the grid on by pressing the Grid button to turn on the grid I just set according your instruction above; however, I unless I don't totall understand this, I don't think turning and setting this grid will automatically put a matte on my footage. I believed that if I export my sequence out, I'll still the footage in full 16:9 and not 2.39:1 aspect ratio.
    Avid MC 3.5
    10GB RAM
  • Sat, Sep 5 2009 4:44 PM In reply to
    The grid is just a grid. You need to apply a mask, and set it so that it matches the 2.39:1 gridlines.
    Like you said yourself:
    Alternatively, just apply a Mask effect and set the V-size to .71.
  • Sat, Sep 5 2009 5:00 PM In reply to
    • NubusAvid
    • Joined on Fri, Mar 3 2006
    • Kent U.K.
    • Posts 126
    • Points 1,435
    Using the Grid as Job suggested is to set the mask height accurately.
    Drop a mask effect on the layer above your sequence and set the height in the effect editor to 71.
    MCA 4.02 DNxHD card Macpro Quad 3Ghz 3Gb Ram Apple Fibrecard Infotrend 15Tb Sata raid 5 Fibre chassis. Panasonic TH-50PF9UK Monitor Yamaha 03D Mixer... [view my complete system specs]
  • Sat, Sep 5 2009 5:31 PM In reply to
    • Alcy
    • Posts 198
    • Points 2,715
    NubusAvid:
    That's what I figured. Without this last step, it does not seem it is working properly. It does seem correct now. However, how do I apply this mask effect to the whole sequence instead of clip by clip?
    Avid MC 3.5
    10GB RAM
  • Sat, Sep 5 2009 5:35 PM In reply to
    Create a new layer on top of your sequence. (CTRL-Y). Apply the effect to that empty top layer.
  • Sat, Sep 5 2009 6:08 PM In reply to
    • Alcy
    • Posts 198
    • Points 2,715
    Job ter Burg:
    That's a smart idea. One other things I was wondering. Is there a way to adjust and move the footage up and down to show what I wanted in the 2.39:1 aspect ratio screen since a mask is being apply?
    Avid MC 3.5
    10GB RAM
