Latest post Thu, Sep 3 2009 1:59 PM by lateral. 3 replies.
  • Wed, Sep 2 2009 5:20 PM
    • lateral
    • UK
    • Posts 126
    • Points 1,525
    Timecode in DPX headers
    I'm going to be receiving graded takes exported from an iQ as DPX files to seperate folders.
    Previously, I was able to easily then conform from these files using afe/edl's.
    Last time the facility manually added the source TC when exporting from the iQ. (Source TC is lost when the grades are rendered/exported to files)
    This time however due to the amount of material (i.e. it'll take to long for them) they're unwilling to add source TC to the exported DPX's.
    Couple of questions...
    Any chance that it'll still conform without embedded TC?
    Could I add the TC myself to the DPX headers using the DS or another program and then conform?
    Thanks for any pointers.
    Edd
    Posted in the ds list as well.
    I support, use and own various systems. [view my complete system specs]
    Eddtheditor
  • Wed, Sep 2 2009 5:35 PM In reply to
    • slabross
    • Montreal
    • Posts 381
    • Points 3,800
      Moderator: Avid DS
    Re: Timecode in DPX headers
    If you are running Avid DS 10+, you need to use DPX with timecode information in order to link them for real-time playback.  Or you can capture them to convert to GEN material (HD RGB and higher formats).
    Details in the Avid DS Hi-Res Workflow and Color Guide.
    Sylvain Labrosse
    Avid DS Product Champion | Video Customer Success
    Avid
    3510 St-Laurent Boulevard
    Montréal, QC H2X 2V2
    Canada
    sylvain.labrosse@avid.com
    We're Avid.  Learn more at www.avid.com
  • Wed, Sep 2 2009 5:41 PM In reply to
    • lateral
    • UK
    • Posts 126
    • Points 1,525
    Thanks for the reply sylvain.
    Could I capture the dpx's to gen and then manually add/modify TC and set Source Roll #, like in avid.
    Would an imported edl/afe then link? (if the metadatas right off course)
    Eddtheditor
  • Thu, Sep 3 2009 1:59 PM In reply to
    • lateral
    • UK
    • Posts 126
    • Points 1,525
    For others in a similar situation, the obvious answer is to use some software to restamp the timecode.
    Higher end pricey products like...
    Pomfort Silver Stack
    Gluetools plugins
    or
    MonkeyJobs DPX-Timecode-Editor which is cheap and seems to do the job.
    or if you can script, the free
    ImageMagick
    Eddtheditor
