Latest post Sun, Nov 8 2009 11:38 AM by MovieMaker76. 11 replies.
Page 1 of 1 (12 items)
  • Wed, Sep 2 2009 4:15 PM
    XDcam yellow-- can you remove highlight in bin?
    I realize that the yellow highlight is to indicate that the files are not native in the Avid Media Files folder, but has anyone found a way to turn that off or change the color? I'm working with a few editors who find the yellow highlights in their bins distracting and hard to search through. Has anyone found a workaround for this? Thanks!
  • Wed, Sep 2 2009 4:32 PM In reply to
    • Posts 1,595
    • Points 19,885
      Avid Employee
      Moderator: Broadcast Newsroom
    Re: XDcam yellow-- can you remove highlight in bin?
    Checking around for you hellobowser....  it isnt that intuative to me so I am checkign with the engineering group to see if a. you could change the color to say blue or pink and b. if it can be turned off.
    I'll report back.
    marianna
    Customer Advocate/Customer Success [view my complete system specs]
    813-493-6800 mobile
    AOL IM avidmarianna
  • Wed, Sep 2 2009 4:40 PM In reply to
    • Posts 1,595
    • Points 19,885
      Avid Employee
    Hi again....
    Unfortunately...........  yellow is it, and it can't be changed for now.
    marianna
    813-493-6800 mobile
    AOL IM avidmarianna
  • Wed, Sep 2 2009 4:43 PM In reply to
    Ah too bad, but thanks for your help Marianna!
  • Thu, Nov 5 2009 4:39 AM In reply to
    • MovieMaker76
    • Joined on Tue, Mar 25 2008
    • Los Angeles
    • Posts 208
    • Points 2,685
    It is yellow because it needs to be transcoded.  Once the clip is transcoded it will not be yellow any longer.  You just need to transcode it to the DNxHD codec.  Right click the clip and follow the stetps.
    Hope this helps.
    Intel Core 2 Duo E 6700, RAID(0), NVIDIA Quadro FX 3450/4000, 4GB ram, Vista64, MC 3.5 [view my complete system specs]
    Filed under: , , ,
  • Thu, Nov 5 2009 3:14 PM In reply to
    • bobcat
    • Joined on Thu, Jul 20 2006
    • New Mexico, USA
    • Posts 319
    • Points 3,730
    I am new to the AMA process, so this is as much a question as anything, but can't you also just consolidate the files to any "Avid" hard dirve and continue to work with native XDCAM files? Or do the files have to be in a DNxHD code?
    (System #1)HP 8200,dual 3.4,quadro 1400, 2gb ram, 160gb boot drive, 250gb Sata internal, Avid MC 3.0, Caldigit HD Element 4TB Raid Array w/ Raid Card ... [view my complete system specs]
  • Thu, Nov 5 2009 3:53 PM In reply to
    bobcat:
    It's my understanding that any hard drive containing P2 or EX material can be an AMA volume and would show up as highlighted.  So, if you simply move the file structure over then you're still using AMA.  If you truly do a "Consolidate" or Transcode, then the files will be converted to an Avid media type/codec.
  • Thu, Nov 5 2009 6:13 PM In reply to
    • MovieMaker76
    • Los Angeles
    • Posts 208
    • Points 2,685
    bobcat:
    Yes, you can continue work with the native XDCAM file.  I was letting him know that if he transcodes to DNxHD that it will not be highlighted yellow.
  • Fri, Nov 6 2009 9:43 PM In reply to
    • chomper129
    • Los Angeles
    • Posts 164
    • Points 2,025
    Are there any disadvantages to just leaving them in their original folder?  I am doing a job right now where some of the material is AMA (therefor yellow), and it seems to work just fine as is.  Am I setting myself up for something to go wrong by just leaving it?  I can consolidate if I need to, but I'm not sure if that's necessary.
    MC4 with Adrenaline HD BOB MacPro 2 x quad 2.26 - 6Gb RAM work and a late 2008 MacBook Pro at home Command Soft FibreJet Fibre Channel Drives [view my complete system specs]
  • Sat, Nov 7 2009 12:23 AM In reply to
    • Pope
    • Portland, OR
    • Posts 14
    • Points 165
    FWIW, we're dealing with relatively large batches of tapeless media - sometimes combining P2 and XDCam - and have come close to reaching capacity of our 4.8 TB Sonnet eSATA array with a single combination project when consolidating/transcoding to DNXHD. While it's not recommended by Avid, we have taken to just using AMA and working off the source camera files stored on the eSATA array throughout the duration of the project. OTher than potential stability isses, which we haven't seen, the only significant challenge we've seen is losing the ability to export a QT Reference because of long-GOP video. It takes longer to export full QT files, but until things improve in the market and we can spend into the mid-four figures on more media storage, this seems to work for us.
    I think it might be a different story if you're working from USB 2.0 or FW drives, SCSI or eSATA seems to have enough throughput to support working this way. We're also pretty backup-happy around here, so it's a lot less time-consuming to backup those camera files to a separate drive set (in our case, a DROBO) than it is to archive the Avid Media Files folder, sifted by media mover, to another storage location.
    I'd be interested in hearing the concerns Avid has with working long-term with AMA-enabled media...
    Avid 1 = MC 3.5 Adrenaline on MacPro 2 x 2.8 GHz Quad-Core Intel Xeon OS 10.5.6 Avid 2 = MC 3.5 Nitris DX on MacPro 2 x 2.8 GHz Quad-Core Intel Xeon OS... [view my complete system specs]
    Brian Casey
  • Sun, Nov 8 2009 11:02 AM In reply to
    • gumbycat99
    • Joined on Fri, Jun 6 2008
    • Auckland, New Zealand
    • Posts 255
    • Points 3,040
    bobcat:
    if you consolidate AMA P2 or EX/XDCAM footage then they stay in their native codec - Avid can read them now, just has to re-wrap them in some cases as mxf files and pop them into the Avid Media Files folder. Once they have been consolidated to that folder then they stop being yellow. But they will still be in their native format.
    I've heard that using lots of AMA volumes eats up memory, so that might be a reason to consolidate. I always figure that consolidating means the original copy becomes a backup, so after a shoot I copy the cards folder/files onto an external drive, then open in Avid and consolidate to an internal media drive. The advantage of AMA is that I can start editing immediately if necessary for quick turnaround. Or just go through and make selects for consolidating.
    cheers
    Campbell
    3.0.5 on a mongrel PC, Win XP SP3, QT7.5, Quadro FX1400, 2Gb RAM, 2x500Gb internal SATA drives, Macdrive 7 and a Mac formatted WD 250Gb laptop drive in... [view my complete system specs]
  • Sun, Nov 8 2009 11:38 AM In reply to
    • MovieMaker76
    • Los Angeles
    • Posts 208
    • Points 2,685
    gumbycat99:
    bobcat:
    cheers
    Campbell
    Thank you very much.  Extremely helpful!
    Sincerely,
    Todd
