Latest post Tue, Sep 22 2009 2:22 PM by Larry Rubin. 4 replies.
  • Wed, Sep 2 2009 2:22 AM
    • sfo
    • Joined on Wed, Sep 2 2009
    • Posts 2
    • Points 30
    Does Avid Xpress (Meridien) support xdcam...
    I have an old meridien system an got a last minute project that needs to be edited on Avid. It was shot on XDCam and I want to know if the old avid can handle it before I dig up the machine and hook it up. Oh, and I plan to work only with the proxy files.
    Thanks!
    -O
    Filed under: , , , ,
  • Wed, Sep 2 2009 2:34 AM In reply to
    Re: Does Avid Xpress (Meridien) support xdcam...
    Meridien is SD only, so no flavors of HD.  You could attach an XDCAM player, and record baseband, and choose any low-bandwidth resolution you want.  To finish in HD, however, you'll need to switch to a newer Avid.
    Media Composer 3.5.9/4.0.2 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 8GB RAM, FX 3700, 1TB Boot, 1 x 1TB & 1 x 500GB internal SATA media drives, 3-Ware... [view my complete system specs]
    Our new websites are up!
    http://www.lifenetintl.org/
    http://www.capitalchristian.net/
  • Wed, Sep 2 2009 2:40 AM In reply to
    • sfo
    • Posts 2
    • Points 30
    The footage is SD and my client is planning send me just the proxies to edit an offline seq. I guess my question is, will the system be able to import the low-rez proxies?
  • Tue, Sep 22 2009 1:21 PM In reply to
    • FunkyDragon
    • Boston MA
    • Posts 529
    • Points 6,280
    the answer would be no.
    Meridian development stopped about 6 years ago.
    MC 3.5 Software License! HP nw9440 Laptop Mojo SDI Camera: DVX100A Deck: DSR 1500a [view my complete system specs]
     The FunkyDragon
    Happy Editing!
  • Tue, Sep 22 2009 2:22 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 8,995
    • Points 107,070
      Moderator: Meridien
    However, if you can get a hold of a PDW-1500, it can be set to an AV/C mode which will allow the deck to emulate a VTR for realtime playback and capture. You probably will need to toggle source on the capture tool and capture on the fly without timecode, as I don't think you'll be able to establish a channel to handle the PDW remotely. This is assuming your client still has the original source XDCAM disks.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
