Latest post Mon, Aug 31 2009 8:36 AM by mvegas. 10 replies.
Page 1 of 1 (11 items)
  • Sat, Aug 29 2009 8:53 PM
    • ratrat
    • Joined on Sun, Jan 28 2007
    • Posts 22
    • Points 300
    No deck control
    Can anyone offer any suggestions... I am trying to capture from a JVC BR-HD50 deck using rs-422. When I auto configure etc Avid does not recognise the deck. I have a Sony HVR M25U which works through the Convergent Systems box & the RS-422 works fine through this & also on my standard Sony UVW-1800. I have the setting "on" in the menu for 9 pin control, does anyone have any experience with this JVC deck, or offer any explanations?
  • Sat, Aug 29 2009 8:59 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,005
    • Points 107,160
      Moderator: Meridien
    Re: No deck control
    Please tell us what specific platform and MC version you're running. Have you checked your "deck configuration" profile in your user settings? Do you have the channel configured correctly, depending on whether you're using analog inputs or firewire?
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Sat, Aug 29 2009 10:13 PM In reply to
    • ratrat
    • Posts 22
    • Points 300
    Re: No deck control
    I'm sorry... I'm using Avid Symphony vers 5.5.5 (Meridien) with a H/P workstation XW-8000. I'm using the standard RS-422 cable (9 pin) not firewire. I have checked the deck configuration & everything appears to be correct.
  • Sat, Aug 29 2009 10:21 PM In reply to
    Re: No deck control
    Have you gone to manually configure the deck to a JVC deck?  I am on a MC soft this morning and it has a JVC BR-50U PAL template available.
    Avid often does not automatically find a deck and uses generic. Tradditionally Sony tends to work with almost any template and JVC's are FAR more fussy (in my experience)
    Seeing that you are on a Meridian you may need to try adding a template. They are simple text files so if you email me I can send you a zipped one that may or may not work with your older system.
    Thanks for the continued dongle support
  • Sun, Aug 30 2009 12:36 AM In reply to
    • ratrat
    • Posts 22
    • Points 300
    Re: No deck control
    That would be fantastic, and well worth a try! What is your e-mail?
  • Sun, Aug 30 2009 1:33 AM In reply to
    Re: No deck control
    When logged in double click on my forum name and "Start a conversation" with Andrew will get me.
  • Sun, Aug 30 2009 2:20 AM In reply to
    Re: No deck control
    You have mail
  • Sun, Aug 30 2009 3:32 AM In reply to
    Re: No deck control
    "... I'm using the standard RS-422 cable ..."
    JUst to clarify, are you using a Rosetta Stone (or comparable device) to convert the computer RS-232 to RS-422?
    Media Composer 3.5.9/4.0.2 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 8GB RAM, FX 3700, 1TB Boot, 1 x 1TB & 1 x 500GB internal SATA media drives, 3-Ware... [view my complete system specs]
    Our new websites are up!
    http://www.lifenetintl.org/
    http://www.capitalchristian.net/
  • Sun, Aug 30 2009 7:54 AM In reply to
    • mvegas
    • Posts 1,436
    • Points 16,450
    Re: No deck control
    Randy is right, the Rosetta Stone is required on Meridien systems.  Try another JVC deck template or generic deck template.  Also check the deck to see if there is a serial port setting that needs to be set.
  • Sun, Aug 30 2009 12:27 PM In reply to
    • ratrat
    • Posts 22
    • Points 300
    Re: No deck control
    Yes, I am using a rosetta stone.
    I have tried several templates, and several of the ones you sent to me Andrew, but to no avail. I cannot get deck control or T/C from this deck! Thanks for trying, maybe the system is too old for those deck templates? Because I rented the deck, I had to just bring everything in at 2:1 with no T/C.
    Thanks for all the help & advice though.
  • Mon, Aug 31 2009 8:36 AM In reply to
    • mvegas
    • Posts 1,436
    • Points 16,450
    Re: No deck control
    can you control other decks with the same hardware?
