Latest post Wed, Apr 23 2008 10:28 PM by scroll2b. 11 replies.
Page 1 of 1 (12 items)
  • Tue, Jan 17 2006 1:44 PM
    • iszkiri
    • Joined on Tue, Jan 17 2006
    • Posts 1
    • Points 15
    Can't find any audio cards in your system
    Hi!
    First when I downloaded and installed my Avid Free DV, everything worked correctly.
    After I installed my webcam (Logitech Quickcam Pro 5000) Avid pops the following error message:
    "Can't find any audio cards in your system. You will not be able to play audio."
    What can I do to work my Avid correctly again?
    Please help me!
    Iszkiri
  • Tue, Jan 17 2006 3:00 PM In reply to
    Re: Can't find any audio cards in your system
    Search on "webcam" ... there's dozens of posts.
  • Tue, Jan 24 2006 12:53 PM In reply to
    • Baklap
    • Hilversum - The Netherlands
    • Posts 6,612
    • Points 78,310
    as in disconnect the webcam prior to start up.. USB webcams often come with a mic and therefore act like a soundcard for the OS.. Avid does not like that much...
    Menno
    Test-Intel Core2Duo 6800,GTS8800 Nvidia (soft modded into Quadro FX4600),Soundblaster Live 5.1, 21" Samsung display [view my complete system specs]
    Dutch AV forum
  • Thu, Feb 15 2007 11:10 AM In reply to
    • RST
    • Posts 629
    • Points 7,370
    Baklap:
    Menno
    Thank you, Avideers.  I disconnected the webcam, and that did it.
    Much appreciated.
    Dell Precision Workstation 670 with a single Intel Xeon CPU (3.20GHz) and 3 GB of RAM; NVIDIA Quadro FX 1400 with Driver Version 6.14.10.9185; SB Audigy... [view my complete system specs]
    "Meet the wife, and don't laugh." - Shemp (WHY PAY RENT?, 1935)
  • Sat, Jul 14 2007 4:27 AM In reply to
    • makastoo
    • Joined on Sat, Jul 14 2007
    • Posts 2
    • Points 20
    I am running Avid Xpress Pro 5.6 and had a Logitech webcam in my USB port. I was recieving the same error message at startup and it forced me to use the "dont play audio" setting. I detached my webcam and - BAM- Avid now recognizes my sound card. *Phew
    Thanks for this post
  • Sun, Apr 20 2008 5:28 PM In reply to
    • emendator
    • Joined on Sun, Apr 20 2008
    • Chicago
    • Posts 4
    • Points 50
    I have the same problem with Xpress 3.5, and I've searched all the posts adressing webcam issues.
    I've unplugged and uninstalled my logitech webcam to no avail.  Any other ideas would be much appreciated.
    Thanks much.
    Microsoft Windows XP Pro Avid Xpress DV 3.5 Quicktime 7.4.1 Dell Inspiron 6400 [view my complete system specs]
  • Sun, Apr 20 2008 5:45 PM In reply to
    • camoscato
    • Posts 4,526
    • Points 54,075
    • Moderator: Avid Free DV
      Moderator: Meridien
    What audio card is in your system?
    good luck,
    Carl
  • Sun, Apr 20 2008 6:09 PM In reply to
    • emendator
    • Chicago
    • Posts 4
    • Points 50
    It's a Sigma Tel High Definition Audio CODEC
  • Sun, Apr 20 2008 6:33 PM In reply to
    • camoscato
    • Posts 4,526
    • Points 54,075
      Moderator: Meridien
    emendator:
    Unfortunately, Avid has a lot of trouble with Sigma Tel and Realtek HD audio cards.  Here are the results of a forum search for realtek.
    You may be able to get it working by trying different drivers, or changing your Windows mixer settings, but most people wind up getting a Soundblaster Audigy 2 card and installing that.
    good luck
    Carl
  • Mon, Apr 21 2008 3:23 AM In reply to
    • emendator
    • Chicago
    • Posts 4
    • Points 50
    Thanks much.  I'll look into the Soundblaster card, as this is just a frustrating issue.
    The advice is much appreciated.
    - Chris
  • Mon, Apr 21 2008 4:03 AM In reply to
    • emendator
    • Chicago
    • Posts 4
    • Points 50
    After searching for a sigma tel driver, I did find this link.
    http://www.downloadsource.net/16240/Toshiba-SigmaTel-HD-Audio-Driver-Windows-XP/
    I downloaded and installed and I'm not getting the "can't play audio" warning when I start up, but I still can't hear anything.  Part of this has to do with the fact that I have no idea what I'm doing in the Avid, so it may me a very simple fix.
    -  Regardless, I'm happy to have found a solution to the main problem and I can check with an editor tomorrow at work to find out if I'm nearing the end of this issue.
    - Thanks again.
  • Wed, Apr 23 2008 10:28 PM In reply to
    • scroll2b
    • Joined on Tue, Apr 1 2008
    • Posts 1
    • Points 5
    Got the same message with my Audigy 2 zs (model number = SB0350), but I just installed it so I'm still working out the issue...
    Update: Originally I updated the drivers through Windows Update. Lesson learned: use the official driver download...
