Latest post Tue, Oct 20 2009 7:24 PM by John Sprung. 8 replies.
Page 1 of 1 (9 items)
  • Wed, Aug 26 2009 9:04 PM
    • chadg
    • Joined on Thu, Mar 12 2009
    • Los Angeles
    • Posts 11
    • Points 155
    Has anyone used this camera?
    The DP of a feature I'm cutting this fall is thinking of using the Canon EOS 5D Mark II. It's a still frame camera that also shoots full HD video at 1080p. Here's the link:
    http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=139&modelid=17662
    Workflow we have in mind is to shoot this camera (at 30p), offline on Media Composer and create an HD master, then do a film-out to introduce grain and additional contrast, then color the negative, mastering back to HD.
    Wanted to see if anyone here has dealt with this camera for filmmaking before. And if so, what sorts of problems I might need to look out for, both with the media and the workflow?
    Any feedback is greatly appreciated!
  • Thu, Aug 27 2009 10:51 PM In reply to
    Re: Has anyone used this camera?
    The big problem is that this camera is limited to 30 frames per second, which means you have to convert somehow to 24.  There are two ways to do that:  either expensive, or low quality.  Using it for a few shots as a gag, or for slight slow motion could be reasonable.  To do a whole feature that way doesn't make sense.  Wait for them to release a model that does 24 fps, how hard could that be?
    -- J.S.
  • Thu, Aug 27 2009 10:58 PM In reply to
    • chadg
    • Los Angeles
    • Posts 11
    • Points 155
    Yeah you would think it wouldn't be that hard... there were rumors that 24p was in the works for this camera but those turned out to be false.
    I'm pretty sure we're removing this camera from consideration but thank you for the reply.
  • Fri, Aug 28 2009 3:41 PM In reply to
    • MichaelP
    • Boston
    • Posts 1,751
    • Points 21,670
      Moderator: Film
      Moderator: MetaFuze
    The other issue is that it is a 30.00fos camera and not 29.97. Any sync sound would need to be recorded 48048 if doing a frame for frame inport into a 29.97 project type.
    There has been rumors of a 24p version, but latest rumors seem to indicarte it wouldn't be an update to this model, but a different model camera altogether. We shall see.
    Michael
    HP 8600 Symphony Nitris DX v4 || MBP 15" Media Composer v4 [view my complete system specs]
    ____________ Anything 24fps
  • Wed, Sep 2 2009 1:13 AM In reply to
    Here it is, they've released a new model 7D:
    http://www.dpreview.com/news/0909/09090105canoneos7d.asp
    It does 29.97 and 23.976.
    -- J.S.
  • Wed, Sep 2 2009 1:24 AM In reply to
    Oh man .... just when I thought it was safe to back into the camera store!
    Media Composer 3.5.9/4.0.2 w/Mojo (analog), HP xw8400, 1xQC 3.0GHz, 8GB RAM, FX 3700, 1TB Boot, 1 x 1TB & 1 x 500GB internal SATA media drives, 3-Ware... [view my complete system specs]
    Our new websites are up!
    http://www.lifenetintl.org/
    http://www.capitalchristian.net/
  • Wed, Sep 2 2009 1:27 AM In reply to
    • chadg
    • Los Angeles
    • Posts 11
    • Points 155
    Wow, that was fast! Looks like my digital to film and back again workflow might actually be saved. And now for some more research... Thanks for the link!
  • Wed, Sep 2 2009 4:53 PM In reply to
    • pianoman72
    • Joined on Thu, Feb 9 2006
    • Dallas, TX
    • Posts 294
    • Points 3,355
    We've used this camera (rented one first and then purchased one) - it's awesome.  Check for firmware updates before you shoot.  We didn't use the audio from the camera but it's not bad.  I imported the 30p media directly into a 29.97 project - didn't seem to cause any problems.
    OSX Leopard can play the media natively if you have the Digital Camera RAW Compatibility Update 2.6 installed.
    MC Adrenaline v3.5.1 OSX Leopard 10.5.5 Mac Pro 2x3 Ghz Quad-Core Intel Xeon 4GB RAM, NVIDIA Graphics Card 5TB VideoRAID [view my complete system specs]
  • Tue, Oct 20 2009 7:24 PM In reply to
    They have a 24p/25p firmware upgrade coming early next year:
    http://www.smarthouse.com.au/Digital_Photography/Still_Cameras/K2B2J6P7
    -- J.S.
