Latest post Mon, Nov 16 2009 9:43 PM by GOZ. 60 replies.
Page 1 of 5 (61 items) 1 2 3 4 5 Next >
  • Tue, Aug 25 2009 7:27 PM
    • taynos
    • Joined on Wed, Jan 21 2009
    • Posts 6
    • Points 130
    MC 3.5 and Snow Leopard - Mac OSX 10.6
    With the announcement that the 64 bit update for Mac OSX, Snow Leopard (OSX 10.6) will be available for upgrade earlier than expected (August 28th, 2009)
    Will Media Composer 3.5 and above versions be compatible Snow Leopard?
    A huge advantage in using Snow Leopard would allow access to more than 2GB of RAM per APP, which would obviously be a fantastic thing for Avid editors / producers.
  • Tue, Aug 25 2009 8:06 PM In reply to
    • berga
    • Stockholm, Sweden, Europe
    • Posts 1,627
    • Points 19,490
    Re: MC 3.5 and Snow Leopard - Mac OSX 10.6
    I is surprise how well Apples marketdepartment work. I thougth that OSX has been 64-bit for years??? And a 2GB RAM limit??? why have nobody tell me this? Maybe FCP also have some hidden limits?Wink
    To be serious, I do not know if MC will utilise the 64-bit, because it is a 32-bits program, at least in the Windows version. It has to be run in some sort of 32-bit mode.
    Transcode a software from 32-bit to 64-bit is a huge task, and it takes time. As I understand it, Adobe has not manage to make photoshop 64-bit for OSX (but it exist for Windows, but the rest of the CS4 suite is 32-bit).
    HP xw4600, 3.2Mhz, 4Gb RAM, Mojo. 500GB SATA Bootdrive, 3x500GB internal raid-0 for video, Windows xp sp3, MC3.05, Genelec 1030A, JVC TM-H170. [view my complete system specs]
  • Wed, Aug 26 2009 1:57 PM In reply to
    • oze
    • New Zealand
    • Posts 206
    • Points 2,415
    Avid ususally gets there eventually. My guess is that it will take a while to get 10.6 compatability for MC, especially since it uses Quicktime X - that's probably going to pose a few challenges. I have FCS 3 so I'll probably install it on another drive and see how it runs. It sounds promising though.
    Mac Pro 2.66Ghz , 17GB RAM, NVidia 8800GT/512MB, OS 10.5.6, MC 3.5, 750Gb Internal, Analog Mojo, 23 inch Cinema Display. Also 17" MBP Unibody 2.93Mhz... [view my complete system specs]
  • Thu, Aug 27 2009 3:17 PM In reply to
    • red ant
    • Joined on Wed, Feb 1 2006
    • Posts 129
    • Points 1,560
    OK, so, when I order my new 24" iMac tomorrow, will I need to order a "downgrade" of some kind??  Confused
    It would be great to hear that Avid has been testing with the developer versions of Snow Leopard.... after all, it was announced in June, and copies were made available...
    MC3.5 on a MacBook Pro 17", OSX 10.5.7, 2.6GHZ core2duo, 4GB 667MHz DDR2 SDRAM, external LaCie d2Quadra 500GB on FW800. the ole' pc: Avid Xpress... [view my complete system specs]
  • Thu, Aug 27 2009 3:45 PM In reply to
    Avid tests with developer versions, but they only qualify actual shipping versions. And thorough testing takes time.
    Symphony Classic Nitris 4.0.2 on 2x 2.33 quad core XW8400/8GB Vista Biz 64bit | MC 4.0.2 on 2x dual core 2.66 XW8400/7GB Vista Biz 64bit | Mojo SDI | Unity... [view my complete system specs]
  • Thu, Aug 27 2009 5:44 PM In reply to
    • berga
    • Posts 1,627
    • Points 19,490
    I think it is important to remember that Avid MC is a production system, just like the transaktion system in banks.
    It costs Avids customer more it there system stop because of a not fully tested computer and OS is used compare the the cost of not been able to use the latest and greates in these OS.
    Remember that Newscutter och MC is used by TV-stations, and it theses systems stops, there will be no broadcast and no advertising and no income.
    This attitude from Avid is one of the main, and most important, difference compare to the competitiors.
  • Fri, Aug 28 2009 5:57 AM In reply to
    • red ant
    • Posts 129
    • Points 1,560
    berga:
    ha ha, i guess you're right... still, it would be nice to hear from Avid... "hey, we're testing snow leopard" or "working on a patch " or "certification expected by mid-october" or... something!  and have an FAQ telling people what to do.
    im going to call the apple rep and ask if there is such a thing as downgrades...  the apple people can be so unhelpful because they hire all these kids based on  their hip looks... useless! ha ha ha.
  • Fri, Aug 28 2009 6:59 AM In reply to
    • Raimonc
    • Riga, Latvia
    • Posts 16
    • Points 160
    Hi, today I got Snow Leopard, installed it and what a surprise - Avid MC 3.0 works. I have MBP SantaRosa, later I will play with it, try to connect some FW devices and will see what will happen then, if everything will be ok, maybe it is worth to try to install SL on MacPro with NitrisDX.
    MBP, 15", 2.4, MC3.1, 10.5.6 MacPro, 2x3.0 quad core, MC3.1.3, NitrisDX [view my complete system specs]
  • Fri, Aug 28 2009 6:41 PM In reply to
    • berga
    • Posts 1,627
    • Points 19,490
    red ant:
    I think it can be difficult to give a schedule for then a certification can be done. We can assume they are testing today (and also they are playing with Windows 7) and if there is no problems, the certification can be soon. But if they got some unexpected problems, it can take times before is is solved and as everyone knows, solving problems is a time consuming business which is quite unpredicted. (But ok, some sort of more openess would be wellcome, and will work as a competitive edge towards Adobe and Apple. Maybe in blogform, we start testing, every is fine after 50% test, uups, very difficult problem, and so on.).
  • Fri, Aug 28 2009 6:49 PM In reply to
    • Posts 1,606
    • Points 20,025
      Avid Employee
      Moderator: Broadcast Newsroom
    Red Ant et al....
    I shoud have more later but for now I can say that Avid is testing Snow Leopard for use with MC and Symphony - as well as other Avid products.
    Stay tuned - will post again with a bit more scoop.
    Customer Advocate/Customer Success [view my complete system specs]
    813-493-6800 mobile
    AOL IM avidmarianna
  • Fri, Aug 28 2009 9:22 PM In reply to
    • romaneagle
    • Joined on Fri, Sep 26 2008
    • California, USA
    • Posts 8
    • Points 100
    Do tell. Also, I still have M.C. 3.1. Can you certify that works? I don't plan to upgrade to 3.5+ until next tax year. Thanks!
    Media Composer on a supped up Mac. I use eSATA G-RAID for external drive(s). [view my complete system specs]
  • Fri, Aug 28 2009 9:42 PM In reply to
    • red ant
    • Posts 129
    • Points 1,560
    Marianna:
    Red Ant et al....
    sweet!  thanks for the update.
  • Fri, Aug 28 2009 11:33 PM In reply to
    • Posts 1,606
    • Points 20,025
      Avid Employee
    Romaneagle.....
    I am not sure exactly where the cutoff will be but will run it to ground next week with QA.  They are done for the day in Tewksbury-land so I cant start checking until Monday.
    813-493-6800 mobile
    AOL IM avidmarianna
  • Sat, Aug 29 2009 12:57 AM In reply to
    • romaneagle
    • California, USA
    • Posts 8
    • Points 100
    Thanks! & Thanks for being so quick to status update!!! Impressive!
  • Sat, Aug 29 2009 5:24 AM In reply to
    • Torv
    • Marin County, California
    • Posts 6
    • Points 110
    I just upgraded to Snow Leopard and Media Composer 3.5.4 seems to work fine.  It launches and I'm able to edit.  I'll post if any anomalies arise!
    Later.
    Torv
    Mac OSX, Mac Book Pro [view my complete system specs]
