Can anyone confirm whether the LTC Out XLR on the Nitris DX Bob works. Trying to get it to feed a Tek scope for logging but doesn't seem to work. I'm not near another source of time code to check the scope end now. I tried switching project formats but no luck. Could this be tied to the original format of the sequence (TC1)? Just thinking out loud.
John Moore Barking Trout Productions bigfish@pacbell.net
Well I've been able to confirm the scope will read time code from a deck just not the Avid. I have gone to the general settings and enabled "Generate LTC On Playback" but still nothing out of the avid that reads at the scope.
Hi John, Did you check to see if Generate LTC on playback was enabled in the General tab?
Derrick Abeyta | Blu Pixel
Phoenix, Arizona
www.blupixelpost.com
Sorry, I see you've already checked that.
I just ran an XLR cable from the DX LTC out to my HDCAM deck and it is reading LTC timecode correctly.
I plugged the time code input to a deck and it reads code from it but not the LTC out of my Nitris DX. I guess I'll have to dig a little deeper to see if there is any signal coming out the bob. If it works for you that gives me hope.
The LTC signal is just an audio signal (@1x speed ~4kHz). Check the audiolevel of the LTC with a peakmeter, maybe you have to amplify or attenuate the signal.
Udo
Forgot to follow up on the resolution to my problem. Here is my post to the L2
Thanks for all the suggestions. Today it is working!!! yeah I did plug the output into the mixer and heard time code and I put it into a composite scope and saw it. I will say relative to the BNC time code output of a Panny 1400 the voltage is about 30% less. I think my problem was coming from the fact that I was not only wiring in the time code signal, but also an external remote panel to recall presets. I think perhaps when I was testing I was also calling up presets remotely that were programed to read anc tc not ltc. I probably didn't notice the change at the time. It also didn't help that I dragged in a Panny 1400 as my time code reader but I didn't realize it was set to firewire input so it wouldn't read code but it would generate code. Oh well after ohming and scoping I think the scope just decided to give me a break when it saw I had the Panavise out and a bunch of alligator clips it knew it would be next on my chopping block. So bottom line the Avid was outputting time code I just couldn't get anything to read it yesterday. So Avid I promise to not have any more tantrums about time code. So if I'm good can I get my split to reference back in the color corrector? ;-)
