Latest post Wed, Aug 26 2009 1:38 PM by spejampar. 12 replies.
Page 1 of 1 (13 items)
  • Mon, Aug 24 2009 2:58 PM
    • spejampar
    • Joined on Mon, Mar 3 2008
    • Evanston, IL
    • Posts 33
    • Points 415
    trouble importing an XDCAM clip
    For some reason when I'm trying to import an XDCAM clip, I get this error:
    XDCamStreamReader::Read - Error reading from essence
    it also says to look at the console for more info.  It says it "failed to write essence" and "failed to write index table to file."
    Spencer
    Filed under: , ,
  • Mon, Aug 24 2009 3:06 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,003
    • Points 107,150
      Moderator: Meridien
    Re: trouble importing an XDCAM clip
    Spencer:
    In the import tool options XDCAM tab, de-select "import essence marks as locators" and try again.
    Newscutter Nitris DX 8.0.2 * Media Composer Adrenaline PC v 3.5.4 * F-70 XDCAM HD & PDW1 * PDZ-1 XDCAM Browser * Sapphire 2.05 plug-in (single platform... [view my complete system specs]
  • Mon, Aug 24 2009 3:11 PM In reply to
    • spejampar
    • Evanston, IL
    • Posts 33
    • Points 415
    thanks for the suggestion but I don't have an XDCAM tab in the import option.  I'm running MC 3.5.4.  Could it be somewhere else?
    Spencer
  • Mon, Aug 24 2009 3:13 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,003
    • Points 107,150
      Moderator: Meridien
    Not sure on that. I don't have 3.5.4 here to check it on. Mine shows it in the import tool options.
  • Mon, Aug 24 2009 3:19 PM In reply to
    • spejampar
    • Evanston, IL
    • Posts 33
    • Points 415
    i think I do remember seeing that when we went to 3.0 but then it must've went away when we went to 3.5.  It's got to be in there somewhere.  I'll look in the help.
    Thanks!
    Spencer
  • Mon, Aug 24 2009 3:58 PM In reply to
    • Moses.M
    • Joined on Mon, Jun 9 2008
    • Austria
    • Posts 487
    • Points 6,125
    it IS there in 3.5.4 (MC/PC) SETTINGS -> IMPORT -> XDCAM -> 5th point: Import Essence Marks as Locators
    Avid Adrenaline DNxcel | HP xw8400 - Xeon CPU 2.66 GHz - 3GB RAM | easyRAID 4TB | XP 32 bit | QT 7.5.5 | MC 3.5.4 | PDW-U1 (Firmware 2.420) | DVW-M2000P... [view my complete system specs]
  • Mon, Aug 24 2009 4:07 PM In reply to
    • spejampar
    • Evanston, IL
    • Posts 33
    • Points 415
    I definitely have no XDCAM tab in the import settings.  Could there be something else that's different about this system that would affect that?  Very strange.
    Spencer
  • Mon, Aug 24 2009 5:30 PM In reply to
    • Moses.M
    • Austria
    • Posts 487
    • Points 6,125
    hm.... at least in my version, it's there. have you tried to reinstall the app?
  • Mon, Aug 24 2009 5:31 PM In reply to
    • Moses.M
    • Austria
    • Posts 487
    • Points 6,125
    have you tried to enable / disable AMA?
  • Mon, Aug 24 2009 5:36 PM In reply to
    • spejampar
    • Evanston, IL
    • Posts 33
    • Points 415
    Hm, that's an option.  no, I haven't tried that.  Thanks!
    Spencer
  • Wed, Aug 26 2009 11:46 AM In reply to
    • mvegas
    • Posts 1,436
    • Points 16,450
    You might want to post your question on the active Media Composer forum.  The forum
    you are on now are for vintage (hardware based) systems like Meridien/ABVB, etc
  • Wed, Aug 26 2009 1:36 PM In reply to
    • Larry Rubin
    • Washington DC
    • Posts 9,003
    • Points 107,150
      Moderator: Meridien
    Spencer:
    Tell me if you're on PC or Mac and I'll move this thread to the appropriate MC Forum.
  • Wed, Aug 26 2009 1:38 PM In reply to
    • spejampar
    • Evanston, IL
    • Posts 33
    • Points 415
    Thanks for your suggestions!
    I still need to check out the AMA thing but it seems to be working now.  Thanks Larry, but no need to move this over to the proper thread. I will keep that in mind for the future.  I didn't realize I was posting on the wrong one.
    Spencer
