Latest post Mon, Aug 24 2009 1:18 AM by BrettC. 2 replies.
  • Sun, Aug 23 2009 10:52 PM
    • BrettC
    • Joined on Fri, Jul 27 2007
    • Auckland, New Zealand
    • Posts 23
    • Points 345
    Does Analogue Mojo down convert from HD to SD?
    I have a Client that has rented my MC dongle and my SDI mojo, they have a limited budget. The footage that they are cutting is Red footage they are using the component out put from the SDI mojo to monitor in component. Could this be done also using an analogue mojo?
    Avid Media Composer 3.01 running on a Mac Pro Dual core. 2.66Ghz. 8Gb of ram. OS 10.4.11. SDI Mojo. 8Tb external storage Dual channel scsi,(Info Trend... [view my complete system specs]
  • Mon, Aug 24 2009 12:45 AM In reply to
    • jef
    • Joined on Sun, Feb 26 2006
    • Maryland
    • Posts 470
    • Points 5,780
    Re: Does Analogue Mojo down convert from HD to SD?
    Your question is a bit confusing to me because there is a lot of missing info.  But I will attempt an answer by saying that I have an old analog Mojo.  I can set up a HD project and switch it to SD and the Mojo will output images to my SD monitor.
    That said, there might be some limits.  So the question is exactly what types of HD projects will it do this with?  I do not know the full list.  I know it works with 1080i 59.94.  Probaly others.
    Cheers,
    Jef
    MC 3.1.3 Mac Dual 2.8 8core ATI2600 OS 10.5.7 QT 7.6 10 GB ram 2xSATA software raid local storage [view my complete system specs]
  • Mon, Aug 24 2009 1:18 AM In reply to
    • BrettC
    • Posts 23
    • Points 345
    Thanks Jeff
