Latest post Fri, Aug 21 2009 5:25 PM by spejampar. 2 replies.
  • Fri, Aug 21 2009 4:36 PM
    • spejampar
    • Joined on Mon, Mar 3 2008
    • Evanston, IL
    • Posts 33
    • Points 415
    "Exception: std:: exception, what:bad allocation" while importing
    For some reason when I'm trying to import XDCAM clips into a 1080p/29.97 project, I get this error:
    Any thoughts on why?  I've imported XDCAM clips into other projects before with no problems and I think at least one of them has been 1080p/29.97.
  • Fri, Aug 21 2009 5:18 PM In reply to
    • Posts 1,604
    • Points 19,990
      Avid Employee
      Moderator: Broadcast Newsroom
    Re: "Exception: std:: exception, what:bad allocation" while importing
    hmmmmmm the only time I have seen this error is when someone tries to capture a PAL 25fps clip in an NTSC 30i project.   There was even a tech note written for this as it was a common error for people doing that.
    Are you sure the project type is the same as what you are capturing?   Can you open a new project and try to capture the XDCAM clips into that???? maybe narrow it down to this specfic project.....
    Customer Advocate/Customer Success [view my complete system specs]
    813-493-6800 mobile
    AOL IM avidmarianna
  • Fri, Aug 21 2009 5:25 PM In reply to
    • spejampar
    • Evanston, IL
    • Posts 33
    • Points 415
    Thanks for the info!
    I actually restarted the entire computer and it worked!
    Spencer
