Latest post Fri, Aug 21 2009 5:53 PM by BobRusso. 1 replies.
Page 1 of 1 (2 items)
  • Fri, Aug 21 2009 8:00 AM
    • weghet
    • Joined on Fri, Aug 21 2009
    • Posts 2
    • Points 30
    workflow canon 5DMII and newscutter
    Hello,
    I shot an entire story with a Canon 5DMKII as the SX cam broke down on the spot. Now I need to edit with the material in Newscutter for broadcasting on tv. I've been searching for decent workflows;but no luck. Can you please help us?
    Tx,
    Tom
  • Fri, Aug 21 2009 5:53 PM In reply to
    • BobRusso
    • Tewksbury, MA
    • Posts 970
    • Points 11,915
      Moderator: Avid Symphony Nitris
    Re: workflow canon 5DMII and newscutter
    I believe the camera records 1920 x 1080 30p H.264 QuickTime files. If QuickTime player can play the files you should be able to import them into the Avid.
    It might be better to use MPEG Streamclip and batch transcode the files to a DNx145 QuickTime file. These will fast import in Newscutter.
    Since the camera records at a true 30p and not 29.97p, there will be a slight change to the frame rate.
    -- Bob Russo Applications Specialist at Avid Technology
