Latest post Sat, Aug 22 2009 9:41 PM by EL Dudero. 4 replies.
  • Fri, Aug 21 2009 3:32 AM
    • EL Dudero
    • Joined on Mon, Apr 9 2007
    • Toronto
    • Posts 17
    • Points 215
    Avid crashes on closing
    My Avid Media Composer has been crashing for some time, it happens as soon as I want to close it. To be more precise once I decide to quit Avid it closes its windows and as I am about to see it disappear it sends me the message:
    "Assertion failed: err == noErr
    File: /Snapshots/releng.relengintel7_1236903488/vobs/ppg/MCTop/ProjectFiles/../../MediaComposer/Media_Composer/MediaComposerApp.c,  Line: 631"
    With the three buttond underneath: "Create Report, Exit to Finder, Continue or Debugger."
    Anyone?
    thanks
    ELD
    Media Composer 3.1.3; 2 x 2.66 GHz Dual Core Intel Xeon; 5 GB 667 MHz DDR2 FB-DIMM [view my complete system specs]
  • Fri, Aug 21 2009 5:57 AM In reply to
    • Bill Nelson
    • West Coast
    • Posts 715
    • Points 8,145
    Re: Avid crashes on closing
    Señor Dudero:
    I'll bet you've got some confused media drive databases.  Smarter folk will be along soon, but until then I'd try deleting the database files generated on each of your drives where you store your media.  Restart the app, watch the databases rebuild, and then see if you achieve an uneventful shutdown.
    buena suerte!
    MC v3.5.4 thru SDI Mojo, OS 10.5.8, QT 7.6, on Quad-Core Intel Xeon 2.8 w/8 gig RAM, 2Tb internal RAID volume, 4TB CalDigit HDOne RAID, 30"Display... [view my complete system specs]
    "I scare nothing! Even you become napkins!"
    (english subtitles in Hong Kong kung-fu movie)
  • Fri, Aug 21 2009 7:19 PM In reply to
    • EL Dudero
    • Toronto
    • Posts 17
    • Points 215
    Do you mean to delete:
    msmFMID.pmr and msmMMOB.mdb files in my MXF folders, I did it but the same problem is there again.
    Thanks though
    ELD
  • Fri, Aug 21 2009 7:23 PM In reply to
    • Serleejus
    • Posts 334
    • Points 4,340
    Hi, we have the same problem for some time now. The only way to quit without having it crash is to close the project, then quit to exit. It seems to be fine that way. I had a similar post regarding this, but I dont remember if the error was exactly the same. The only thing is to completely uninstall and re-install, but we're in a middle of a project so not a good idea now.
    Take care and good luck
  • Sat, Aug 22 2009 9:41 PM In reply to
    • EL Dudero
    • Toronto
    • Posts 17
    • Points 215
    The same goes here, in the middle of the project, but thank you for the close-before-quetting tip. It works.
    ELD
