Hi! No, all PC's are in domain, and domain controller is that time source.
Aha, then that might be where the problem comes from. Is the lanshare also in the domain?
I have never put my editing systems in a domain. The rights issues avid and Unity have, and the lack of documentation, have stopped me from ever trying. The forum user that might be able to help you is DocAvid.
Maybe if you send him a private mail he will join this thread.
Jeroen van Eekeres
Ena productions
Software activation AND dongle is better then only software activation.
But lanshare can be in a domain (there is a description in avid documentation how to setup lanshare in domain).
There is a tool, named Server Log Viewer. And this info from that program:
Local transport enabledTarget mode transport enabledGetSystemInfo returned 4 logical processorsGetProcessAffinityMask returned f for system and 1 for processBinding thread to processor(s) 1 (mask)MediaNetwork 4.2.1 Server 4.2.1 has successfully started.Avid Unity Server (Version 4.2.1) is running.[Press ? for interactive help.]Physical Mem 2046 MB, Auto Mount Size 500 MB, Disk Limit 32, File Limit 250000, Dir Limit 10000Allocated 1042 MBReserved 54400 bytes for requestsReserved 5120 bytes for internal requestsReserved 40960 bytes for internal responsesReserved 27648 bytes for net buffersReserved 640000 bytes for 10000 channelsReserved 2097248 bytes for heap validationReserved 32768480 bytes for disk validationReserved 2164800 bytes for transaction journalReserved 880000 bytes for open segmentsTotal 5910176 bytes reservedMax Users allowed by dongle is 4Mirroring is not allowed by dongleVirtual server name: AVID-99C7B8294AFCInitializing IBOD target mode communication areaEnabling the fc target mode communication transportEnabling the local communication transportIs a LANshare, so the LUN masking feature is not used...Found a partition -- need 15 disks and have 15Logical Unit 0, named Drive 000 is \Device\Harddisk16Logical Unit 1, named Drive 001 is \Device\Harddisk2Logical Unit 2, named Drive 002 is \Device\Harddisk3Logical Unit 3, named Drive 003 is \Device\Harddisk4Logical Unit 4, named Drive 004 is \Device\Harddisk5Logical Unit 5, named Drive 005 is \Device\Harddisk8Logical Unit 6, named Drive 006 is \Device\Harddisk6Logical Unit 7, named Drive 007 is \Device\Harddisk7Logical Unit 8, named Drive 008 is \Device\Harddisk9Logical Unit 9, named Drive 009 is \Device\Harddisk13Logical Unit 10, named Drive 010 is \Device\Harddisk10Logical Unit 11, named Drive 011 is \Device\Harddisk11Logical Unit 12, named Drive 012 is \Device\Harddisk12Logical Unit 13, named Drive 013 is \Device\Harddisk15Logical Unit 14, named Drive 014 is \Device\Harddisk14Spare disk \Device\Harddisk1Found data disks.Meta Set 1 Disk 0 \Device\Harddisk16 Disk 3 \Device\Harddisk4Meta Set 2 Disk 1 \Device\Harddisk2 Disk 4 \Device\Harddisk5Meta Set 3 Disk 2 \Device\Harddisk3 Disk 5 \Device\Harddisk8Did not lock section: addr 42edd000, len 8192, retry 0, status 87 Failed to lock 1 sectionsMemory lock down complete. Took 7 secondsLocked 1119768576 bytes into working set in 285 of 286 sections with 1 errorsWorking set is now 1124831232 min and 1126039552 maxLooking for active file managersAllowing server operationSet Created Fri Apr 04 10:32:52 2008Meta Set 1 Sequence Number is 5557492 using 2 disksMeta Set 2 Sequence Number is 5557493 using 2 disksMeta Set 3 Sequence Number is 5557494 using 2 disksLocal Disk Sequence Number is 5557491Loading metadata from Meta Set 3Partition0 Mounted from Meta Set 3Removing Auto.ImportServer created a new recovery file.Area 0, total 500 MB, unlocked 344 MB, locked 155 MBArea 1, total 500 MB, unlocked 344 MB, locked 155 MBPartition mount completedServer startup complete. Took 50 secondsWatchdog - enabling watching of metadata saving
"Locked 1119768576 bytes into working set in 285 of 286 sections with 1 errors" - what does this "1 errors" mean I don't understand.
The problem solved!
1) We disabled unnecessary resources (services)
2) We played with antivirus software
Files become visible. It looks like something ate part of system memory.
Thank you all for advice!
Update to 4.2.3 at your earliest convenience, or 4.2.4 if you plan on ever attaching Windows 2003 server clients. 4.2.1 was not a fun build.
The question about metadata, files are either there or not with a metadata problem- that would be a global issue, and you would prolly have obnoxiously high file and folder counts.
What AV solution are you using?
JDS
