Latest post Tue, Aug 18 2009 7:21 PM by mrmikster. 6 replies.
Page 1 of 1 (7 items)
  • Mon, Aug 17 2009 11:21 PM
    • switthaus
    • Richmond/Gwynns Island VA
    • Posts 1,071
    • Points 14,280
    Relinking issues
    Hey all -
    not EXACTTLY related to Metafuze but I am covering all my bases...
    Doing the offline to online route with Red files via Metafuze. Took the raw red
    files thru MF and created DNXHD36 "offline" files to cut on MC 3.5.1. Created
    the ALE. Checked the material on a 3.5.3(whatever the latest is now) system at
    the place I did the transcoding and everything showed up. Even did a test back
    to the Raw red files via DS and all worked great....there.
    Copied the MXF files and the ALE to my FW drive and now that I am at my studio
    on 3.5.1, I cannot get the files to relink. My gut tells me I am missing a
    simple filtering setting or something along those lines...I went back to the MF
    users guide and it seems I am going about it correctly but without the desired
    result...
    Ideas? Thanks in advance.
    sw
    Scott Witthaus
    Owner/Editor/Post Production Supervisor 1708 Editorial
    www.1708editorial.com
  • Mon, Aug 17 2009 11:59 PM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 353
    • Points 3,945
    • Moderator: Avid DS
      Moderator: MetaFuze
    Re: Relinking issues
    Framerate mismatch?
    "There are no rules for the brave". Albert Einstein
  • Tue, Aug 18 2009 12:00 AM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 353
    • Points 3,945
      Moderator: MetaFuze
    Also, uncheck almost all the relink options in MC, including match to media from this project. This has bitten me before.
  • Tue, Aug 18 2009 12:11 AM In reply to
    • switthaus
    • Posts 1,071
    • Points 14,280
    yeah, tried all of those options.  I trashed the media databases and when it re-built it flagged two files as "possibly" unreadable and asked if I wanted to quarantine.  I said ignore to both.
    Scott Witthaus
  • Tue, Aug 18 2009 7:29 AM In reply to
    What happens if you don't ignore but Quarantine the files?
    Also, do the mediafiles you need appear in the Media Tool? If so, can you "relink to selected" when you drag them into a bin? Are you sure that any earlier transcodes are all hidden from the system (including audio from those)? I ask this since I think that MF will create mediafiles with the exact same filename per R3D clip.
    Since you have two files that the Avid doesn't like, it sounds like the copy to or from the FW drive has not been 100% successful.
    Symphony Classic Nitris 4.0.2 on 2x 2.33 quad core XW8400/8GB Vista Biz 64bit | MC 4.0.2 on 2x dual core 2.66 XW8400/7GB Vista Biz 64bit | Mojo SDI | Unity... [view my complete system specs]
  • Tue, Aug 18 2009 12:41 PM In reply to
    • switthaus
    • Posts 1,071
    • Points 14,280
    Job -
    the Media Tool suggestion was a good one.  I can see the files via the media tool, and can see that the rate is 23.98 compared to the project at 24.  I thought I could change this in the format tab, but no joy.  Once I created a new project with the frame rate set there, rebuilt the media database, all worked well.  So indeed, it was operator error.  I assumed that I could change to any format from within the project and we all know what "assume" does!  Thanks Job/MrMikster.
    Scott
    Scott Witthaus
  • Tue, Aug 18 2009 7:21 PM In reply to
    • mrmikster
    • Los Angeleez
    • Posts 353
    • Points 3,945
      Moderator: MetaFuze
    Framerate has stumped me before. I assumed it could use 23.98 for 24fps media.
