Hi Guys!
Some months ago I purchased via ebay an old Meridien system. I´m a huge reliability lover, so an used meridien system was an logical option ( big mistake)
I have a lot of problems with my vendor, and to this date I haven´t the system working properly.
I have some problems:
- It´s based on a G4. The second LCD monitor won´t turn on. I´m working with a pair of Belina 19" lcd monitors (1024X??)... What can I do to configure the system?
- I bought in the same reseller, 2 avid media drives with 2 HDD scsi 180 Gb... For my surprise when I opened the enclosures there were empty!!! without the drives!!! what model of hdd do I need to put inside the enclosures?
- I have a keyspan adapter mod. USA-28XG, but the meridien does not recognize the adapter. What can I do? perhaps it´s a problem with the OS and this model?
Thanks in advance!!!!!
The USA 28XG has a frame accuracy problem but should be recognized. Are you running the keyspan adaptor from a USB hub? If so, try connecting direct. Make sure you visit www.keyspan.com and download the appropriate keyspan software.
Can you get either monitor to work? How are you seeing your desktop? What version of composer software are you trying to run? The OS supported may not be compatible with your flatpanel monitors.
Can you be a bit more specific about your storage issue. Description and or model numbers would help
HTH
