Latest post Tue, Nov 20 2018 10:46 PM by dew. 8 replies.
Page 1 of 1 (9 items)
  • Thu, Aug 13 2009 7:24 PM
    • Ob1-adobe
    • Joined on Thu, Aug 13 2009
    • Posts 2
    • Points 30
    How do I change colors of clips in timeline?
    I know you can set up avid to show the clips as different colors in the time line based on source, or off line.
    But I just want to highlight/color a clip in the timeline just so I can make it stand out. Like if its a cut I don't like or if its something I want to change later on, I want to give that clip a certain color in the time line so I can see it easy among the rest.
  • Thu, Aug 13 2009 7:29 PM In reply to
    • babyblue
    • Joined on Fri, Oct 5 2007
    • Rio de Janeiro Brazil
    • Posts 200
    • Points 2,570
    Re: How do I change colors of clips in timeline?
    Go Timeline fast menu, active the local color
    Use segment mode to mark the clip, after go to main menu and change whatever color you want
    08 stations MC 6.5.2 XENON QUAD CORE 8 GBYTES MEMORY VIdeo ATI 1 Gbyte, SHARED NETWORK DRIVES 02 ISIS 5000, INTERPLAY. [view my complete system specs]
  • Thu, Aug 13 2009 8:59 PM In reply to
    • Sylvain P
    • Montreal, Quebec, Canada
    • Posts 1,484
    • Points 17,545
    The main menu  is : Edit / Set Local Clip Color
    Media Composer 2018.5 (Symphony Option), ASUS P8P67 Deluxe, Intel i7 2600k, 16G DDR3-1600, PNY NVIDIA Quadro 2000 (353.82), Windows 10 Pro. Boris Red 5... [view my complete system specs]
    Sylvain Primeau
    Self-employed worker - Les productions Primeau Medias
    primeaumedias.com
    Radio-Canada/CBC news editor
    cbc.ca / ici.radio-canada.ca
  • Thu, Aug 13 2009 9:09 PM In reply to
    • Ob1-adobe
    • Posts 2
    • Points 30
    Do high light the clip first using segment mode? then go to edit and set local color
  • Thu, Aug 13 2009 10:29 PM In reply to
    • Posts 10,159
    • Points 217,400
    Hello Ob1-Adobe,
    I describe the procedure in this video Tutorial beginning from about 1min. 35 secs
    Good luck.
    Douglas
  • Tue, Jun 27 2017 2:01 PM In reply to
    Sylvain P:
    I'm on 8.8.4 and this menu item does not exist. I can only access it via right click but I need the menu command for a macro.
    Any ideas?
    MC 8.8.2 OSX 10.12.3 Quicktime 7.6.6 Nitris DX [view my complete system specs]
  • Tue, Jun 27 2017 2:17 PM In reply to
    • Posts 10,159
    • Points 217,400
    This will help James.....
    http://resources.avid.com/SupportFiles/attach/Media_Composer_Editing_Guide_8.8.pdf
    do a find on this document using Clip Colors and there are a bunch of ways - timeline color, bin color, clip color.... etc...
  • Tue, Nov 20 2018 7:19 PM In reply to
    • JPBU
    • Joined on Sat, Jan 11 2014
    • Canada
    • Posts 142
    • Points 1,925
    This is what I see in the manual but can't find the "Set Local Clip Color" from the Edit Menu in MC 2018.10.
    You can assign local colors to clips in the Timeline — for example, to indicate clips that you want to group together or to make clips stand out while you work in the Timeline.
    To assign a local clip color:
    1. Click the Timeline Fast Menu button, and select Clip Color. The Clip Color dialog box opens.
    2. Select Timeline Local, and then click OK.
    3. Select one of the segment tools in the Timeline palette, and select a clip you want to color.
    4. Do one of the following:
    Select Edit > Set Local Clip Color > color to select a standard color.
    Select Edit > Set Local Clip Color > Pick to select a custom color from the Windows Color
    dialog box.
    The assigned local color appears in the clip in the Timeline.
    Media Composer 2018.10 | iMac Pro (2017) 3.2 GHz Intel Xeon W | 64 GB 2666 MHz DDR4 | Radeon Pro Vega 56 8176 MB | G-Raid 16TB Thunderbolt 3 | macOS... [view my complete system specs]
  • Tue, Nov 20 2018 10:46 PM In reply to
    • dew
    • Joined on Tue, Feb 27 2007
    • Posts 509
    • Points 6,530
    https://www.youtube.com/watch?v=XXZja3Qp6g4
    This video goes through changing colors for the interface, tracks, and individual clip colors...
